04-25-2018, 05:15 PM | #1 |
Administrator
40707
Rep 21,238
BMW Reveals Some Upcoming M850i xDrive Specs. 530 HP / 553 LB-FT (with videos)
BIMMERPOST NEWS BMW Reveals Some 8 Series (M850i xDrive) Specs BMW has just revealed some official specs ahead of the 8 Series' reveal. Highlights: • New V8 Turbo Engine VIDEO Full Press Release: Munich. In the final stage of the series production development process, the new BMW 8 Series Coupe is exhibiting the entire spectrum of its dynamic handling potential. Current test drives in Wales are fully dedicated to the final coordination of all drive and suspension systems, the key focus being on the BMW M850i xDrive Coupe, a car which embodies the performance characteristics of the new luxury sports car in a particularly intensive manner. A completely redeveloped V8 engine, state-of-the-art intelligent four-wheel drive technology, an active rear axle differential lock, the adaptive M suspension Professional with active roll stabilisation and Integral Active Steering form a perfectly harmonised package for fascinating sportiness and supreme comfort. The most striking features shared by the engine and suspension include the broad spectrum of their characteristics. The eight-cylinder power unit being featured for the first time in the BMW M850i xDrive Coupe produces precisely the amount of torque and sonorous sound ideally suited for relaxed cruising. On the other hand, in the Sport or Sport+ mode of the driving experience control feature, both power delivery and engine sound alike become noticeably more dynamic. Likewise, the function of the electronically controlled dampers, the stability control system DSC (Dynamic Stability Control) and the four-wheel drive system are precisely oriented to the selected driving mode. The rear wheel-focused setup of the new BMW xDrive system is perceptible in every driving mode, whilst particularly ambitious drivers benefit from the active differential lock in the rear axle transmission, which provides for maximum traction when accelerating out of bends. “The thing that always impresses when test driving the new BMW 8 Series Coupe is its adaptability,” says Markus Flasch, BMW 8 Series Project Manager. “Whether a driver expresses his or her wishes with regard to comfort and sportiness using the accelerator pedal or by pressing a button, the vehicle immediately adapts perfectly to each setting.” A low centre of gravity and high stiffness values for body and suspension form the basis for the new BMW 8 Series Coupe’s highly dynamic handling characteristics. In the case of the BMW M850i xDrive Coupe, both agility and direct steering behaviour are additionally assisted by standard Integral Active Steering and active roll stability. Moreover, the electronically controlled dampers are able to provide for maximum wheel stability at any time, so that contact with the road is guaranteed even on short stretches of uneven surface. “The new BMW 8 Series Coupe will be available exclusively with mixed tyres. This gave us the possibility when coordinating the suspension control systems to exploit the potential of the wide rear wheels to attain particularly sporty handling characteristics,” comments Jos Van As, head of Suspension Application. “Also, the higher camber values on all wheels and specifically tuned elastokinematics result in the realisation of exceptionally high cornering speeds prior to the intervention of the electronics. So those who wish can drive on the racing track with active DSC, too.” As the embodiment of both supreme and sporty power delivery, the new V8 power unit also contributes decisively towards the performance characteristics of the BMW M850i xDrive Coupe. Whist having the same weight as the predecessor engine, the new power unit mobilises an output that has been increased by 50 kW/68 hp to 390 kW/530 hp. Maximum torque has increased by 100 Nm to 750 Nm and is available at 1,800 rpm. The eight-cylinder engine delivers its power to an extensively further developed 8-speed Steptronic sport transmission characterised by expanded spread and further shortened shift times. “The new V8 engine offers exactly the right balance between performance and emotion, which is what also sets the new BMW 8 Series Coupe apart,” says Christian Billig, head of Drive System Integration. “Above all, the eight-cylinder harmonises perfectly with the further developed Steptronic transmission during dynamic acceleration. At the same time, the sound development of the sports exhaust system authentically reflects the car’s power delivery. And thanks to BMW xDrive and active rear axle locking, the engine always transfers power precisely to where it can be best converted into driving dynamics. With the test drives in Wales, developers are rounding off the exceptionally diverse and intensive programme for the series development of the new BMW 8 Series Coupe. Outside the racetrack and cordoned-off proving grounds, prototypes of the new model are also tested on public roads in order to obtain information on customer-relevant characteristics in driving situations that are as close to reality as possible. They form an ideal supplement to the information gathered for instance during winter test drives in Arjeplog in Sweden, on the BMW Group proving ground in Miramas in the South of France, at the testing centre on the Nürburgring Nordschleife or during initial racing circuit deployment. The BMW 8 Series Coupe will go on sale during the course of 2018. The digit 8 in the model designation refers to the new model’s prominent position within BMW’s product range. As was once the case with BMW Z8 and currently the BMW i8, it stands for highly emotional and exceptionally sporty vehicles. Thus, the BMW 8 Series Coupe will become a crucial component of the luxury segment model initiative laid down by the BMW Group in its NUMBER ONE > NEXT strategy. *Due to the prototype vehicle status, technical details like fuel consumption, CO2 emissions etc. will be communicated later this year.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
04-25-2018, 05:51 PM | #3 |
Rep 2,557
C+D also posted a first drive review.... sounds promising!
