BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis run flat tire pressure
      07-08-2018, 04:26 PM   #1
chuckbimmer17
Drives: 540i xDrive M Sport
Can anyone help me with the recommended tire pressures, my handbook implies there should be instructions on the edge of the driver door but there's nothing there.
I have a 540i xDrive M Sport with the 245/35R20 95Y on the front and 275/30R20 97Y on the rear.
The idrive is telling me the front left one is low at 37 but the others are green at 38. I'm not sure what to inflate them to. Thanks
      07-08-2018, 04:48 PM   #2
ADS-UK
ADS-UK's Avatar
United Kingdom
499
Drives: G30 - 530d M Sport
Have you checked the passenger door side (in case they've mistakenly put the sticker there)?
I'll take a picture of mine tomorrow and post it if you haven't got it.
      07-08-2018, 05:14 PM   #3
chuckbimmer17
Yeah I have, checked inside petrol cap too cos thats where they were on my last car but can't seem to find it anywhere. Cheers mate appreciate it.
      07-08-2018, 09:43 PM   #4
Osheatwo
Drives: BMW M3 Comp Xdrive
2021 BMW X5 M50i  [10.00]
2023 BMW 330E  [10.00]
I have the same tires and my door states 36 front 44 rear
      07-08-2018, 11:29 PM   #5
nlkccom
nlkccom's Avatar
Drives: 2018 540i AW
Here's a pic of mine.
      07-09-2018, 12:40 AM   #6
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
Idrive tells you both current and recommended pressure for each tyre.
Just make sure you select the correct wheel/tyre sizes you are running.
G30 540i xDrive M Sport MPPSK / BM3
      07-09-2018, 12:42 AM   #7
AP
AP's Avatar
2777
Drives: G30 M550
Yes it even allows for temperature .
      07-09-2018, 06:33 AM   #8
chuckbimmer17
Thanks guys, the iDrive is set to "other" under tire type as the ones I have don't appear to be an option. I guess I'll set them to 36/44 cold and perform a reset on the iDrive.
      07-09-2018, 10:58 AM   #9
AP
AP's Avatar
2777
Drives: G30 M550
Should be an option for 20 inch wheels as I have that on mine. ( I have the style 759 wheels)
      07-09-2018, 12:29 PM   #10
chuckbimmer17
Ah yeah you're right. Well I set it to those tires and it recommended 38psi for all 4. Although that's quite different to the sticker suggesting 36/44. Strange
      07-09-2018, 03:33 PM   #11
ADS-UK
ADS-UK's Avatar
United Kingdom
499
Here's my sticker as promised. I suggest you go for 35/38 if you only have 2-3 people.
      07-09-2018, 11:30 PM   #12
JohnEnglish
Drives: Black
Yeah the 36/44 is the pressure of you have a full load of people and cargo with the 17/18/19" tires.
      07-10-2018, 12:41 AM   #13
AP
AP's Avatar
2777
Drives: G30 M550
Interesting. Must admit I've only looked at idrive rather than that sticker.
Will have to have a look as I might be running higher pressures than necessary , ( will idrive flag that if I lower a bit? mmmm)
      07-10-2018, 02:22 AM   #14
ADS-UK
ADS-UK's Avatar
United Kingdom
499
I don't think so. My understanding is that once you reset the system with lower pressure, it'll simply monitor the new circumstances.
      08-23-2018, 03:57 AM   #15
csm7djs
Drives: G05 X5 3.0d M-Sport
I'm running the 19" 664m wheels and my iDrive was moaning yesterday that the front pressure was too low. It recommended I set them at 33/34.
5post
