BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY info #2 - parking brake handle...
      03-11-2006, 08:18 PM   #1
E24
DUBYA
E24's Avatar
Drives: 2012 328I - 6MT
Have a new handle to install. Any info on how to pull out the original and replace? Point me somewhere. Thanks again.
      03-12-2006, 01:40 PM   #2
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
oh good luck... search this topic for yerself, but my understanding is that the oem brake handle is glued on and very difficult to remove.
"Teach the ignorant. Ignore the stupid."
      03-13-2006, 04:25 PM   #3
longtran
longtran's Avatar
1431
Drives: E90 M3
2006 325i  [0.00]
no it is not glue. just pull it out like your shift knob.
      03-13-2006, 11:39 PM   #4
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
really? I'll have to gove it a try.
Hey longtran...
is there anything you havent fiddled with in your car? Yerself included?
      03-19-2006, 05:51 PM   #5
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
Yup..Longtran is right..The factory e-brake handle is super easy to remove..Just yank on it hard and it'll pull right out..I replaced mine a while ago with the ACS handle...
1988 E30 M3
Diamantschwartz/Black
      03-23-2006, 04:44 PM   #6
jjon90
jjon90's Avatar
Drives: E90
The leather cover is definitely glued to the handle! I had to take a little screw driver and pry the glued leather off the handle then give it a good jerk and off it came! When I Installed the new one (Poplar) I can see a gap because I did not glue the leather sleeve to it. Any suggestions on glue choice?
      03-23-2006, 04:46 PM   #7
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
I didnt see ANY glue at all when I removed mine..It just popped off with a little force..
1988 E30 M3
      03-23-2006, 05:18 PM   #8
jjon90
jjon90's Avatar
Drives: E90
If you look closely you can see the glue residue and little pieces of beige leather remnants still stuck!
      03-23-2006, 05:20 PM   #9
jjon90
jjon90's Avatar
Drives: E90
This is the gap I have now since I didn't use adhesive. Any suggestions?
      03-23-2006, 10:51 PM   #10
mc68386
mc68386's Avatar
Drives: '06 330i 6MT
How about putting a couple of rubber bands that are close to the beige color on there? You really just need to cover the black then no one will ever notice.
Or if that's too ghetto, go to an arts & crafts shop & find some leather or naugahide or suede of the right color and glue a thin strip in the gap.
2006 330i | Black Sapphire Metallic | Black Dakota Leather | 6SP MT | ZPP | ZSP | ZCW | Sirius
      03-24-2006, 02:55 PM   #11
jjon90
jjon90's Avatar
Drives: E90
I'm really looking more on the lines of a recommendation for a good, fast drying, strong adhesive. Anyone?
      03-26-2006, 08:20 AM   #12
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
Did you make sure that you pulled the leather boot far enough foward and made sure it "snapped" into place?...
1988 E30 M3
      03-26-2006, 06:13 PM   #13
jjon90
jjon90's Avatar
Drives: E90
Shadye90, Thanks! After carefully feeling around the upper portion of the sleeve, I could feel a metal or plastic band which I worked into the groove of the handle! My problem was, I was doing this whlie the brake was off (down position) when I pulled it up I had plenty of slack to work the ring on to the handle!!
All is well!
Thanks Again!
      03-26-2006, 06:53 PM   #14
shadye90
shadye90's Avatar
60
Drives: BMW Fanatic
All is well!
Thanks Again!
Now you go out and pimp that damn thing like it should be...
1988 E30 M3
      03-26-2006, 10:39 PM   #15
jjon90
jjon90's Avatar
Drives: E90
Yaa baby!
      11-25-2006, 06:51 PM   #16
rlc
rlc's Avatar
34
Drives: '06 E90 - '04 E85 - '16 F15d
2016 BMW X5 35d  [0.00]
2006 330i  [0.00]
2004 Z4 2.5i Roadster  [9.00]
I changed over to the Pearlescent chrome E-Brake handle. The leather boot is held onto the handle with a nylon tie wrap on the inside. Once you turn the leather inside out you can easliy clip off the old tie, pull the old handle off, and replace with the new handle (securing the leather with a new tie wrap). The whole process took about 5 minutes.
Finished product.....
More pictures of final look at http://www.e90post.com/forums/showpo...&postcount=312
      05-24-2012, 11:58 AM   #17
TGIM
Drives: 2006 330i e90
That's so sick. I'm dooo doing that... That looks easy and looks real good!
