M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > What is a sensible quote to replace pads?
      04-17-2018, 07:19 AM   #1
StefanV
Drives: BMW M2 LCI LBB DCT
I got quoted from the local BMW dealer over 500 euro (600$) just to replace the brake pads in all 4 corners, without the pads (I'll provide the parts).
Isn't that a tad too much?
      04-17-2018, 07:25 AM   #2
HODLM
HODLM's Avatar
Drives: 2018 M2/AW/6MT; '16 X5 Hybrid
I'm not sure whether the price is high / low, but the entire brake pad and clutch replacement warranty from BMW is $600. So...
      04-17-2018, 10:05 AM   #3
NOLAGUY
Drives: LBB M2
Way too much. DIY. The new calipers make it super easy to swap pads. Just youtube it and save you the money. It can be done with pretty basic hand tools.
      04-17-2018, 12:07 PM   #4
capt_and
Drives: 2017 m240i
It takes me 30 minutes to replace the pads on all 4 corners. I do it every week/every other week for the track so I've gotten very good at it. All you need is a punch, hammer, and pry bar.
M240i Racing Build
Instagram: @Capt_and
M2guru383.50
      06-06-2018, 01:39 PM   #5
alscks0414
alscks0414's Avatar
690
Drives: MY18 X3 M40i, MY18 M3 ZCP
For that money (600), you can buy better street pads front and rear than OEM pads, and purchase jack+stand+impact wrench.
Then you can save yourself money for all cars in the future for changing.
Changing pad takes about 45 min when you get used to it.
I do it in about 40 min as I change mine frequently because of tracking.
Some helpful video;
      06-06-2018, 02:34 PM   #6
ZM2
Drives: 2017 LBB M2
Quick and easy to do, but sometimes when I don’t have time before a track event (or if my car is already at the shop for other things), my race shop charges about $200.
      06-07-2018, 10:44 AM   #7
boostspoon
Drives: M2
Does your quote include resurfacing your rotors? Does it include sensors being replaced? Let’s see your estimate sheet - something isn’t adding up.
On a normal brake service, rotors are resurfaced and sensors are replaced.
      07-06-2018, 08:32 AM   #8
StefanV
I didn't get something written. I just called BMW Automobile Bavaria (biggest authorized dealer and service in Romania) and asked for the service department, I described what I want to do and he asked me if the pads are OEM or aftermarket. Then gave me the estimate...
      07-06-2018, 10:22 AM   #9
Spartan King
MOLON LABE
Spartan King's Avatar
80
Drives: BMW M2 LCI
I had my pads replaced and bedded and an axleback exhaust install done at my local shop for just over $200.00. I also provided the parts. Shop around for an honest and knowledgeable shop and you won't get screwed.
      08-20-2018, 08:43 PM   #10
AESZ4
Drives: M2
Some helpful video;
What do you do with the wear sensors when the OEM pads are out?
      08-25-2018, 10:18 PM   #11
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
I'm slow and it takes me 40 minutes to swap all pads on all four corners. That includes jack time, wheel removal, pad replacement, reinstalling tires and wheels and torquing the wheels to spec.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      09-09-2018, 07:00 AM   #12
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
You zip tie them to the brake line. You will not need them for your track pads.
rich8566608.50
      09-09-2018, 07:04 AM   #13
chief1richard
2018 M2  [0.00]
Almost nobody resurfaces rotors anymore. When taking in the time to do this, it is cheaper to buy new ones.
      09-09-2018, 07:09 AM   #14
chief1richard
2018 M2  [0.00]
I'm even slower than that. All in all it takes me about 1 1/2 hour to do it at my pace. However I just invested in a Quick Jack with my son, and that makes the process much easier.
rich8566608.50
      09-09-2018, 06:11 PM   #15
rich8566
rich8566's Avatar
Drives: M2 + Z-4
I concur
      09-09-2018, 06:20 PM   #16
rich8566
rich8566's Avatar
Drives: M2 + Z-4
That's way too much. I can do it in my driveway in 40 minutes. I don't have a lift so I jack up 1/2 of each side of the car using a floor jack and I do the front and rear on one side then I do the same on the other side. Another option for DYI is to use the front center and rear center jack points. That way you can do both fronts and then both rears each at the same time. Either way always use jack stands for safety. I would think that a shop would charge one hour of shop time to do job, but I bet they can actually do the work in 20-30 minutes since they have a lift plus they do pads on our cars every day.
m2
