2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire questions f10. 550xi drive
      10-20-2018, 06:24 PM   #1
v8power550xi
Drives: 2013 bmw 550
I recently bought some rims and tires 19x8.5 all around I was looking at the car earlier and it seemed squared all around, some body told me I would not have enough traction, that I needed wider tires but I'm really confused about this I'm new to all this car stuff what kind of rear tires would I need for my 550xi f10[IMG][/IMG]
      10-21-2018, 01:44 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
The biggest issue is that 235/35-19 is way too short for F10, 5% smaller than OEM size.
245/40-19 would be OEM size, if you like slightly wider 255/40-19 will also fit on those wheels.
      10-21-2018, 12:44 PM   #3
v8power550xi
So I can go ahead and just change the tires all around to 245/40-19 and it will be better right ?
      10-21-2018, 12:57 PM   #4
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Yes.
      10-22-2018, 08:02 AM   #5
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
On a 550?!?!? You need way more tire under that car
      10-22-2018, 10:02 AM   #6
v8power550xi
What tires do u prefer on this car sir ??? Im looking to buy some good tires to put on my car today ....!!!
      10-24-2018, 01:29 AM   #7
NinetyEight740
2010 E91  [0.00]
Well the car should have a 275 on the back at minimum in my opinion. Msport would be a 275/35r19 but those won’t fit the wheels you have.
      10-24-2018, 01:30 AM   #8
v8power550xi
Well the car should have a 275 on the back at minimum in my opinion. Msport would be a 275/35r19 but those won't fit the wheels you have.
What wheels will I need ??
      10-24-2018, 01:46 AM   #9
NinetyEight740
2010 E91  [0.00]
9” wide wheel at minimum but 9.5 would be better imo
      10-24-2018, 01:48 AM   #10
v8power550xi
9" wide wheel at minimum but 9.5 would be better imo
So 9.5 inch wide wheels for back rear, I can still use the same rims?
      11-01-2018, 03:30 PM   #11
Ilanboy
Ilanboy's Avatar
Drives: 2014 BMW F10 N63TU 550i MSport
The xDrive 550i is not staggered in wheel size. both front and rear are 245 40 19. Well my 2014 xDrive 550i is not staggered
5post