Side note anyone else find it hilarious they did a press release with the camo images... maybe will be an individual paint option |
TheBlackGT554.00 drew_larson39.00 |
04-25-2018, 06:09 PM | #8 |
Rep 635
Does "new v8 engine" mean a brand new engine or a reworked version of the one found in the F90?
I wonder if BMW now bringing back the 8 series, could mean that they might also bring the Z8 back to fill the portifolio, and also the already rumored X8 to complete the 8 lineup. Seems logical, maybe they are waiting to see how the Z4 goes. |
clbmw632.50 |
04-25-2018, 06:12 PM | #9 |
Rep 2,350
Finally a true BMW!
04-25-2018, 06:14 PM | #10 |
Ring Leader of G8X Haters
25074
Rep 8,762
C+D reviewed the car and praised the electric steering for having road feel! This car now is definitely real promising.
BimmerGuyFL78577.50 335i classic3.00 |
04-25-2018, 06:28 PM | #12 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
I need a moment!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
BimmerGuyFL78577.50 |
04-25-2018, 06:35 PM | #13 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
CD review is very promising! https://www.caranddriver.com/reviews...e-drive-review
04-25-2018, 06:37 PM | #14 |
Rep 1,483
I think this answers the engine question
https://www.topgear.com/car-reviews/...es/first-drive Unfortunate to hear that it needs more steering feel (but nothing new about that), but then C and D said it has some... be interesting to hear about the final tweaked production car |
04-25-2018, 06:55 PM | #16 |
Rep 5,824
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
SliChillax486.00 |
04-25-2018, 06:56 PM | #17 |
Rep 629
I know I might be in the minority on this forum, but why can't BMW make something really sleek and sexy like Aston or Jag or Maserati? I'm not say this car isn't good looking, but the design isn't better than the old 8, which I thought was a really beautiful car. On the plus side, a new engine and better steering feel per the review!
Gone but not forgotten: '10 X5M, '14 550ix, '17 M3 zcp, '11 aw e90 M3 zcp, ?11 sg e90 M3, '17 X5M, 19 F90 M5
Current: ?13 e92 m3 ESS 585, 22 f95 x5m Comp, Track - '18 manual 991.2 GT3, Wife's family truckster - '20 Volvo XC90 T8 |
04-25-2018, 06:58 PM | #19 |
Rep 80
I know!! I think the M8 is going to be a beast, as I recall it was built in conjunction with the M8 GTE, so I expect to see the use of some areo and light weight techniques.
04-25-2018, 07:36 PM | #22 |
Fitness Gene
1112
Rep 2,413
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
So let me get this straight
M5/8 will get old engine and m850 will get a new one? I don't see much logic here. 530 hp vs 600 in an M car... I hope it won't be like e92 m3 being slower than e92 335 with $400 tune
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
Madvillain160.50 |
