Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > What offset am I looking for in Wheels and Widest
      06-20-2005, 06:26 AM   #1
RachelS
Drives: 2006 325i
What offset am I looking for in Wheels and Widest wheel I can use.
What is best
look at this page
http://the*******change.com/products..._18_index.html
will the m5 work
      06-20-2005, 10:15 AM   #2
ogrady
ogrady's Avatar
88
Drives: AW 09 335
Yea the M5-look wheels should work. They're 35 offset which is ok for the E90. Someone correct me if I'm wrong plz.
      06-20-2005, 05:25 PM   #3
RachelS
Drives: 2006 325i
Can I use a 8-1/2 ifront 9-1/2 rear ?
      06-20-2005, 09:14 PM   #4
res_ipsa
res_ipsa's Avatar
14
Drives: 325i SparkGraphite
9.5 rear sounds kinda big. Maybe marke90m3 or some other wheel expert can help out with this question.
      06-20-2005, 10:24 PM   #5
Mark
Administrator
Mark's Avatar
6698
Drives: 1M
you can easily fit 9.5 in the rear. Dont forget that the E90 sedan uses the same fitment as the previous M3 does or even close to the 5 series in the rear... which means wide wheels and deep dishes are possible in the rear of the E90.. 9.5 is not a problem at all, 10" should be doable also.
      06-21-2005, 04:30 PM   #6
RachelS
Drives: 2006 325i
thanks
what offset
      06-21-2005, 07:16 PM   #7
Mark
Administrator
Mark's Avatar
6698
Drives: 1M
Originally Posted by RachelS
thanks
what offset
9.5 with a +35-40 offset seems to be what the tuners are using for now.
      06-29-2005, 03:02 PM   #8
RachelS
Drives: 2006 325i
Mark
I think I am going with 18 x 9 40 offset Rear 18 x 8 40 offset front
anyone think this is OK....
      06-29-2005, 10:38 PM   #9
Mark
Administrator
Mark's Avatar
6698
Drives: 1M
Mark
that is fine, but it wont look as wide and will sit inside your fenders a little bit probably, it depends on what look you are going for
but it will fit just fine
      06-30-2005, 06:55 AM   #10
RachelS
Drives: 2006 325i
So the higher offset pushes the wheel inside the well more. I would like the even with the fender.
thanks
may 18 x 9 all around would be OK
if I did that, could I use 225's in the front and 255's in the rear with 18 x 9 all around?
      06-30-2005, 09:21 AM   #11
Mark
Administrator
Mark's Avatar
6698
Drives: 1M
thanks
yeap the higher the offset number, the more it will push the wheel inside the well.
you can do 18x9 all the way around depending on offset (18x9 40 should work) but you cant fit 225 on the front 18x9 wheels.
235 could fit with a stretching, 245 would definatly fit on a 9" rim tho
      07-01-2005, 07:37 AM   #12
RachelS
Drives: 2006 325i
Mark
would a 255 on the front and rear look awefull
      07-01-2005, 09:18 AM   #13
Mark
Administrator
Mark's Avatar
6698
Drives: 1M
Mark
No, IMO the wider the tires, the nicer the car looks, so I think 255 would look great ! but something like taste is all subjective
      07-12-2005, 07:47 AM   #14
SleeprM3
Drives: Cosmos E36 M3/4
9 x 18, 40-mm offset all around with 255/35-18?
I'd like to run 9 x 18 with stock 255/35-18 RE050A Bridestone runflats all around. The only wheel I could find is BBS RE from Tire Rack. Offset is 45-mm offset.
http://www.tirerack.com/servlet/Call...pecial=Pricing
Two questions.
1. Will the BBS RE rim work with the Bridgestone RE050A runflat?
2. Will the 45-mm offset all around work?
Thank you very much!
GREAT FORUM!
BTW, I've heard rumors of the 335i. I was going to order a new 330i, but plan to wait for the 335i (twin turbo)
      07-12-2005, 02:19 PM   #15
E90Fleet
South Africa
1311
Drives: BMW
For a run flat to work properly you need a wheel with a EH2 hump
The EH2 hump is a extra ridge inside the rim that prevents the sidewall from jumping off the rim when the wheel is flat
The 335i is only expected this time next year in europe
      07-12-2005, 10:03 PM   #16
SleeprM3
Ahh, so I have to find out if the BBS RE has the EH2 hump? Dammit. The Euros always get the good stuff from BMW
I guess I'll place my order for the 330i then
