Earthquakes, Part 2...2Ohms
06-27-2008, 01:22 PM | #1 |
Rep 3,106
I just talked to the guy here who I put an order in with a few days ago and the 4 ohm get in early next week, but he just got some 2 Ohm ones in today. Wanted to pass along to those of you who are looking into getting these.
http://www.caraudiocraze.com/subwoof.../prod_762.html I know it says they are on backorder, but give him a call. Question thought, what difference is there between the 2 and 4 Ohm, if they will be powered by a different amp? Anything?
Delivered 28 May
06-27-2008, 06:14 PM | #2 | |
Rep 1,104
4 ohm + 4 ohm (in parellel) = 2 ohm for the amp thats all i know though, maybe Technic can chime in on this?
2007 E90 335i JB
2010 E90 M3 JRB |
06-27-2008, 07:28 PM | #3 |
Rep 3,106
But if they are not run in parallel or with each sub having its own channel then the 2 vs 4 Ohm wouldn't matter, would it?
Delivered 28 May
06-27-2008, 08:31 PM | #4 | |
2288
Rep 13,001
Remember, according to the Earthquake people, this 2 ohm version was made to match the base OEM system subs impedance as a drop in replacement therefore it does not have to have double the power rating of the 4 ohms. Especially when the base OEM amp has way less power to supply to these 2 ohm subs than the Top HiFi amp to the 4 ohms subs. |
06-28-2008, 01:15 PM | #5 |
Rep 8
Hey all,
I am "that guy" that Colin has talked to from CarAudioCraze.com I figured id stop in and answer a few questions and shed some insight. I didnt realize the Earthquake was a direct fit into the E90's as im oldschool with my E46. Anyway like he said we got in the 2-ohm version on Friday and those we can ship out either Monday or Tuesday at the very latest and the 4-ohm versions are coming later this week sometime. As for the difference in Ohms, it does matter. Im not sure of stock system but if you are hooking them up to an after-market amplifier it does matter. Ohms are resistance and so depending on the amp it will determine the power the sub woofer receives. In Colin's case he has an Alpine PDX amplifier which puts out the same power at ANY resistance so it doesnt matter for him, however most amps ARE NOT like this. However since the subwoofer isnt a dual voice coil sub it cannot be wired down to 1 ohm unless in parallel with another subwoofer. Likewise a 4ohm can only be wired down to 2 ohms if in parallel with another woofer. If you guys have any other questions feel free to contact me personally at my email: trenier09@gmail.com (this goes to my blackberry, so expect a pretty fast response) ALSO: e90post.com users can now recieve 8% off your order total with the coupon code "E90Post" (random percent but its the max i could do for you guys!) |
06-28-2008, 01:33 PM | #6 |
Rep 3,106
Hey good to see you in here, sorry I didn't remember your name.
So should I wire these in Parallel or not? Thanks
Delivered 28 May
06-28-2008, 01:44 PM | #7 | |
Rep 8
Anyway no you dont need to. You can just wire them separately at the normal 2-ohms to your PDX. -Trent CarAudioCraze.com |
06-29-2008, 11:12 PM | #8 |
318
Rep 387
2 things:
first, do you have any detailed specs of the new 2ohm subs? second, im still not sure which one to get, I want to use the 300.2 earthquake amp.. http://www.earthquakesound.com/xtreme.htm Which one would you recommend for the most increase in bass? the 2 or the 4 ohm version? Thanks, Alex.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
07-01-2008, 12:20 PM | #10 | |
Rep 8
As for that amp, id go with the 4-ohm subwoofers. As you know, the sws-8's have a max load of 300W and the RMS of that amplifier at 2ohms to 2 subwoofers is 250W. Usually, you want to give the subs half of their max. So the 130W x 2 subs at 4-ohms would be the better choice. Hope that helps! -Trent |
07-01-2008, 05:48 PM | #12 | |
318
Rep 387
Alex.
07-01-2008, 11:27 PM | #13 |
318
Rep 387
In case anyone was wondering, I called earthquake directly to confirm, and the only difference between the 2-ohm and the 4-ohm is the resistance. The guy also said that the 2-ohm ones have a new voice coil and that should make them a little more powerful, but everything else is the same, dimensions, RMS, max wattage.. all the same.
07-07-2008, 06:47 PM | #16 | |
Rep 6,723
I have Logic 7 system and I'd rather keep the amp stock |
07-07-2008, 07:15 PM | #17 | |
Rep 3,201
07-08-2008, 05:43 AM | #18 | |
2288
Rep 13,001
07-08-2008, 03:38 PM | #19 | |
Rep 3,106
I have had mine installed here for a few days and to be honest I am not sure if I am going to hook up the amp. With the way I installed them with Dynamat and the cover back on with the spacers under the carpet, they hit hard enough for me I think, at least enough to shake the rear view mirror on some songs, and a good amount of ass massaging. I have no rattling outside of the cabin either on the side skirts like some were having with these. Just not sure how much harder they woud hit with the amp
Delivered 28 May
07-08-2008, 04:15 PM | #20 | |
Several N54 cars, V1,3, V2.0.2, and V3.1
12
Rep 778
07-08-2008, 05:27 PM | #21 |
76
Rep 1,548
the spec are the same as the 4 ohm
Message from eBay member, audioonesavings Do not respond to the sender if this message requests that you complete the transaction outside of eBay. This type of offer is against eBay policy, may be fraudulent, and is not covered by buyer protection programs. Learn More. User details: From User: audioonesavings (6376) 99.6% Positive Feedback Member since Jan-09-06 in United States Location : NY, United States Activity with audioonesavings (last 90 days):I have bid on 0 items from audioonesavings Activity with audioonesavings (last 90 days):audioonesavings has bid on 0 of my items Dear The 2 ohm model has the same power/tech specs as the 4 ohm model (only difference is impedance): 8" Car Subwoofer 300w Peak power 150w RMS Power Impedance: 2 Ohms Mounting Depth: 2 1/8" Cut out Mounting hole= 7 7/8" Voice coil Diameter: 1.5" Aluminum bobin Over 1.5" long throw excursion Long lasting UV treated high roll compostite foam surround Weather resistant light weight PVC cone For Door Mount, Under-seat mount, In-Dash mount or rear deck mount For car , home & marine bass application Revc. (ohms): 3.500 Fo. (Hz): 30.394 Sd. (msqM): 22.000 BL. (TM): 6.210 Qms: 3.987 Qes: 0.804 Qts: 0.669 SPLo. (dB): 86.7 Vas (Ltr): 27.830 Xmax (mm): 23 Let us know what you think. Thank you. |
07-08-2008, 05:42 PM | #22 |
Rep 3,106
That is correct, just tapped the wires from the old subs and left the connecter on there when I get rid of the car so I can put it back to OEM.
Delivered 28 May
