      10-02-2018, 08:03 AM   #1
sward
sward's Avatar
Sweden
632
Drives: i7 xDrive60
2023 BMW i7  [0.00]
Will the new X5 have the key that stops transmitting while put down
This must be the best new feature on the new 3-series. This must prevent steeling bmw parked on the driveway with the keys inside the house using a signal repeater. I wonder if the X5 I have on order also will have this?
"New movement sensor in key monitors if key is being carried (and therefore is always transmitting) or has been put down on a table, for example, allowing it to switch into standby mode with the transmit function deactivated"
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30)
      10-02-2018, 03:39 PM   #2
idgam
Drives: the wife mad!!!!!
I hope this is the case.
I have already lost the F15 40d this way and don't relish parking the new G05 50d outside the house in case it happens again.
      10-02-2018, 04:46 PM   #3
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
I can confirm the X5 key DOES go to sleep after 45 seconds once it stops detecting motion. It was mentioned during the training session I was able to watch today. In fact there was a whole video demonstration regarding it.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
Appreciate 4
1230vani647.00
volodp196.50
gen1md16.00
      10-03-2018, 06:50 AM   #4
sward
sward's Avatar
Sweden
632
Drives: i7 xDrive60
2023 BMW i7  [0.00]
That's great!!!
/Fredrik
      10-03-2018, 08:21 AM   #5
idgam
That is great news
      10-03-2018, 12:59 PM   #6
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
Drives: 2020 M340i
2020 BMW M340i  [0.00]
Key goes to sleep after 60 seconds of no movement.
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com
Top M Client Advisor in New England.
1230vani647.00
volodp196.50
      10-03-2018, 08:11 PM   #7
Dilz
Drives: x5 Build for Nov 2018
Does this mean that you should not keep the key in your pocket while at home to avoid signal repeater attempt?
      10-03-2018, 08:40 PM   #8
ScottMZ3
That’s correct. If you are in an area where that is a serious concern, then I wouldn’t walk around with the key in your pocket...it wouldn’t ever go to sleep.
      10-04-2018, 08:46 AM   #9
JayPichardo
BMW Client Advisor
3452
Drives: 2020 M340i
      10-06-2018, 01:50 PM   #10
MysticBlue
369
Drives: '20 M5C, '09 M3 DCT Coupe
Wrong forum. You're about 14 years off.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      02-10-2020, 07:14 AM   #11
kamilkoc
Drives: BMW X5 GO5 (ordered)
Hi Jay!
Today I tried to test key fob sleep function and did the following: closed the door using comfort access, put key fob on the ground right next to the car, tried to unlock the car after: 1 min and then after 2min. I could still unlock the car after that time.... Is there any way to verify that I got the new version of key fobs (checking serial number, etc.)? It seems mine don't enter sleep state
Thanks for the response!
      02-10-2020, 09:19 AM   #12
Anterialis
Drives: BMW G05 45e
Maybe it won't go to sleep if the car senses you are within "comfort access" range?
volodp196.50
      02-11-2020, 02:22 AM   #13
kamilkoc
I'll try it again - maybe 2 min. wasn't enough
      02-11-2020, 02:30 AM   #14
jimbg
Drives: LR Discovery 5
Probably time AND distance as mentioned above.
      02-11-2020, 03:07 AM   #15
X5 45e
1089
Drives: BMW X5 45e
Hi Jay!
I have got a display key. I also had one on my previous car. The old one was empty after 2-3 days. The new one only lost 25% of battery after putting it away for a week (I use the normal key as default). Probably the function you mention has to do with it or also a better battery.
      02-12-2020, 02:21 PM   #16
bhe
Belgium
105
Drives: X5 G05 45e
This display key was in my wife's handbag. It hasn't been charged for 2 weeks now. still shows 2/3 battery ..
      02-12-2020, 03:43 PM   #17
Aimster82
Drives: 2018 X3 M40i 2019 BMW X5 5.0
You are sure the BMW X5 key goes to sleep after 60 seconds? My previous generation X5 was broken into using a signal repeater.
I always put my keys in the fridge or in a RFID blocker sleeve.
It would be nice if I no longer have to do this.
      02-12-2020, 03:54 PM   #18
X5 45e
1089
Drives: BMW X5 45e
I can't confirm that. I have read it in another post too . The only thing I can confirm is that the display key in the g05 holds it's charge much longer than my previous 6GT (2-3 days vs 2-3 weeks).
Can't find anything in the manual. I would presume if the function was present it would be mentioned or would state in the Q&A something like if your key doesn't work move it around.
      02-12-2020, 04:06 PM   #19
BMPHIL
BMPHIL's Avatar
619
Drives: 2024 M60i
Easy to check, put the key down next to the door and try opening using keyless entry after 60 seconds.
My GLE key goes to sleep after a period of time and you can also do this instantly by pressing the lock key twice, if you do this you have to press any button on the key to reactivate it.
      02-13-2020, 01:41 AM   #20
mitch57
805
Drives: 2020 BMW X7 xDrive40i
Do you have a link to a document that addresses this feature?
      02-13-2020, 03:24 AM   #21
X5 45e
1089
Drives: BMW X5 45e
"The models rated from Audi, BMW, Ford and Volkswagen not only have strong all-round security but have also made motion sensor enabled fobs available as standard when buyers opt for keyless entry and start," said Richard Billyeald, chief technical officer at Thatcham Research.
General article mentions bmw 1 and 8 and x6. Not the x5. On the other hand they mention all new BMW with comfort acces would have the feature
https://www.motoringresearch.com/car...ess-car-theft/
mcsa65.00
      02-13-2020, 02:26 PM   #22
Andyx5
Drives: bmw x5 3.0d
Carried out the key test tonight re the powering down after a minute without movement and yes it did go to sleep after 60 seconds. That’s great as I have also been concerned regarding theft with the comfort access My car was built in July 2019.
mcsa65.00
