Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > SUBS: face backwards or forwards?
      07-03-2008, 02:58 AM   #1
Random456
Drives: 2006 325i
Which way do you face your subs in the trunk? Towards the back or towards the front? Do you think it makes a difference if you have the ski opening? I'm interested in what ppl do.
R456
      07-03-2008, 04:33 PM   #2
wheelman2925
Drives: 2007 335i SGM 6AT
As far as which direction to face the subs rear facing is the rule of thumb. Part of the reason that this holds true 99.9% of the time is that the relatively long bass waves are amplified due to reflecting off of the trunk wall and then into the cabin. The only sure fire method is to place the sub in different positions and firing angles until you get the best sound up front. Often times the optimum location renders the trunk a lot less useful.
Having the ski pass through will def make a noticable difference in the way the bass sounds. With the ski pass blocked or not there at all it's like having your sub in your neighbor's apartment. The bass will be diminished and not very detailed. It will seem like no matter what you do there isn't enough bass. This can be overcome with multiple woofers and high power, but that takes up a ton of space and weighs a ton. Ever pick up a box with 2 12"s in it? Pretty darn heavy. If you don't have the ski pass through be sure you go with a good sub/ amp combo to help off set. The better a car is built the more of a bass trap the trunl will be and since we're not putting 2 15"s in a geo metro it's gonna be an issue.
Any questions feel free to ask.
      07-03-2008, 04:45 PM   #3
Random456
Drives: 2006 325i
do you think it'd be worth it to "cut out" a ski pass behind the arm rest if the car didn't come with one? would the improvement in bass be slight or substantial? also, if you have the ski pass, does it still sound better to have the subs aimed against the rear of the car rather than through the ski pass hole? thanks!
R
      07-03-2008, 08:49 PM   #4
wheelman2925
Well cutting a hole in the trunk wall would improve the sound quality of the bass it's a permanent mod and you would still have the seats to contend with. That's up to you, and yes even with the cut out facing the sub towards the rear would all but certainly sound better.
      07-08-2008, 12:09 AM   #5
i8_it
Feeling Blue.
i8_it's Avatar
Drives: I12 i8,f10 M5,e89 IS,F1 6S35i
2008 E93 M3  [5.36]
just drop your back seat
      07-08-2008, 01:11 AM   #6
PAKMAN
PAKMAN's Avatar
North Korea
360
Drives: 2011 E92 M3
2011 BMW E92 M3  [9.50]
2006 e90 330i  [5.50]
Offtopic i have 2 12 jl facing towards the trunk lid and my gas tank rattles any solutions?
stock car
      07-08-2008, 08:30 PM   #7
scooby9
scooby9's Avatar
61
Drives: 2007 E90 BMW 335xi
Do you mean the gas cap? If so, you could use some Dynamat on the gas cap to eliminate any extraneous gap space.
2007 BMW 335xi 6MT TiAg
      07-08-2008, 11:47 PM   #8
PAKMAN
PAKMAN's Avatar
North Korea
360
Drives: 2011 E92 M3
the lid to open and close to get to the gas cap rattles like nooo other.
stock car
