03-27-2018, 05:40 PM | #1 |
BMW obsessed
9546
Rep 10,844
IND | F90 M5 Painted Rear Reflector | Installation Procedure
Step 1: Remove the two 8mm bolts securing the plastic underbody panel to gain access to the rear reflector area. Step 2: Pull the underbody panel aside and reach up behind the rear reflector. Squeeze the reflector tabs one by one and push them outward to release them from the bumper. Step 3: With all three tabs released, you should be able to remove it from the bumper. Step 4: With uniform pressure, insert the IND F90 M5 painted rear reflector into the factory location. Step 5: Insert the two factory 8mm bolts by hand then tighten.
