      08-26-2018, 07:23 PM   #1
LenO
Drives: 2016 X6 xDrive50i, 2014 650i
X5 Cargo Area Dimensions Confusion
The dimensions for the cargo area for the 2019 X5 (G05) are:
Minimum - 22.8 Cubic feet and Maximum - 65.7 Cubic feet
The dimensions for the 2018 X5 (F15) are;
Minimum - 35.8 Cubic feet and Maximum - 76.7 Cubic feet
The 2019 X5 has 13 Cubic feet less behind the rear seats, and 11 Cubic feet less with the rear seats folded.
My X6, which is shorter and narrower and with the sloped rear tailgate, has cargo area dimensions of:
Minimum - 26.5 Cubic feet and Maximum - 59.7 Cubic feet.
The X6 has about 4 Cubic feet more capacity behind the rear seats than the 2019 X5. The X6 has always been criticized for having inadequate cargo carrying capacity.
So, what is going on? What happened to the 2109 X5 cargo area? Are these new numbers real, or is there something else we should know?
      08-26-2018, 08:27 PM   #2
nal13
nal13's Avatar
561
Drives: M3 xcomp/911 cab/RR LWB
B  [0.00]
According to a previous post by Jason the trunk volume will be 31.7 cubic feet. Very strange that a longer, taller, and wider car will have a smaller boot. This could actually be a deal breaker for me.
The Range Rover Velar, which is 5 inches shorter has 34 cubic feet.
Could this be right?
2022 M3 xdrive IOMG/SS
2023 Porsche 992 4 GTS cab RubyStar Neo/Black/MT
2023 Range Rover P400 SE LWB Penguin
      08-26-2018, 08:52 PM   #3
drjoe66
drjoe66's Avatar
Drives: 2021 M5 & 2019 X3
The volume is kind of pointless. If I need to put three suitcases in, the length and width determine if they will fit
or not. So what are those numbers, I can measure my old X5, but i can't find the numbers for the new one.
2019 X3
2021 M5 Comp
On order: 2022 X3M40i
      08-26-2018, 10:36 PM   #4
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
Something isn’t right with those posted dimensions. If you look at photos of the ‘18 X5 and ‘19 X5 cargo areas they certainly look almost identical in size. I don’t see how you would lop off 13 cubic feet from a car that grew in size. 13 cubic feet is the entire size of my wife’s 528i trunk! Even the X3 has more than 23 cubic feet with seats up. With 13 less there wouldn’t be enough room for a 3rd row.
A couple cubic feet difference maybe...then give more rear seat room perhaps.
      08-26-2018, 11:30 PM   #5
mbhammer
Hammer
Drives: 2014 Mercedes Benz E63 AMG
Originally Posted by ScottMZ3 View Post
I don’t see how you would lop off 13 cubic feet from a car that grew in size... With 13 less there wouldn’t be enough room for a 3rd row.
ScottMZ3 - I had the same question.... and drew the same conclusion.
LenO - Glad I'm not the only one scratching my head on this metric. Thanks for starting the thread... though in my case at least, my order's in and I'll get in October what I get.
2019 BMW X5 40i
2014 MB E63 AMG
      08-27-2018, 11:09 AM   #6
Influence
Drives: 2020 X3M, 2016 X5 35i
Looks like it is time to get out the old tape measure and check the actual dimensions of the G05's trunk space. While I am hoping for a bit more rear leg room than my F15 (1.5-2 inches would be perfect), if they have to shrink the trunk to get it that is not good. Considering the wheelbase is up by 1.6 inches, overall length is up by 1.1 inches, height is up and width is 2.6 inches more, there is no reason cargo capacity should have dropped unless they added like 6 more inches of combined front and rear legroom, which I highly doubt.
Anyone going to a preview/training event anytime soon? I'm supposed to get an invite to a training session at my local dealership, but that won't be until sometime in October.
      08-27-2018, 12:00 PM   #7
mbhammer
Hammer
I have a theory. Could be total fiction. And I haven't bothered to do any math to test the theory. With those caveats, here goes:
The F15 did not accommodate third row seating. Only two cargo capacities made sense to report: with rear seats up, and with rear seats down.
The G05 accommodates third row seating. Are the lower cargo capacities about which we are commenting affected by this?
So for example, is there 13 ft3 behind the third row that is somehow getting lost in these calculations?
