BMW M5 F90 (2018+) General Forums Cosmetic Modifications    While I wait for my IND black grille...
      04-03-2018, 09:25 PM   #1
trackday96
trackday96's Avatar
155
Drives: BMW M5 CS, Porsche 911 GT3 RS
2022 BMW M5 CS  [0.00]
2016 BMW M4  [0.00]
Does anyone have a how-to on removing the double slats from the front grille? I am trying to wrap it until my IND grille comes in (on order).
I can get most of it off, but can't get these three small clips up enough to remove the inner slats. Has anyone done this successfully and could you share a few tips?
Much appreciated.
instagram: trackday.fanatic
      04-03-2018, 09:34 PM   #2
stbm5
Drives: 2018 M5 DG
does this help?
http://f90.bimmerpost.com/forums/sho....php?t=1482536
      04-03-2018, 09:56 PM   #3
trackday96
trackday96's Avatar
155
2016 BMW M4  [0.00]
Originally Posted by stbm5 View Post
Thanks. Removing the grille is not a problem (the grille pops out in seconds); removing the inner slats from the outer grille is the challenge. The number of clips on the inside is far greater than any of the previous M grilles I have seen.
      04-04-2018, 05:33 PM   #4
BG23
Drives: F90 M5
How did you go with this?
      04-04-2018, 10:37 PM   #5
trackday96
trackday96's Avatar
155
2016 BMW M4  [0.00]
Managed to remove the inner slats; however, wrapping this grille is above my skill level. Will wait for the IND grille to come in.
      04-05-2018, 02:14 AM   #6
BG23
Drives: F90 M5
Thanks - how hard was it? I ordered my grills from another place - despite advertising them as the full grills they changed it to just the outer part. They have offered to refund me (so fair play) but I am concerned this may be above my skill level. Given how easy changing the entire assembly is I was thinking of returning them and just ordering from IND.
BTW they are yet to arrive.
      04-05-2018, 06:37 AM   #7
trackday96
trackday96's Avatar
155
2016 BMW M4  [0.00]
Good luck. Removing the grilles is very easy (Open the bonnet/hood, push down on the three clips above the grille and pull). Removing the inner slats takes a bit more time, but once I had enough picks to lodge in the various grille crevices, it was relatively straightforward. Fear of breaking something was my largest concern.
Good luck!
      04-05-2018, 10:39 AM   #8
onfireX5
Drives: F90M5,F85X5M
Remove the inners in a warm room. Hot comb helps. Toothpicks help. Go in a circular pattern. Not terrible but takes patience.
      04-05-2018, 04:52 PM   #9
BG23
Drives: F90 M5
Thanks for the tips. I'll give it a go!
m5post
