TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > FS: Kicker 400.1 AMP
      03-09-2006, 10:38 PM   #1
Artz 330
Drives: Z4M, 335i, 135i
2006 330i  [0.00]
Arrow FS: Kicker 400.1 AMP
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
I have a 400.1 Kicker AMP I am selling. I upgraded to a 600.1 by kicker and have no use for the 400.1 anymore. The amp is $279.99 NEW from the Store.
Ill sell it for $150.00 OBO.
Let me know if interested. Local to NJ you can pick it up or I can take it to you. Out of state You pay shipping.
Specs.
Kicker Mono Subwoofer Amplifier (KX400.1)
Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
Power output: 200 watts RMS at 4 ohms or 400 watts of peak power at 2 ohms.
Protection Circuitry: Protects against short circuits, overloads, heat and reverse polarity.
Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
Low-pass filter: Filters out all of the low frequencies and keeps them flowing to your sub for maximum bass response.
MOSFET circuitcity: Runs cooler and more efficiently.
Remote bass control: Place the controller on your dash or console to change the amount of bass going to your subwoofer without having to leave the driver's seat.
Removable endkaps: Conceals and protects the wiring on the ends of the amplifier. They can be painted to match the inside of your car for a cool, custom look.
Power kit and RCA cables required.
KKR 04KX4001
• 200 watts RMS at 4 ohms
• Low-pass filter
• Protection circuitry • Speaker-level & RCA inputs
• Remote bass control
Price was: $299.99
You save: -$20.00
Learn more about Kicker Products
You pay: $279.99
      03-10-2006, 06:11 PM   #2
Artz 330
2006 330i  [0.00]
bump
      03-11-2006, 11:27 AM   #3
Tiffz MiniS
Artz Girl
9
Drives: 2007 Sapphire Black 335i
Originally Posted by Artz 330
bump
nobody has wrote
      05-31-2006, 06:02 PM   #4
thd13
thd13's Avatar
46
Drives: A07 330i
2006 330i  [0.00]
I know this thread is old as dirt, but any chance you still have it?
      05-31-2006, 07:14 PM   #5
Artz 330
2006 330i  [0.00]
I sold it awhile back... sorry... are you doing a setup in your car?
      05-31-2006, 08:06 PM   #6
thd13
thd13's Avatar
46
Drives: A07 330i
2006 330i  [0.00]
I'm trying to; any suggestions? I'm currently looking at Infinity Kappa Perfect 10.1 or 12.1, depending on how little space the 12.1 will take. And I was going to pair it up with a Rockford Fosgate P4001 amp bridged @ 4 ohms. I was going for something modestly priced with decnet thump for the Logic 7.
      05-31-2006, 10:10 PM   #7
Tiffz MiniS
Artz Girl
9
Hmm well I can tell you that the Rockford is junk. Lotta people I know have used it and its junk. I would do something simple since you are going to be using the stock head unit. If you want something nice that is adjustable to your liking I would go with a Kicker set up.
2 10" Comp VR's in a custom built box. (I can give you the specs to build a nice box) Also if you want deeper bass sound, buy the yellow wall insulation from home depot and put it on the backing inside the box.
What you have to take into consideration is the Trunk. Its pretty large. In a larger trunk you need more power because of the area. So something like a Mini Cooper a 200 Watt amp is sufficent enough with 1 sub. But this would not work in the BMW. Also do you have the rear fold down arm rest? This is good if you do. The trunk is so well insulated in the BMW it takes power to get sound into the cabin of the car.
So I would do something simple. Either go with a Kicker Amp or do a nice Infinity Amp. A mono amp is good choice in keeping things simple. I would personaly to get nice quality go with A Kicker Mono Channel Class D Amplifier (06ZX7501) its $499.99 but the power output is 375 watts RMS at 4 ohms or 750 watts of peak power at 2 ohms.
If you are running 4ohms 375watts will get you plenty of bass in the car.
Ill put up a pic off my wiring and I am running at 2Ohms around 325 watts and I have very nice sound. And its all adjustable also through the Stock head unit with the bass option. The logic 7 works very well with this setup.
My setup when I tested it is running 2ohms. I am sure tho if you run 2 subs at even at 2 ohms you can get an amp that is rated between 300-400 Watts RMS continuious you can save yourself some money. Although this amp when running at 4 Ohms will be alot less like 150 or so. So you just have to watch what you buy.
If you want a saturday and sunday project. Im in NJ, if ur not to far into MD, maybe you can swing by for a day and we can hook you all up with a nice system.
Good Luck~
EDIT: This is Artz 330
      05-31-2006, 10:35 PM   #8
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
do you still have space in your trunk? i want one but still want to use my trunk. can i see your setup?
      06-01-2006, 08:50 AM   #9
thd13
thd13's Avatar
46
Drives: A07 330i
2006 330i  [0.00]
Good Luck~
Thanks brotha!
I would love the specs of a custom box, the only problem is, I would still like to use my trunk. Or at least most of it. My Maxima had a huge box with 2 12" and it took up all of the space. I'm trying to avoid doing that, hence going with 1 10". I was looking @ the Infinity 611A amp, may be a bit overkill for one sub, but that might just give me enough reason to get another 10".
If you wouldn't mind, I would love to take a trip up there to NJ. What part do you live?
      06-01-2006, 10:03 AM   #10
Artz 330
2006 330i  [0.00]
Thanks brotha!
hey the Ref611amp is a very very good choice. We would just have to take a look at the power output closely and match it up to a nice set of subs. Remember the Smaller the sub. example 10" over a 12 inch, the sound is cleaner and chripser. I am from Mercer County, in NJ right near Princeton.
      06-01-2006, 10:06 AM   #11
Artz 330
2006 330i  [0.00]
Yea I have plenty. I posted this a while back
http://www.e90post.com/forums/showthread.php?t=18302
I dont know if you saw that or not. I didnt take a pic of the final thing. But if you look at the positioning of the sub. You will see I have plenty of trunk space left.
      11-15-2012, 11:52 PM   #12
Cristian Cemophora
Mister E92
Drives: White BMW 328Xi
2007 BMW 335i  [0.00]
1989 Camaro RS  [0.00]
Hey Artz I was wondering if you could help me a bit with a system. My car recently flooded in the hurricane so i'm buying an 07 328xi and as soon as i get it i want a system in it. I live in bergen county. north jersey so if you can please pm me
