      04-01-2018, 10:53 AM   #1
stbm5
Drives: 2018 M5 DG
coating
yesterday i did full decon - iron-x followed by glide/nanoskin then followed by eraser; today will apply cquartz uk and cquartz gliss! then pray its not raining tomorrow. sometime later i'll coat the wheels and for the record I HATE CLEANING WHEELS! i wish i had curing infrared light set up.
      04-01-2018, 07:50 PM   #2
stbm5
Drives: 2018 M5 DG
that was a chore. my 1st time using cquartz and wishing i had used optimum gloss coat instead. optimum is a much quicker process, less time wiping off, & faster flashing.
      04-02-2018, 09:00 PM   #3
stbm5
Drives: 2018 M5 DG
One coat carpro cquartz then top coat of gliss. Just iPhone pic
      04-02-2018, 10:27 PM   #4
basque76
Not a BMW Genius
basque76's Avatar
Drives: 12' BMW 535i (dec.), 19' M5
I’ll take it! Gorgeous.
      04-02-2018, 11:02 PM   #5
stbm5
Drives: 2018 M5 DG
thank you! a lot of work. i wasn't expecting to polish it but i had to. not sure if dealer quick waxed it but when i was trying to prep it i was getting smudges. polishing adding another couple hours. prob the nicest it will ever look!
      04-04-2018, 07:48 PM   #6
ljdavis
Drives: BMW G30 M550i
What made you decide on Cquartz? I did a full paint correction on my M5 before applying two coats Gyeon Mohs. I haven't had a chance to really see how the product performs. I tried a couple of tests and it seems to be performing really well. How is the cquartz performjng?
      04-04-2018, 09:20 PM   #7
stbm5
Drives: 2018 M5 DG
i don't have a good reason for choosing cquartz and if i had to do it again i'd use Optimum Gloss Coat because its a faster process. i assume that these products are all pretty similar... based on my visual memory i think the look of the cquartz w/ gliss and optimum gloss coat are pretty much the same.
      05-15-2018, 05:33 PM   #8
Cacou
13
Drives: F90
Anyone has experience with Gyeon Pure? I'll be picking up my car through the European Delivery and I want to see if there is a coating I can quickly apply that can protect my car while I'm there and during transit back from Germany.
I need something that I can apply in an hour or so in a single step.
Thanks.
      05-16-2018, 10:44 PM   #9
stbm5
Drives: 2018 M5 DG
The issue isn't the time it takes to apply. You could very easily put a number of coatings on in an hour. Problem is you need to prep the surface then it needs to cure. I think the minimum time to accomplish all that would be 12-15h.
