10-23-2018, 07:08 PM | #1 |
Rep 607
Lowered on 19s or get new 20s
Noob question
..I cant find much information on this topic.
If you had to pick between one or the other, would you? Lower and use spacers on your current 19s or buy new 20s without lowering. Any pics would be much appreciated.
Life is short...Drive fast
10-23-2018, 11:48 PM | #2 | |
12968
Rep 18,714
Going 20" from 19" won't reduce your wheel gap.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
540iSUP704.00 |
10-24-2018, 05:58 AM | #3 |
Rep 607
If I lower and use spacers on my current 19's will it look bad without 20's? There could be a large time gap before I can add 20's. Thanks for the help.
10-24-2018, 09:04 AM | #4 | |
12968
Rep 18,714
19" on the M sport just not cutting it. And if you get a spacer for the 19", it won't be the same thickness that you'll need on the 20".
10-24-2018, 03:28 PM | #5 | |
Rep 11
Brake_Late1937.50 |
10-24-2018, 03:30 PM | #6 |
Rep 225
Lower it with the 19s. Rather than buying twenties
10-24-2018, 03:33 PM | #7 |
Rep 225
Always lower. Even if you add 20s the gap is still there. I actually lowered mine myself. Took me less than a day. All you really need is spring compressors. That took the longest. Actually compressing the springs. The removal of the struts was easy.
10-24-2018, 05:28 PM | #8 | |
Rep 607
Thanks for the reply. I appreciate the advise.
r33_RGSport12967.50 |
10-24-2018, 05:41 PM | #9 | |
Rep 607
Thanks for the response. I agree the gap is an issue for me as well but in the long run the look I am going for probably won't cut it on 19's
11-16-2018, 06:27 PM | #10 | |
Rep 607
Considering this as my next move. Any thoughts RG? 20x9 +25 offset front and 20x10 +30 offset rear on this set of wheels https://g30.bimmerpost.com/forums/sh....php?t=1533594
11-16-2018, 09:25 PM | #11 | |
12968
Rep 18,714
You can check out my G30 mod thread. I think I have some pictures with that wheels on.
11-16-2018, 10:41 PM | #13 |
Delrosa81
59
Rep 251
Lower it and get 20s for the best look. Whether U keep ur 19s or get 20s, U need to maintain ur overall rolling diameter the sane. The gap gonna be there regardless whether its the 19s or 20s.
F20 LCi
11-23-2018, 12:55 AM | #14 |
Rep 9
20" looks better compared to 19" - but that's a (and my) personal opinion. If you like a sporty stance it's for sure looking better with 20s. The openings are not determined by the size - the height will be exactly the same (I would hope or you're going to have other issues). The width of the combination rim/tyre is determined by a number of factors like the ET-value and rim-width. You can have a 20" that creates a bigger space and stands less flush compared to a 19" wheel (look at the OEM wheels without spacers - ET 44 and 9x20 in the back won't give you a great result).
That being said - I've opted for 19" winter-wheels as in my part of the world 20" winter tyres are rather rare and if you unexpectedly need to replace one there's always the risk they are not available (for sure in the midst of the season or towards the end). For summer-wheels I've opted for 20" too for reasons mentioned above - and 20" summer-tyres are readily available all the time. |
11-25-2018, 06:39 PM | #15 |
Rep 12
Did the springs come with install instructions, or have you found a write-up? Can't seem to find info on springs DIY install for these cars. I work on my cars myself, but didn't want to run into an unforeseen issue.
11-28-2018, 06:49 PM | #16 |
Rep 225
No instructions came with the springs. The fronts are pretty straight forward. You do have Tom compress the old spring a little to get the strut out. The rears you need to take out rear seat c pillar and deck lid plus the seat belts.
11-28-2018, 06:50 PM | #17 |
Rep 225
I did mine myself on just a jack and some manual spring compressors.
12-23-2018, 12:43 AM | #18 |
Rep 12
Sorry, I guess I don't get notifications. Now in the heck did you break the rear lower shock bolt? It's stuck so hard on there it's deforming rather than loosening. If I put more pressure on it it just raises the suspension. I can't find a solid spot to put a bottle jack in to keep it from compressing. Arg, I need to finish this!
12-24-2018, 03:27 PM | #19 | |
12968
Rep 18,714
540iSUP704.00 |
03-06-2019, 11:52 AM | #20 |
Rep 140
