Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Aggressive fitment 19x9.5 et22 front and 19x10.5 et34 rear
      01-15-2018, 05:14 PM   #1
tan_rich
Drives: 2013 335is
Did some research however I would like some extra input. Anyone can chime in on this fitment? I'm fairly certain the front will rub.
E92 335is
Lowered a decent amount on ST XTA
19x9.5 et22 with 245/30/19 front
19x10.5 et34 with 275/30/19 rear
235/35/19(25.48" diameter) seems to work while 245/35/19(25.75" diameter) isn't recommend, however maybe 235/30/19(24.79" diameter) would fit
      01-19-2018, 04:21 PM   #2
techwhiz
techwhiz's Avatar
Drives: e90 335i Sedan - Arctic
E92 335is
I know the tires fit.
I have that size on my car.
I don't know about those offsets but:
You can use the tool here
http://www.e90post.com/forums/forumdisplay.php?f=12
I plugged in my numbers and compared the to your proposed:
I'm running 19x9 ET33 with 245/35 and the calculator says
" 5mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 17mm"
That's about 2/3 of and inch. Mine are already pushed out pretty good.
The 335is has plastic fenders up front so you can't even do a pull.
On the rear I'm running 19x9.5 ET30 with 275/30
When I compare that number to what you want, I get.
"17mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 9mm"
I would need a fender roll on my car in the rear to have these fit.
I don't know if I have 2/3 inch of additional clearance.
It's definitely going to be tight.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
      01-19-2018, 07:35 PM   #3
tan_rich
Drives: 2013 335is
I see thanks for the info.
Well from my research the front is doable with 235/35/19 and about -2 to -3 camber. My car is fairly low tho so I will probably raise it.
The rears are doable with a raise, fender roll and slight stretch as well, most likely in 265/30/19.
The wheels were a good deal that i couldnt pass up, worse case is i flip them or hold them for a m3
      01-23-2018, 02:35 AM   #4
Adieu
73
Drives: 335d
Rears seem doable as is
      01-23-2018, 04:43 AM   #5
Digitalize
Photographer
Digitalize's Avatar
United Kingdom
412
Drives: 320D
They'll fit with 235/275 tyres and a little camber work.
      01-23-2018, 05:45 PM   #6
tan_rich
Drives: 2013 335is
That seems to be the consensus, im fitting on some vorsteiners vff-103 so lets see how it goes.
