2010 2011 BMW 5 Series Forum F10 H&R Springs and 20" Verde Wheels FIXED! |
01-26-2018, 03:35 PM | #1 |
Rep 58
Update: Job completed ..any suggestions should I black out chrome?
anything else? The ride quality of the Nankangs for me is what I expected for the price, a little bit of road noise but they ride smooth and I am happy with them. hopefully the springs will settle a little more. as far as the springs, the ride is slightly "tighter" and I can feel the difference with the handling and overall ride. Of course the wheels and tires come into play here as well. HR's took a total of 3.5 hours to install and I will try to do a write up later if I have time. So I have a 2014 528i Callisto Grey(B64) or as my wife calls it "poop Green" and I am going to do some upgrades.. will post pics in 2 weeks 20x9 Offset 35 front with 245/35/20 Nankan NS 20 20x10.5 Offset 42 rear with 285/30/20 Nankang NS 20 Edit:Added pic of the wheels I ordered H&R lowering Springs Chrome delete around window trim any suggestions or ideas welcome the e90 is my sons car in the pic. Last edited by mejori; 02-13-2018 at 03:22 PM.. Reason: UPDATED PICS |
01-26-2018, 04:04 PM | #2 |
Rep 10
Do you have Adaptive Suspension?
If you do...I recall seeing a pretty good buy for H&Rs w/Adaptive Suspension from a fellow forum member on here. Haven't seen it come up recently, but I know I saw it like a month ago. Might be worth a look see. |
01-26-2018, 04:06 PM | #3 |
Rep 58
I do not .. but I can get the HR's through my job for $250 which is cheaper than I can find online. thanks for info though
01-26-2018, 04:11 PM | #4 | |
Rep 10
Here's the link I was referring to. http://f10.5post.com/forums/showthread.php?t=1430261 |
mejori26.00 |
01-26-2018, 09:28 PM | #5 |
Rep 182
Just fyi. Eventually, the shocks will go because the factory set up is not rated for the H&R springs. My personal opinion is to do coilovers. Therefore, when it occurred you don't have to go back and switch it up again. But if you're on a budget it is not a bad option. Good luck!
mejori26.00 |
01-27-2018, 07:00 PM | #6 |
9159
Rep 14,522
what color choice are you going with the wheels?
mejori26.00 |
01-28-2018, 05:13 AM | #7 |
Rep 58
01-31-2018, 04:32 PM | #8 |
Rep 58
Fronts arrived woohoo.. tomorrow the rears, tires and H&R springs will be here
springs arrived!! Rears have been delayed hopefully next week I will be able to post pics
Past And Current whips!
http://f10.5post.com/forums/album.php?albumid=12002 Last edited by mejori; 02-04-2018 at 05:56 AM.. |
02-06-2018, 01:20 PM | #9 |
Rep 58
FYI
I installed the right front spring on my lunch and it took me about 45 minutes to do. I will do the rest after work today.. I work at a dealer and have access to air tools and spring compressor. by no means am i a technician..
http://f10.5post.com/forums/album.php?albumid=12002 |
Ickdeep5720.50 |
02-07-2018, 02:13 PM | #10 |
Rep 58
here she is all cleaned up..
TJBentley135.00 |
02-07-2018, 03:10 PM | #11 |
9159
Rep 14,522
Wow! That turned out pretty damn SWEET! The color combo works well. Too bad you can't drop the front another inch but the rears sit perfect.
Now just to shadowtrim the windows and side marker and black Double Slat grills
mejori26.00 |
02-07-2018, 03:34 PM | #12 | |
Rep 58
PS your car looks badass!!
lsturbointeg9158.50 |
02-07-2018, 06:29 PM | #13 |
Rep 272
Hey got 2 questions for you:
What brand wheels are those? Which model H&R springs did you get?
2000 E46 330i | 2007 E92 335i | 2014 F31 328i X-Drive Sport Wagon | 2019 G30 530e | 2022 G05 X5 45e
02-07-2018, 08:01 PM | #14 |
Rep 58
@ichibanb18c
the sport spring 28947-1
http://f10.5post.com/forums/album.php?albumid=12002 Last edited by mejori; 02-08-2018 at 04:22 AM.. |
02-08-2018, 10:07 AM | #16 |
ZEROdoubleZERO
228
Rep 659
Wheels and offsets look good, no poking out in the rear. The springs don't look like they did much you still have a huge gap up front, hopefully they settle. Did you measure the ride heights front and back before and after the installation as instructed by H&R per the install sheet?
mejori26.00 |
02-08-2018, 10:25 AM | #17 | |
Rep 58
install sheet?? I did not measure the height since I was going from 17" factory wheels to a 20" I did not think it would make sense.. yes I am hoping the front "settles" because it is a big gap. I will post pics in a couple of weeks to see if there is a difference. Is there really anything that would cause the ride height to stay the same or not lower at all?, the spring are significantly shorter than the OE and everything was aligned properly (springs are seated correctly on top and bottom) at installation.
Ickdeep5720.50 |
02-09-2018, 08:40 AM | #19 |
Rep 58
I think tomorrow I will take apart the front to make sure all is correct. I remember now that when I put the front struts back in I had to turn(twist) them to align the link bolt hole properly and cant help thinking that the spring may have twisted up on the insulators.. but hopefully it is just a "settling" issue.
02-09-2018, 11:16 PM | #21 | |
9159
Rep 14,522
02-10-2018, 07:15 AM | #22 |
Rep 58
Yea i know .. luckily I have technicians at my disposal
although I did the springs on my own .. I don't mess with the alignment machine I'm just going to take the wheels off and see if the springs are seated properly.
