2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Can you replace the front set of tires on a staggered setup?
      05-28-2018, 02:01 PM   #1
Hanzo550
Hanzo550's Avatar
Drives: 2011 BMW 550i xdrive M Pkg
So i have a f10 550ix with 20inch 750il rims and the standard 245/40 fr. And 275/35 rear. P zeros all around. I lost the front passenger side due to a sinkhole or pothole cant tell the difference. I want to replace it with a new one, but ive been getting all this different feed back. Can i replace the one? Or do i need to replace both front? Or even worse all 4. Then im gonna switch to non rft.
      05-28-2018, 03:24 PM   #2
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Depending on how worn the other side of the front is, you may be able to replace just 1.
But what I usually do is replace both fronts and keep the remaining single good tire from the other front wheel in the garage as a spare.
      05-28-2018, 10:18 PM   #3
Hanzo550
Hanzo550's Avatar
Yeah i think im going to replace both fronts. Thnx
      06-04-2018, 09:24 AM   #4
JDMSteven
JDMSteven's Avatar
Drives: '13 F13 M6, '94 JDM Supra
2013 BMW M6  [10.00]
I've replaced one on my 535i xDrive bc the other side was close enough in tread depth to new that I got away with it, bought the same exact tire and no issues
Tags
550i
5post
