02-28-2018, 02:52 PM | #1 |
95
Rep 339
Onboard footage S55 crank hub failure
The title pretty much speaks for itself
02-28-2018, 03:26 PM | #4 |
515
Rep 554
Drives: 2018 M3 ZCP 6MT
I thought that was maybe a money shift
02-28-2018, 07:27 PM | #10 | |
BMWphile
93
Rep 132
I’m also 90% sure this is a car with iDrive 4.0, therefore most likely an early car. Those are clearly Rolls-Royce gongs, which are identical to those I coded on my 2016 F10 550i with iDrive 4.0. I’m not sure if the Rolls-Royce gongs are different in iDrive 5/6, I’d have to code my F80 to be sure. EDIT: Zoom in on the iDrive, it’s clearly 4.0, therefore pre LCI and potentially pre-crank hub bed change. Wasn’t a complete solution but I haven’t heard much since. Last edited by TanzaniteBlue; 02-28-2018 at 07:51 PM.. |
FSociety3811.50 |
03-01-2018, 05:39 AM | #12 |
Rep 235
03-01-2018, 06:37 AM | #13 |
1600
Rep 1,763
I would be shocked if its covered under warranty with a flash tune and ethanol.
03-01-2018, 08:23 AM | #14 |
Rep 4,632
Was the engine taken apart and it found to be a crank hub failure or this just a guess?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
03-01-2018, 08:24 AM | #15 |
Rep 6,103
Thanks for posting.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
03-01-2018, 08:54 AM | #17 |
95
Rep 339
Engine is in the process of being taken apart, this is a very educated guess.
Codes where something like: Intake cam position signal implausible Exhaust cam position signal implausible High pressure pump position sensor signal implausible Frankly, there is a 99% it is crank hub. |
FSociety3811.50 |
