Pics on the BMW Radio Professinal from behind?
05-29-2008, 04:35 PM | #1 |
Rep 714
Does anyone have any pics on the BMW Radio Professional from behind?
I need to see what kind of channels and inputs it has. |
05-29-2008, 05:28 PM | #2 |
Nigerian Prince
385
Rep 2,180
Drives: '11 F25
i will be able to help you with thing next week. probably on Tuesday.
08-21-2008, 06:37 PM | #5 | |
2295
Rep 13,001
Of course, the diffrerence will be that those 4 circular holes in that connector will have the fiber cables in the Top (digital) Hi Fi system. |
08-22-2008, 05:19 AM | #6 |
Rep 105
which sub-area on the connector is for lineout? and which is for speaker level output as standard system don't have amp?
08-22-2008, 11:19 AM | #7 |
Spaniard member
Rep 197
I think this schema is OK for the new BMWs
Large Black Plug x18126 1 / Blue-Black / Right Rear + output to amp (twisted with 5) 2 / Blue-Red / Right Front + output to amp (twisted with 6) 3 / Yellow-Red / Left Front + output to amp (twisted with 7) 4 / Yellow-Black / Left Rear + output to amp (twisted with 8) 5 / Blue-Black / Right Rear - output to amp (twisted with 1) 6 / Blue-Red / Right Front - output to amp (twisted with 2) 7 / Yellow-Red / Left Front - output to amp (twisted with 3) 8 / Yellow-Black / Left Rear - output to amp (twisted with 4) 9 / White-Yellow bands / I-bus? 10 / White-Brown / Mute from phone? 11 / White-Green / ? 12 / Brown / Ground 13 / White / Remote on-off to amp 14 / Grey-Red / Dash illumination (dimmer) 15 / Red-Green / +12v from battery (not switched) 16 / Violet-White / +12v from ignition (ACC and RUN) small white plug x13598 Pin No. / Wire Color / Function 1 / / No function 2 / White-Brown / Audio common from 6CD player 3-7 / / No connection 8 / White-Red / Audio Left Channel from 6CD player 9 / White-Blue / Audio Right Channel from 6CD player 10 / / No Connection 11 / NAV / TV Audio + 12 / NAV / TV Audio - NEW Small black plug: x13649 plug Pin No. / Wire Color / Function 1 / Tape left + 2 / Tape left - 3 / Left Connection for AUX Input 4 / Right Connection for AUX Input 5 / NAV / TV Audio + 6 / White-Black / Phone audio + Positive 7 / Tape right + 8 / Tape right - 9 / No connection 10 / AUX Input Ground 11 / NAV / TV Audio + 12 / Brown-Black / Phone Audio - Groundv |
08-22-2008, 01:55 PM | #10 |
2295
Rep 13,001
08-22-2008, 01:58 PM | #11 |
2295
Rep 13,001
08-22-2008, 03:38 PM | #13 | |
2295
Rep 13,001
So that photo above will do for all. |
08-23-2008, 06:33 AM | #15 |
Spaniard member
Rep 197
So there's no way to know if that HU will fit in my car (base European sound)?
08-23-2008, 08:39 AM | #16 | |
2295
Rep 13,001
I don't know how specifically the dealer reprogram a OEM HU to output either analog or digital, but the capability is there. |
08-24-2008, 02:46 PM | #17 | |
Spaniard member
Rep 197
08-24-2008, 03:38 PM | #18 |
2295
Rep 13,001
There's only one way of testing this... get it and see what happens. I don't know if by itself will automatically adjust to the specific outputs of your system or it will require dealer progarmming for the adaptation, but the unit is capable of both kind of outputs.
08-24-2008, 04:00 PM | #20 |
Rep 5,984
You need to program the car.
Tell the car you have option 663 (professional) and no hi-fi or Logic7 and you will get standard audio out. Once that is programmed you can then code the radio, so you can tell the radio you have aux, cd changer etc. What are you trying to do?? Upgrade from the business to the prof. radio?? You want to find one that has come from a car with no hi-fi upgrade, and with the same options as yours, so aux input if you have it and cd changer if you have that. I have one that is coded for aux, bluetooth and OBC, but no USB input. It is, and this is the important part, also coded for a car with no audio upgrade, so it will be completely plug and play. How much are you wanting to pay for one?? I was going to keep it, in case I ever need to put it back in, but could have my arm twisted. |
09-10-2008, 08:16 AM | #22 | |
Rep 105
I think in the oem system the PDC signal is mixed into the high level lineout from the radio, and the level of this signal is not adjustable durch the radio volume. Or, the PDC signal is mixed into the amp to speaker wires? In this case I should still have the PDC signal even if my amp is turned off, but I haven't tested it. Because I am planing with a new HU CDA-9887R, I have to consider how to setup all the oem functions with the 9887R. |
