The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > e90 PFC Rear Brake Pad Size
      09-10-2018, 05:50 PM   #1
gilly22
503
gilly22's Avatar
Drives: see sig
Is anyone running PFC pads on the rear of their e90 328i xDrive? I've spent way too much time trying to solve this puzzle through the forum search, realoem, bmwparts and google. I've also spoken to three different PFC dealers, but I keep getting conflicting information about the correct PFC rear brake pad for my car. I have a 2011 e90 328i xDrive N51 (10/2010). Do I need a 0396 or 0548 rear pad size? Anyone? TIA
2011 e90 328i M-Sport 6MT xDrive AW / BLK
///M3 at PIR
      09-11-2018, 04:03 PM   #2
Synectic
Drives: 2010 e92 335i mtech
Have you asked Bimmerworld?
      09-14-2018, 07:33 PM   #3
gilly22
503
gilly22's Avatar
Drives: see sig
Yes. They were the first place I called.
///M3 at PIR
      09-15-2018, 04:49 PM   #4
minaret
Drives: 2008 E91 ZSP
I was in the same dilemma, the PFC 548 rear pads were too small, so Bimmerworld let me exchange them for the 396 rear pads. They were the correct dimensions, but the clips were too small for the caliper pistons. The pads were easy to change, but because they were so loose they'd make clunk noises enough that personnel in the paddock would notice! I switched to CarboTech Pads; they fit great. If you want those 396 rear pads (two track days on them-very little wear) I'll send them to you no charge; I'll never use them.
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