Dunno.
Don't know how else to explain the figures reported.
p.s. As many here probably already know, the refreshed 2018 X3 has luxury compact SUV class-leading cargo space, rivaling the capacities of many luxury mid-size SUVs. Would like to think that whatever magic BMW pulled off to achieve that in the X3 carried over into the new X5.
2019 BMW X5 40i
2014 MB E63 AMG
      08-27-2018, 01:22 PM   #8
LenO
I noticed something interesting while looking more closely at these numbers. The difference between the volume when the rear seats are up and when they are reclined for the 2019 X5 is 42.9 Cubic feet. The difference for the 2018 X5 is 40.9 Cubic feet. They are pretty close. This means that most of the lost space occurs behind the rear seats. I notice in the pictures and videos that I have seen, the car is equipped with the electric cargo cover option. It appears that the side walls are built into the cargo area to accommodate the cover and the control mechanism. Could this account for the lost space? I have no interest in the electric cargo cover. The manual cover is fine for me. The question is: Are the sidewalls built up the same even when going with the standard manual cover?
      08-28-2018, 10:31 AM   #9
JCF15X5
Drives: 2018 BMW X5 M SPORT
That would be a deal breaker if this is true.
I actually have my dog ride in the trunk of my x5.
      08-28-2018, 11:24 AM   #10
ScottMZ3
Here is the 2018 X5 cargo area:
Here is the 2019 X5 cargo area:
They certainly don't look to be THAT different. Main difference I see is that the side walls are more vertical than in the 2018, to accommodate that auto sliding cover. But other than that...I'm sure the cargo areas are near identical. There certainly isn't an entire 528i trunk worth of space missing.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
      08-29-2018, 06:45 PM   #11
LenO
Thank you ScottMZ3, for the photos. I have been studying them to try to find the missing 13 Cubic feet. I printed copies and adjusted the scale to match them side by side. Obviously, the sidewalls on the '19 are vertical, and may even protrude out a little bit more than the '18. Maybe the rear seats are back a little further to accommodate rear leg room. But no way can these minor differences account for a missing 13 Cubic feet.
The numbers I used in my first posting were all from BMW documents. I checked the European BMW brochure, converting liters to cubic feet, and found the same numbers. A number of auto review websites have commented on the reduced 13 Cubic feet, but have offered no explanation. They do say that BMW has put themselves at a significant disadvantage compared to their competition. I have seen nothing from BMW addressing this issue.
With the cargo volume behind the rear seats for the '18 at 35.8 Cubic feet and the value for the '19 at 22.8 Cubic feet, the missing 13 Cubic feet would represent a 36% reduction. Looking at the pictures, there is absolutely no way there is that less space. Pictures don't lie.
So what is going on? Has BMW redefined what they consider to be cargo volume? Maybe they only consider the area beneath the cargo cover to be usable. Whatever it is, the pictures show that whatever changes there are, they don't amount to much.
      08-30-2018, 08:31 AM   #12
maze446
Drives: 2019 X5 50i
Was just on the new US website and it has cargo capacity of 33.9 cu ft and 72.3 cu ft which is slightly down from the F15 but not as much as the early numbers suggested.
      08-30-2018, 09:18 AM   #13
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Good to know
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
      08-30-2018, 09:22 AM   #14
ScottMZ3
Those numbers definitely sound right to me. With the more vertical sides to accommodate the sliding cover a couple less cubic feet is reasonable.
      09-27-2018, 08:34 PM   #15
aus
Drives: Odysse
Has anyone been able to confirmed the volume difference is slightly less than before? And not 13cu ft?
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      09-27-2018, 11:56 PM   #16
maze446
Drives: 2019 X5 50i
Yes. See my note above. Those numbers are from BMW's website.
      09-28-2018, 01:56 AM   #17
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Dunno.
Third row seating is an option on the F15. The seats are pretty small, but they work for small adults and children.
Someone already provided a reference that the OP volumes might be incorrect, so it's probably just a typo.
      12-01-2018, 09:01 AM   #18
Nicky_do_it
Drives: F80 M3 ZCP manual (previous)
Is the difference related to whether the space below the cargo area is included?
I noticed some reports (eg us news&world report) states the 2015/16 X5 has 23 vs other reports at 35.8 cu ft and it doesnt seem to be a matter of a third row. Hard to believe that space would represent that much though.
