XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      05-30-2008, 09:36 PM   #1
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
Thumbs up Oil Cooler on X6
I honestly think that BMW did an excellent job building X6.
Placing Oil cooler right behind the left fog light was a great idea ! Now the air can flow right through it , not like on my e92. I wish they would do the same thing on 335's ...
      06-02-2008, 07:54 AM   #2
ALMO7TRF
Drives: bmw323i-White-2008
Thanks man for posting this... can you explaine to me why it is good to have the cooler
behind the fog lights?????
FYI,
i saw this in the MB C63 AMG
      06-02-2008, 08:22 AM   #3
Palbay
Palbay's Avatar
Drives: 2007 BMW X3
FYI,
The oil cooler is basically a small radiator.Needs fresh supply of cool air at speed to cool oil ( the pictured X6 is the TTI6-Oil temps in this particular engine have been on the high side w/o the oil cooler).The reason it's behind the fog lamps.....a good place to receive cool air.Thanks! PalBay
      06-02-2008, 11:44 AM   #4
KJ
32
Drives: 2008 E92 M3 - Alpine White
Also, chipped 335i's work best with an upgraded oil cooler (although it is not REALLY required). Hopefully, this means a chipped X6 will not need an upgraded oil cooler because of it's good placement.
- KJ
      06-02-2008, 12:25 PM   #5
SayyaaF
Drives: Porsche Panamera 4S
Any performance numbers for your car yet doba_s ?
      06-02-2008, 01:16 PM   #6
chuck92103
chuck92103's Avatar
91
Drives: 2011 535i
- KJ
Chipping will void your warranty.
2011 535i
2008 VW GTI
      06-02-2008, 01:56 PM   #7
archwerks
20
Drives: x6 3.5i VR
archwerks
thanks for foto of oil cooler. I noticed the same feature on 1 car but didn't have my camera. Thought it would be the same on all 35i's. The only model available @ dealers. But I've not seen this vent open on others since seeing ur post. The cars i've looked since have the vents blocked on both sides w/ solid black crisscrossed plastic.
What model & w/ what opts have this vent open?
Thanx.
      06-05-2008, 11:11 PM   #8
doba_s
doba_s's Avatar
Thanx.
I have all the options that you can get on this car, but even the base model should have OC ...
I think the new V8 version will have 2 oil coolers, one on each side.
      06-05-2008, 11:13 PM   #9
doba_s
doba_s's Avatar
I gained around 50+ hp ... now working on getting custom exhaust system for it ...
      12-08-2009, 08:47 PM   #10
Rac10000
29
Drives: 981 Cayman S
Sorry to bring this thread back from the dead, but I can't find the answer to my question.
Do all X6's have oil coolers behind one (35i) or both (50i) of the fog ducts?
I could swear the X6 35i that I saw at the dealer a few weeks ago had both ducts behind the fogs blocked off. But some people have said the 35i has one cooler behind one of the fogs and the 50i has coolers behind both of the fogs.
Can someone please confirm? Does it have anything to do with the "Sport Package"?
      12-09-2009, 09:01 AM   #11
Kojak
Drives: 535i M-Sport
The 35i oil is cooled by coolant fluid from the radiator. Its oil cooler is the small silver assembly at the top front center of the engine block just below and to the left of the plastic air intake tube. Hopefully, this redesign relative to the 3 series means they are adequate and don't need upgrade. The mechani told me that the 501's have coolers behind the fog lights but I don't remember if its one or both of them.
      12-09-2009, 09:11 AM   #12
NYCGarbagePrince
Drives: X6 50i
Mine was smoking this morning for like 10 minutes after I parked it at work. Cold day and a ton of precipitation. I tried to take a video of it but it looked terrible... and you couldn't really see it.
      12-09-2009, 09:29 PM   #13
Rac10000
29
Thanks, guys!
Maybe some other owners could chime in as well. Maybe it has changed from the 2008-2010 model year?
It's not really a big deal ... just curious ...
      12-10-2009, 11:49 AM   #14
archwerks
20
Drives: x6 3.5i VR
Hot oil temp?
Pls. elaborate on "smoking"..
Where? at the oil cooler behind fog lites??
What would cause it to steam up ?? HIgh humidity & cold ambient temp?
What was engine oil temp on the gauges?
I checked onto it '08 &'09's 3.5i w/ sport pkg have the xtra oil cooler behind drivers' side fog lites. 5.0i's all have the cooler as well.
Not sure whether 2010's 3.5i without the sport pkg. would come with it now.
Can someone w/ 2010 3.5i with or without sport pkg. confirm?
(I'll have to check w/ dealer later.)
