08-12-2018, 10:49 AM | #1 |
Rep 128
688 / Harman Kardon Power Output
Just realised that the power output for G05 is only 464W compared to F15's 600W. That's 22.6% drop in power. Anyone with insights as to why? New circuitry maybe, or the new tech taken at the expense of HK system?
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40 |
08-12-2018, 04:25 PM | #2 |
Rep 2,857
How many speakers come with the HK? It's an up sell to the B&W 20 speaker/1,500-watt output.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
08-13-2018, 02:23 AM | #3 |
Rep 128
It's the same 16 speakers currently on F15. 7/7/2 setup.
11-19-2018, 08:30 AM | #5 |
Rep 128
Listened to some music on the H/K sound system on G05. Pleased to report that despite the drop in power, it actually sounded really good and decent (sufficient) power to me. I was playing 160kbit/s music tracks which I previously downloaded on Spotify.
11-19-2018, 09:05 AM | #6 |
208
Rep 328
My 18 540i HK system sounds much better than my wifes 19 x5 HK system.I have to turn it up 3 quarters of the way to get it as loud as the 540 at only a quarter of the volume.
2018 540i
2019 X5 xDrive40i 2012 Boss 302 #2147 2017 Shelby GT350 2017 F250 KR |
11-19-2018, 09:31 AM | #8 |
208
Rep 328
Oh yeah for sure. Dont get me wrong it still sounds great, its just the power behind it is not the same. Suspect they lowered the watts or changed the brand/type/company for the amp.
2018 540i
11-19-2018, 10:42 AM | #9 | |
Rep 276
Drives: 2019 X5 50i
With CarPlay wireless, it doesn't use BT for the audio, it uses WiFi to get an AirPlay quality audio stream - so that should be significantly better as a source. |
11-19-2018, 10:46 AM | #10 |
Rep 131
You should give some time speakers in your new X5 - after warming through few weeks they will start to sound better.
11-19-2018, 11:10 AM | #11 |
Rep 6,121
I've heard it's still a 600W system but there an error on BMWs site. check HKs BMW page to see the 600W system reference.
11-19-2018, 11:33 AM | #12 | |
Rep 978
And to the poster above that caught the bluetooth volume involvement - good call. That will also effect the overall sound. I've found bluetooth volume needs to be all the way up for the supporting source to use its own "normal" audio range. |
11-19-2018, 11:48 AM | #13 | ||
Rep 1,448
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
11-19-2018, 11:56 AM | #14 |
Rep 276
Drives: 2019 X5 50i
With wireless CarPlay, Bluetooth is only used to negotiate the WiFi connect to the vehicle's access point, after which all music/video/etc. is carried entirely via high-bandwidth WiFi. With more bandwidth available (compared to Bluetooth), the audio quality is the same as if you were playing on an AirPlay device at home (basically). If you have lossless 44 Khz, 16-bit files on your device, that audio stream goes directly to the vehicle audio system without being recompressed.
Xeno313.00 |
11-19-2018, 02:26 PM | #15 | |
Rep 6,121
Wild Blue3682.50 |
11-19-2018, 07:29 PM | #17 |
Rep 1,133
The HK in my F15 sounded way better than the HK in my G05. They were both the same price and the G05 has quite a bit less bass.
It's good to be bad
11-19-2018, 08:01 PM | #18 |
Rep 238
I respectfully disagree. the g05 noticeably sounds much better than the f15. I still have another few days left with it and going back and forth between the two the g05 def wins. Also has much better bass than before. G05 is wife's car I have the f86 with the b and o. I can def compare all three offerings and was pleasantly surprised by the hk in the g05
11-20-2018, 11:54 AM | #20 |
Rep 186
11-20-2018, 01:03 PM | #22 |
1051
Rep 1,951
From their videos online - if you have a basic knowledge of tools and a torx screw set - you can DIY for maybe an hours worth of your time, if you really take your time. Its a simple as swapping out the old sub with the new. No retro fitting or anything like that. Simply remove the seat (4 bolts) tilt it back, remove the sub and housing, replace sub, reinstall sub and housing. While you're in there, you may want to add some dynomat to help insulate the sub even more and maybe increase the performance of the sub some.
