2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Mixing tires from the same brand
      05-16-2018, 12:32 PM   #1
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
Hi folks,
Is it OK to mix tires from the same brand? My F10 Michelin Pilot super sport for the front are fine, but need new rear tires, and the Pilot sport are no longer available, hence looking at Pilot Sport 3 for example, is this OK?
      05-28-2018, 03:25 PM   #2
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Different tires on the front axle vs rear axle is fine. Never do different side to side, as in different tires on driver vs passenger side.
      05-30-2018, 10:11 AM   #3
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Hello Eire! Most brands would likely advise against it. Often, I've heard the argument of different characteristics. Personally, I would buy a new set of PS3s.
I am very, very familiar with the roads there. I have family in Offaly and Kildare. If you frequent the dual carriage ways, you should be ok with the combo you mentioned. However, you plan to rally on the back roads, I would stick with the same model tire.
On the back roads of the midlands, I've dealt with black ice, sheep, and misc. road debris. Some roads are very tight, and have no margin for error. I wouldn't want a tire "characteristic" issue be cause of meself ending up in the ditch.
Cheers!
      06-25-2018, 10:07 AM   #4
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
I have Good Year non-RFT on front axle and Pirelli Cintaruto RFT on rear axle,car is driving normally
      06-27-2018, 11:01 AM   #5
Ickdeep
Ickdeep's Avatar
Drives: '13 F10 M5 | '15 F15 X5
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Just caution, if you have x-drive then they all need to be the same.
5post