      12-10-2009, 08:07 PM   #15
Rac10000
29
Ahh, okay. I am almost positive the non-sport 35i that I saw at my dealer did not have an oil cooler behind either of the fog lights. I'm not saying that there was not an oil cooler at all, it just wasn't behind either of the fogs ... both ducts were blocked off.
Can someone please confirm about a 35i with the sport package?
      01-08-2010, 11:02 PM   #16
stanleyfalls
Drives: 2010 X6 35i
I have a 2010 35i built in late December with Sport Package but without the new Performance Upgrade option and it does have the fluid cooled oil cooler (manufactured my Modine who is known for these applications) mounted to the top front of the engine and both fog light ducts are blocked off. But, let me add something that is a real mystery on this subject... when I picked up my vehicle on new years eve, I saw a loaded up 2010 35i that had Sport Package AND the new Performance Upgrade with the drivers side air duct open. At the time I didn't think to pop the hood and look for the engine mounted oil cooler....So, I can only imagine the open driver side vent is a result of the new Performance Upgrade? I looked on the window sticker for anything referring to a trailer hitch or towing option and there was none. Anyone who can shed light on this please do it's got me very curious.
      01-09-2010, 12:02 AM   #17
LANDLORD
Turbo Engines are Fun
LANDLORD's Avatar
Drives: 2010 X6M Monte Carlo Blue
The X6M has a huge oil cooler on the left side and the right side is the also huge water cooler for the fluid that goes to the two water intercoolers for the turbochargers. My oil temp goes to just under 210 degrees and stays there, so there must be some kind of thermostatic control to keep the oil temperature at this optimum temperature. The M has the oil temp gauge at the bottom of the tach. I am not sure about the gauges on the other models. The water intercoolers seem to stay pretty cool also. I want to check them after a full throttle pass to see if they seem at all elevated in temperature.
I would love to get a hold of more detailed images of all the systems on the car, and especially the engine. I need to go and buy the mechanics some doughnuts some time and get a look at their service information. There is so little room under the hood I have not been able to figure much out. The pictures I have are somewhat helpful, but don't show nearly everything. One thing I learned from the pictures is that the M also has piston crown oil squirters which is a very nice thing to have. Look for the little tube that shoots oil to the underside of the piston.
      01-09-2010, 02:06 AM   #18
archwerks
20
Drives: x6 3.5i VR
Col. Klink says, "Achtung! Kooler tvventy daze, Vor Hogan!""
BMW probably changed how they equipped the cars since the 7RR perf pkg came out, purely for profit. They used to have the foglite oil cooler when u order the sport pkg in '08 in Canada. It's my guess they nixed it now unless u order the 7RR.
210 o F is 98 o C, that's pretty good my 3.5i w/o the factory cooler runs at betw'n 100-110 o C in city traffic.
One pass is hardly any stress on these engines. High speed in the summer in Death Valley or over black Georgia asphalt would be the test.
      01-09-2010, 08:30 AM   #19
stanleyfalls
Drives: 2010 X6 35i
I agree it must the addition of the 7RR Perf Pkg that caused the 2010 35i with Sport Pkg to have the open driver side fog light grille. My curiosity is whether or not the new design engine mounted Modine oil cooler is also installed or if BMW decided the earlier version air to air oil cooler alone is better suited to performance driving. My oil temp in normal driving sits at 220on the guage. It seems unlikely that the engine would have both oil cooler designes but If anyone with a 2010 Sport Pkg with 7RR Perf Upg can let us know if they have both oil cooling units it would clear some of this up. One other thought is where is the transmission oil cooler? I see in the main grille there is a skinny unit at the top front of the main radiator which I would think is for A/C and then the larger unit at the bottom front of the main radiator, is this for the transmission?
      01-28-2010, 04:28 PM   #20
TexasinDC
Drives: X6
Hi All!
I just signed up, this is a great forum! I've learned so much in the short time that I've been a lurker. I just ordered a X6 3.5i (Tech package, Premium pack, Rear seat climate pack and heated front seat option, (My wife insisted,,,)) Pretty basic set-up. I am curious as to whether anyone has had a trailer hitch installed and what the cost was. I did a search, and came across some old threads, which were helpful, I'm just wondering if anyone has had one put on recently and what was involved.....Thanks!
Texas-
      01-29-2010, 12:25 AM   #21
doba_s
doba_s's Avatar
those are good pictures ... post some more if you get any
      02-19-2010, 02:33 PM   #22
Rac10000
29
Bump!
Any more 2010 35i drivers care to let us know about oil cooler placement or lack there of on your setup?
No Sport Package / No Performance Package = ?
Sport Package / No Performance Package = fluid cooled oil cooler mounted to the top front of the engine and both fog light ducts are blocked off (post #16)
Sport Package / Performance Package = ?
