2010 2011 BMW 5 Series Forum F10 F10 strut nut socket recommendations |
02-07-2018, 01:00 PM | #1 |
Rep 68
I'm going to attempt ACS springs install this weekend. Any recommendations on a strut nut socket or a technique?
Is it a 18mm? What is the torque spec for the strut nut? The previous torque stated are incorrect. Here are the torque specs based on https://www.newtis.info/tisv2/a/en/f...truts/1LHsblhj Wheel bolts - 140Nm (103 ft-lb) Front springs: Tie rod bolt at strut - 45 Nm (33 ft-lb) Upper control arm to swivel bearing - 56 Nm (41 ft-lb) Bottom strut (1 bolt) - 90 Nm (66 ft-lb) Top strut (3 bolts) - 28 Nm (21 ft-lb) Spring strut to support bearing - 34 Nm (25 ft-lb) Rear springs: Top strut (3 bolts) - 28 Nm (21 ft-lb) Bottom strut (1 bolt) - 250 Nm (184 ft-lb) Spring strut to support bearing - 27 Nm (20 ft-lb) Last edited by louieeg; 02-08-2018 at 12:57 PM.. |
02-07-2018, 03:02 PM | #2 | |
Rep 58
https://www.newtis.info/tisv2/a/en/f...truts/1LHsblhj I think it is an 18mm, I used a swivel impact socket to take it off once it the spring was secured on the spring compressor. And used a "stuby" impact wrench.
Past And Current whips!
http://f10.5post.com/forums/album.php?albumid=12002 |
02-07-2018, 03:24 PM | #3 |
Rep 58
on the front I found it easier just to remove the bolt in the pic using an inverted
torx socket. FORGOT!! be careful of the brake lines and sensors when you remove this..use a bungee cord to keep it suspended. I was able to remove one strut in lees than 15 minutes taking my time. credit for image :http://f10.5post.com/forums/showthread.php?t=628336 if you have any other questions let me know
http://f10.5post.com/forums/album.php?albumid=12002 Last edited by mejori; 02-07-2018 at 03:39 PM.. |
02-07-2018, 04:05 PM | #4 | |
Rep 68
I think I found it: https://www.newtis.info/tisv2/a/en/f...struts/5hifyjl 2AZ Support bearing flange to spring strut shock absorber - 34 Nm |
02-07-2018, 04:32 PM | #5 | |
Rep 58
anytime brother.. if you have any other questions ask away.. post pics of your car if you can!!
02-07-2018, 07:11 PM | #6 | |
Rep 68
The torque spec is: 6AZ Upper wishbone to swivel bearing - 56 Nm https://www.newtis.info/tisv2/a/en/f...neral/B9i93KWh Last edited by louieeg; 02-07-2018 at 08:55 PM.. |
02-07-2018, 09:19 PM | #7 |
Rep 68
Here is how the car sits currently. Hoping to close that wheel gap soon.
02-07-2018, 10:59 PM | #8 |
9159
Rep 14,521
you also need a star key for the rears. i forgot what the size was but it's when you need to get access through the rear shelf to get to the rear shock nuts if i recall
02-08-2018, 04:26 AM | #9 | |
Rep 58
this post helped guide me for the install http://f10.5post.com/forums/showthread.php?t=628336
01-08-2019, 11:39 AM | #10 | |
Rep 8
The hub will come off easily once undo the bolt? any tool or technique needed? |
