Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Need spacer size confirmation new square wheels/tires
      10-01-2018, 07:24 PM   #1
Faredo
Faredo's Avatar
312
Drives: 335i
Currently on style 189, (8x18 front ET 34 / 8.5x18 rear ET 37)
Using 15mm front and 20mm rear spacers
Fitment is great and I would like to keep the rear exactly like it is. The front MIGHT be able to come out just a bit.
Going to a 18x9 ET 30 square. I haven't ordered tires yet but probably going 255/35.
If im using the calculator correct, do I need no spacer up front .it would be 2mm more than what i run now with 9mm less clearance near the strut (on ST coil overs) ,
and a 7mm spacer in the rear, if its made?
thanks.
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
      10-02-2018, 04:54 PM   #2
b92
b92's Avatar
Drives: E92 335is, 6MT
18x9 squared is a good fit as long as you're non-x. I ran 18x9et30 in front on my pre-LCI E92 and inner clearance was about 1-2mm with my KW coilovers, there were some tire marks on the coilovers after 2k miles but I never noticed any rub. That was with 235/40 tires so you might need a tiny spacer here. The ST coilovers might be a little smaller than the KW version (same manufacturer), you will know right away when you try to put the wheel on!
For rear, with 255/35 tires you should be able to fit a 12mm spacer with just a little bit of camber, which you may already have if you're lowered. This will give a more flush look and will match the fronts better. I'm not too current on the spacer market, but I remember there being hub issues for spacers in the 7-11mm range, I would look into this.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon.
      10-02-2018, 07:17 PM   #3
Faredo
Faredo's Avatar
312
Drives: 335i
Great info! Would this be with 255 35s or should I go with a skinnier tire?
      10-10-2018, 10:00 AM   #4
Faredo
Faredo's Avatar
312
Drives: 335i
in case anyone is searching.
I needed a 5mm spacer up front to let the tire clear the spring.
Rear I was able to use a 15mm spacer after a mild roll to the rear of fender.
      10-10-2018, 11:11 AM   #5
b92
b92's Avatar
Awesome! Thanks for following up. I just saw that you replied to my post with a question and I never got back to you, my b.
Any rubbing in rear? Looks tight
      10-10-2018, 11:25 AM   #6
Faredo
Faredo's Avatar
312
Drives: 335i
yes, if you see the reflection of my garage door line in the fender, there was a lot of rubbing there. Had to massage it out with a roller. Still getting the slightest of rubs on big bumps but ill try to roll it out more this weekend.
      10-10-2018, 12:41 PM   #7
FCobra94
Guest
n/a
Drives:
Looks great OP
No rubbing up front?
      10-10-2018, 01:30 PM   #8
b92
b92's Avatar
Looks like you can go a little bit farther with negative camber, my pre-LCI coupe went to -3d without needing a camber kit. Could always downsize to a 12mm spacer, not sure how that will look in comparison to the front fitment.
Faredo312.00
      10-10-2018, 04:23 PM   #9
Faredo
Faredo's Avatar
312
Drives: 335i
Thanks for the advise, went ahead and picked up a 12mm. I really dont want to mess with camber if I can get away with it. my tire wear is just slightly heavier on the inside.
      10-15-2018, 08:18 AM   #10
Faredo
Faredo's Avatar
312
Drives: 335i
update. 12mm spacer in and zero rubbing. this is with a minor pull to the rear fenders. can probably be done with the old phone book method.
