BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Recall: Fuel Level Sensor
      09-25-2018, 10:00 PM   #1
verdao
37
Drives: 2018 M5 First Edition
I received the recall letter today for my FE. It states:
What could happen
"The fuel level sensor in the fuel tank may contact and become stuck against an in-tank fuel line. If this occurs, the fuel gauge in the instrument cluster would display a constant (and larger) amount of fuel than is actually available. This could lead to stalling, and increase the risk of a crash."
Has anyone received this letter and had it fixed? Sounds like the car needs to be ripped apart to fix the problem.... at least to get to the gas tank! I don't even want people touching this thing let alone rip it apart. Not good BMW!
      09-25-2018, 10:08 PM   #2
Ex_Stig
Ex_Stig's Avatar
2594
Drives: '24 X7 M60i
2024 BMW X7 M60  [10.00]
I had this problem in my E46 M3 back in '03. Just be glad there is a recall because that means they have a solution.
When I had the problem they didn't have a clue.
Ex Stig
'25 M5 Touring (on the list, first slot)
'24 X7 M60i
'22 M5 CS - (sold)
      09-25-2018, 10:09 PM   #3
TheRealOrosie
BMW Fan Boy
TheRealOrosie's Avatar
Drives: //M
What could happen
I think the fix is rather easy. Nothing to tear apart. They can access the tank from up top, and simply zip tie a fuel line I think. Nothing will get ripped apart.
      09-25-2018, 10:19 PM   #4
Oswiff
Oswiff's Avatar
Drives: 2021 m5 comp
Got the letter yesterday and made an appointment for next week.
I was told it takes an hour to complete so I don't think the car will need to be taken apart.
      09-25-2018, 10:34 PM   #5
ACF90M5
ACF90M5's Avatar
21
Drives: 2018 F90 M5
Already had this done a week ago. I believe it is a quick fix (probably a couple hours) but my service center was booked up so it took pretty much two business days.
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl
      09-25-2018, 10:35 PM   #6
visualguy
Drives: M5
They need to take out the back seat, and then open the area under the seat to get to the gas tank. I'd expect some damage - I have bad experience with dealerships even on much more trivial stuff.
      10-05-2018, 03:21 PM   #7
Oswiff
Oswiff's Avatar
Recall service was done today. Took just under an hour.
They did have to get to the fuel tank but no damage as far as I can tell.
Only drawback is the car stinks of gasoline so have to leave the windows open.
      10-05-2018, 04:02 PM   #8
marcvtec
407
Drives: M5
My piece of advice when you bring the car in to do this ( which i did)
Make sure the gas tank is less then 1/4 (which i did, no smell)
Otherwise you might have the problem listed above /\
      10-05-2018, 04:07 PM   #9
GUNGASLOW
192
Drives: 2019 M5
When I took mine in the somehow got gasoline on the rear seat..it ruined part of the rear seat.. waiting for replacement now
      10-11-2018, 08:41 PM   #10
verdao
37
I took the FE to dealer for the recall. The mechanic was very appreciative that the tank was pretty much empty. I recommend you do the same to avoid any spillage. The access port to the tank seems to be at a 35-40 degree angle so if the tank is full, it will overflow out. No damage and no ripping of the insulation.
Attached are a couple of pics for your pleasure.
      01-21-2019, 04:44 PM   #11
ACF90M5
ACF90M5's Avatar
21
Drives: 2018 F90 M5
Just got done doing a 1200 mile rally (which was a blast in the F90 outside of some scary blizzard highway moments) and I am not convinced the sensor recall was done right or if it is the correct fix. I would fill up 6 gallons of fuel at the pump even though my gas level was showing well above 3/4 full. From what I could tell at each fuel stop it was 1-2 gallons off.
      02-04-2019, 08:09 PM   #12
SpeedyDad
SpeedyDad's Avatar
283
Drives: 2018 F90 M5
2003 E39 M5  [0.00]
2018 BMW M5  [0.00]
I had the recall performed several months ago after experiencing the faulty fuel level readings. All has been fine for the past 2,000 miles until last week when I got an orange CEL. Car is now at the dealer and the code the car is throwing indicates a short in the fuel system electronics. I’ll update when they know/tell me more.
      02-06-2019, 12:45 AM   #13
SpeedyDad
SpeedyDad's Avatar
283
Drives: 2018 F90 M5
2003 E39 M5  [0.00]
2018 BMW M5  [0.00]
Update: there is an issue with the fuel emissions data being relayed to the ecu. The US requires that newer cars record everything that fuel sensors are reading and if there is any interruption in the transmission of that data, the car will throw a CEL. My car is operating normally and safe to drive while I await a new fuel sensor unit (or something like it) from Germany. ETA 3 weeks.
We certainly are the test mules for the f90!
      02-06-2019, 07:29 AM   #14
devondragon
devondragon's Avatar
Drives: 2019 M5 Competition
Huh! My CEL turned on last night, but no errors show up in the iDrive system. I wonder if it's related to the emissions data.
      02-07-2019, 05:58 PM   #15
Miko M
///M
Miko M's Avatar
Drives: 2020 M2C. 2020 X3M
Did you remove upper down pipes?
Life is too short...enjoy your life
///M
      02-07-2019, 08:00 PM   #16
Miko M
///M
Miko M's Avatar
Can you provided us with codes please?
Like to know what exactly was showing on code reader.
///M
      02-08-2019, 01:50 PM   #17
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
I like that interior color! Dam!
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      02-11-2019, 09:42 PM   #18
SpeedyDad
SpeedyDad's Avatar
283
Drives: 2018 F90 M5
2003 E39 M5  [0.00]
2018 BMW M5  [0.00]
I’ll have to ask the dealership.
m5post
