Ipod Audio issue
06-16-2008, 10:17 AM | #1 |
Rep 27
Ipod Audio issue
I've searched around but can't find anything on my issue. I'm driving around music from the ipod blaring and all of a sudden the audio goes out, total silence . Switch to radio, still no sound. I have to basically reset the car's computer by shutting off the car and waiting a good minute. This has happened about 4 times now...I've had the car 3 1/2 months. Suffice to say its an annoyance especially if I'm on the highway and don't want to pull over and shut down. Anybody else encounter this issue and have either a quick fix or had the dealer resolve it for them with satisfactory results
335xi coupe: black sapphire, black leather/dark burl trim, step AT, sport, premium, 18s (189), nav
06-16-2008, 10:29 AM | #2 |
Rep 3,201
That sucks, sorry to hear it.
I have not had this problem. It is mis-titled since it's an overall audio issue - if the radio is affected, it's not neccesarily an iPod issue. If you listen to the iPod most of the time, that might be why it only happens with the iPod playing. it is either the head unit or the amp. I know from personal experience in the E90 that the HU can lose F channels to the amp and keep playing the R channels. For this reason my gut says that either the amp is intermittent or the HU is not keeping the amp on with the remote turn on signal. Either way the dealer needs to deal with it. Since it is intermittent the dealer will first try to say that it didn't happen when they tested it, so you may need to escalate before you get what you need, which is first the amp swapped out, and then if that didn't do it, the HU swapped out to fix the problem. Good luck! |
06-16-2008, 10:36 AM | #3 |
26
Rep 1,826
Drives: E92 335i
Shutting off the car and waiting a minute doesn't "reset" anything in the entertainment system that I'm aware of. Sounds like you're overheating the amp until the thermal protection kicks in and you have to wait for it to cool off before it resets. Don't bother turning off the car next time, just turn off the radio and let the fan run for a while.
06-16-2008, 10:45 AM | #4 |
Rep 3,201
06-16-2008, 11:48 AM | #5 | |
Rep 27
06-16-2008, 02:07 PM | #6 |
Rep 3,201
Info from BMWtechinfo
By the way, he's right - it's NOT a "reset".
If a control module becomes too hot, this control module switches off for up to 10 minutes to protect the individual components against damage. |
06-16-2008, 02:23 PM | #7 |
26
Rep 1,826
Drives: E92 335i
06-16-2008, 03:36 PM | #8 |
Rep 3,201
For aftermarket, because we never know what impedance these things are getting used with. For OE, usually heat isn't an issue... but maybe with 2-ohm speakers and ported woofers underseat, we are running into more impedance variation...
06-16-2008, 08:35 PM | #9 | |
Rep 27
Thanks for the info all
06-16-2008, 08:39 PM | #10 |
Rep 3,201
You know, just when I start to think I'm good at communicating...
IT SHOULD NOT HAPPEN. IT SHOULD BE FIXED. IT INDICATES A BAD AMP OR A BAD SPEAKER OR A BAD HEAD UNIT. |
06-16-2008, 10:10 PM | #11 |
26
Rep 1,826
Drives: E92 335i
Indeed... the no-audio in response to overheating (if that's really what's happening) is by design, but it probably shouldn't be overheating nearly as often as you seem to suggest it is.
If it were me, I'd start taking notes about how often it happens and how long you were listening before it cut out. In the non-logic7 loaner I've been driving I've listened with the volume up to distortion level for 45 minutes or so without the amp keeling over on me. One of these comes in awfully handy: http://us.fluke.com/usen/products/Fluke+62.htm |
06-17-2008, 12:07 PM | #12 | |
Rep 27
06-19-2008, 02:03 PM | #13 |
Rep 33
I've had a similar problem a couple of times when I get into the car to go somewhere and the audio completely cuts out.
-iPod is recognized, but if I switch over to it is jumps back to the radio. -Radio 'works', but no audio at all. -No door gongs. I can turn off and turn on the car and nothing will change. Strangely though, when I open the door, eventually, I get a warped door gong and the sound comes back. It doesn't seem to be tied to restarts, or opening or closing the door, because it doesn't always come back when I open the door, it just randomly comes back at some random time that I open the door.
2008 E90 328i ZSP - Sparkling Graphite
