Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Same size tires on a 07 328i coupe
      08-26-2018, 02:35 PM   #1
Mrclean67
Drives: 2007 328i 6 speed manual
I'm picking up a 07 328i coupe this week and it needs new back tires, can I run the same size all around or will I run into issues? Seems there's such a slight difference between the front and rear. It has 18's and the sport suspension. Thanks in advance!
      08-27-2018, 02:25 PM   #2
///M-Power
///M-Power's Avatar
Drives: 2014 BMW 528i F10
No problem, it's called a square setup. I wouldn't mix and match tire brands and speed ratings. That's just me.
      08-30-2018, 05:12 AM   #3
Mrclean67
Thank you! The fronts were just replaced with Bridgestone Potenza S-04 Pole position so I'll put the same on the rears👍
      08-30-2018, 05:17 AM   #4
Mrclean67
So no rubbing issues with the 255 40 18 on the rears correct?
