BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 530e lowering springs
      08-22-2018, 05:10 PM   #1
Richukbmw5
England
Drives: BMW g30
Looking at options on lowering springs. I spoke to eibach today and they don't have any plans to release the pro kit for the 530e.
I don't fancy H&R due to bad experiences in the past.
That leaves AC schnitzer which I believe have springs made by eibach anyway. I can't find them online, anyone have any info they can share?
BMW 530e M sport
Mediterranean Blue
      08-22-2018, 10:06 PM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Do you have M Sport suspension package or not?
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      08-23-2018, 12:45 AM   #3
Richukbmw5
England
Drives: BMW g30
I have an M sport car yes, but BMW don't offer M sport suspension (lowered springs) on the 530e.
I have standard shocks, so no Variable dampers.
BMW 530e M sport
Mediterranean Blue
      08-23-2018, 09:07 AM   #4
r33_RGSport
PM me last 7 of your VIN.
Let me check.
Because I installed H&R on 530e M Sport and it rode fine.
Ride a little stiffer than stock, but not bouncy.
      08-27-2018, 04:05 AM   #5
Richukbmw5
England
Drives: BMW g30
Let me check.
I got a reply from AC schnitzer this morning advising they have no plans for lowering springs.
So H&R is the only option for the 530e.
The correct part number is 28721-5.
Image courtesy of Shmeidmann
https://www.schmiedmann.co.uk/en/pro...roduct=28721-5
BMW 530e M sport
Mediterranean Blue
Brake_Late1936.50
      08-27-2018, 10:56 AM   #6
r33_RGSport
Yea, H&R just released it.
      12-02-2018, 01:42 AM   #7
snorkelface
Drives: 2019 530e
Any update on other offerings? Those H&R springs are just too low. PLus, they seem to sag in the rear. I don't think they really compensated for the battery weight in the rear.
Brake_Late1936.50
      12-03-2018, 05:15 PM   #8
r33_RGSport
I believe so far only H&R that have the specific spring for 530e.
The pictures that I post are using the non 530e springs.
Other than that, your option is KW V3 coilover.
      12-05-2018, 07:20 PM   #9
snorkelface
Drives: 2019 530e
What's your opinion on wheels spacers for the 530e with the same 19" M Sport wheels you have? 12mm/15mm, or does 15mm/20mm work better with these wheels when lowered?
Brake_Late1936.50
      12-05-2018, 07:38 PM   #10
r33_RGSport
If you lower the car, I would to 15/20 for aggressive look.
12/15 more to the conservative side or if it not lowered.
Brake_Late1936.50
      12-05-2018, 07:41 PM   #11
snorkelface
Drives: 2019 530e
Thanks for the input! I'm trying to get Eibach to use my car to develop springs since I'm local, but no reply. Oh well!
r33_RGSport12963.50
      12-05-2018, 07:48 PM   #12
r33_RGSport
Well, if you decided to go different route, let me know.
      12-11-2018, 10:53 AM   #13
Richukbmw5
England
Drives: BMW g30
Already tried this myself and spoke to them, however all their development is done in Germany and not the US or in my case the UK.
      12-21-2018, 06:18 PM   #14
Sarang5
Drives: 530e
I have H&R springs, bolts and spacers for the 530e. I just took them off after about 3k miles (like new) to put on the G11 20" wheels.
They are for sale if anyone is interested. PM me..
Brake_Late1936.50
      01-16-2019, 12:57 PM   #15
Brake_Late
Brake_Late's Avatar
Norway
1937
Drives: 2015 F82 M4 FIREORANGE2
You have pm
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
      03-20-2019, 09:41 PM   #16
Judahzlion
Judahzlion's Avatar
Drives: 530e
Hi everyone.
on my new 530e I have tried to replace the lowering springs from H&R H&R 28721-5.
I drove it for 2 weeks thinking it will get better. However, it was jumpy and uncomfortable.
I took a bite and replace mine with KW Coil Over STREET COMFORT Part #: 180200BY
This one is with Electronic dampers since mine originally was.
Nicely lowered very.. Very comfortable. However at the maximum high position it is too low and you can not get is any higher. I needed to raise it up at least 1/2" and can not. Unfortunately KW has recalled this product calling it unfit until another product is made and I have removed and replaced factory shocks again.
I have H&R Springs 28721-5 available for quick sale....
PM if interested ..
_______________________
Best Regards; /Hailu
      06-12-2021, 07:45 PM   #17
FoxberryJam
FoxberryJam's Avatar
518
Drives: '23 M4 CompX; '98 m Roadster
I concur...
      11-29-2021, 09:23 PM   #18
chris_sd
29
Drives: 530e
I am not that happy with the H&R springs either. They are sitting a bit to low and ride is to harsh. I have warped the front rims several times already. However, the stock springs are sitting way to high and does not look good. Anyone have any ideas on something in between?
Christer
      11-30-2021, 12:40 AM   #19
PetieD 7
Drives: 540i xDrive M Sport
Christer
Check out the MSS adjustable spring kit. You can obviously lower the vehicle to your spec, and maintain the ride comfort at the same time. Although, it is on the pricey side when compared to other lower spring kits such as Eibach.
      12-08-2021, 02:02 PM   #20
AD51YYY
AD51YYY's Avatar
United Kingdom
15
Drives: BMW 530e M Sport 2018
2022 BMW 520d  [0.00]
Christer
Did you get H&R specific for the 530e? It's a right nightmare this. Seems like BMW couldn't be bothered to make m sport springs specifically for this engine!
      12-09-2021, 09:56 AM   #21
AD51YYY
AD51YYY's Avatar
United Kingdom
15
Originally Posted by Judahzlion View Post
Hi everyone.
PM if interested ..
Hi there, I am considering purchasing the H&R 28721-5, the ones specific for the 530e..what were your thoughts on this spring? What do you mean when you say jumpy? I can't budget for coilovers and really don't want to go for springs that weren't meant for the 530e as I don't want the saggy rear..
      12-27-2021, 09:52 PM   #22
X5Guy
Drives: X5
Hi everyone.
PM if interested ..
Like the others have said…the ride is terrible. After a week of settling, the front was very low. Front wheels looked tucked and cambered in too much. I felt Iike I was driving a slammed civic like back in high school lol. Couldn't take it anymore and removed the springs. Currently sitting at factory height with the huge wheel gap but I'd rather the wheel gap than the horrible ride with H&R springs.
5post
