TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Suspension drop and camber increase for track days
      01-24-2018, 11:15 AM   #1
minaret
Drives: 2008 E91 ZSP
I have M3 LCA and TCK front camber plates/coil-overs. At present ride height, I can't get more than -2.75 front camber for track days. How much suspension drop would increase front neg camber to at least -3.0? FWIW, I get alignments after suspension changes.
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
      01-24-2018, 11:17 AM   #2
bbnks2
Drives: 135i N55
Probably need close to 1/2" drop
      02-06-2018, 02:57 AM   #3
Dowdogg
Dowdogg's Avatar
37
Drives: LCI 335i E90 Space Gray
I have only TCK camber plates. My camber in the front is -3.5. You need to drop quite a bit I’m assuming, I have no wheel gap in the front. From the ground to the lowest point of my front bumper is around 4.0 inches.
      02-09-2018, 08:08 AM   #4
feuer
feuer's Avatar
Drives: wife crazy!
I'm on BMW yellow performance springs so is minimal drop and can get -4.0 with Ground Control camber plates in combination with m3 arms.
      03-20-2018, 09:48 PM   #5
minaret
Changed caster slightly to center strut/shock adjuster in shock tower opening. Plenty of camber adjustment now.
feuer4275.50
      04-01-2018, 10:40 AM   #6
Mistajay
Mistajay's Avatar
29
Drives: 335i
With the ground control camber plate i tough -4.0
That's the best camber set up for HDPE... But on the street it's not really good...
      04-19-2018, 10:43 AM   #7
minaret
"That's the best camber set up for HDPE... But on the street it's not really good..."
Since the caster adjustment, my minimium camber is -2.2. Will probably remove my M3 LCA just to have street-friendly camber during summer travel months.
      05-04-2018, 11:36 PM   #8
r4dr
172
Drives: various BMWs
-2.2* shouldn't be horrible on the streets. Keep in mind the M3 control arms also help you lose the fluid-filled bushing.
