2008 E90 Sedan Radio Issue
10-15-2018, 02:33 PM | #1 |
Rep 14
Drives: 328xi
Okay yesterday I removed the radio "Professional Model" to remove a stuck CD from when I bought the car CD never worked, upon removing I heard dings etc, took top off removed CD put Radio back in not working nothing on Screen and no dings noise, took back checked CD cable was off removed CD unit, now radio works but nothing on screen, phone still program and can work, but screen is amber. removed battery negative for 15 minutes came back still same result but had to reset everything else, clock etc, I do notice on the inside of the radio with the plug is in it has 2 optical plugs one is on the other is not, when taking out could I have pulled the harness out too far and disconnected one inside or am I toast, the CD is not important to me at this point, no door chime seat belt ding etc
10-15-2018, 06:06 PM | #2 |
Rep 14
Drives: 328xi
Please help or point me in right direction
10-15-2018, 07:00 PM | #3 |
198
Rep 709
Make sure you seated all plugs. Also post with model, year your car is and what is the type of radio, this will help others trying to figure it out.
There are so many types and combinations; it's not even funny. Last edited by gamesfrager; 10-17-2018 at 07:13 PM.. |
10-15-2018, 07:32 PM | #4 |
Rep 14
Drives: 328xi
2008 328XI Professional RadioThis is from my downloaded Dealer Spec sheet
S645A BMW US Radio S663A Radio BMW Professional S676A HiFi speaker system There is only one multi plug on the back with 2 fiber optic plugs 1 is lit the other is not, also noticed under the dash I removed to see if I unplugged anything there by pulling radio out, on the left upper corner of the cover I removed that and it has a plug there that has fiber also, and also 1 lit 1 not and I know they should both be lit, I ordered a fiber optic loop cable today to test if the module crapped out maybe I shorted it pulling the radio? |
10-15-2018, 08:54 PM | #5 |
1918
Rep 13,118
Suggest getting a used one on Ebay and getting it programmed
for the options in your car. (Hi Fi , bluetooth phone an usb if you have it) You didn't pull hard on any of the harnesses and used the lever on the main connector to release it? I hope! Since the Radio is the server for the Most Bus I don't see how buying a most bus jumper will help. |
10-17-2018, 05:57 PM | #6 |
Rep 14
Drives: 328xi
okay got the Most bus jumper, I found in the trunk under the middle mat 2 Modules used the jumper on the top one, still no ding or radio screen, tried the one under that one still no go, there is something on the left but I do not see fiber connected to anything, so next question, is there a module under the Dash area? and I did pull on the harness to get my hand on the lever then I pried the lever to release the connector the radio works blue tooth for phone also but no screen and still seat belt warning does not chime
10-17-2018, 06:52 PM | #7 |
1918
Rep 13,118
If the LCD screen on the radio is dead that should be the first thing you try
to fix. No sense in looking at modules in the back of the car when the basic radio functions don't work. Did you make sure all the cables where well seated when you put it back in? |
10-17-2018, 07:33 PM | #8 |
Rep 14
Drives: 328xi
yes all seated, just went outside and shined light thru cables the green side not shielded in black no light from the MOST port to the radio, did same from trunk modules no light on green side from anywhere I shine the light, bad cable? also inside radio you can see the 2 fiber connectors one has light the other doesn't is there a junction box with connector somewhere?
Also the LCD screen was working fine until I pulled the Radio out, not even a letter missing |
10-17-2018, 07:52 PM | #9 |
1918
Rep 13,118
You may have drained your battery working on the car this
can cause the IBS system to shut stuff down as the car stays awake when the doors and trunk are open or cell phone is paired. Other wise you need some way of verifying the radio. Since the fiberoptic loop connector contains both a source and return I believe you will only see one side lighted at a time if the loop is broken(meaning dissconnected or broken) Most http://www.e90post.com/forums/showthread.php?t=727663 http://www.e90post.com/forums/showthread.php?t=347222 https://www.google.com/search?q=BMW+...VCkMqy2aCK09M: http://www.1addicts.com/forums/showt...php?p=19256760 |
10-22-2018, 07:08 PM | #10 |
Rep 14
Drives: 328xi
Update after further research and other suggestion on it being my LCD purchased working radio on EBAY $60.00 from a 2011 popped it in and all is well and now have working CD too
