      10-12-2018, 11:32 AM   #1
VTENGR
1053
Drives: 2020 X5 M50i
Harmon Kardon in 40i vs 50i
Seems like the HK upgrade is different depending on which engine your choose. Seems odd. The HK if the 40i is listed as 360-watt, 12-speaker system whereas the HK in the 50i is 464-watt, 16-speaker system. Why would they make them different?
      10-12-2018, 11:42 AM   #2
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
Both get the same system (as shown below). Its just standard in the 50i and an option on the 40i. Its the same item code (688) for both cars.
Harman Kardon® Surround Sound Audio System with vehicle-specific equalizing and powerful 464-watt amplifier; the 16-speaker system includes 7 tweeters, 4 midrange speakers located in the door panels and 2 midrange speakers located in the D-pillar, 2 bass speakers located under the front seats and 1 midrange center channel speaker
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1
Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i
VTENGR1052.50
      10-13-2018, 12:44 AM   #3
hk5er
97
Drives: I20 iX xDrive40i
Do you happen to know why the power dropped so much for G05? Am wondering if it's because the new electronics are drawing too much current from the car's battery so the audio power has to be downsized. Or anyone?
https://www.bimmerpost.com/forums/sh...php?p=23581785
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40
      10-13-2018, 01:25 AM   #4
maze446
Drives: 2019 X5 50i
Could be a lot of different reasons. Maybe more efficient speakers? Not sure why it would have anything to do with the battery since the alternator would power the amp when the engine is on. The B&W system has way more power and I can't imagine they use a different alternator if you get that option.
