BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Opinions Please: Staggered vs Square tire setup
      11-09-2018, 06:09 PM   #1
HDEddie1
HDEddie1's Avatar
120
Drives: X5 40i, X3M40i, Audi SQ5
Asking for opinions on changing from staggered to square tire set up:
I have an incoming 540i M Sport that is wearing stock 19" wheel/tire set up at 245/40 and 275/35 19" run-flat, F/R 8"/9" wide , ET 30/44 respectively.
I'm thinking of changing out these wheels to BMW wheel 647M (see attached) 19" 8.5", ET 25 all-around, for both front and back. In addition, I would wrap them all in slightly bigger 255/40 19" non run- flats (yes!).
Basic calculator check shows rolling diameter difference negligible on speedo. The front wheel will stick farther 11.4 mm or almost 1/2" and the rear wheel about 12.7mm, a tad over 1/2". The biggest notice is the new rear wheel, which with the ET 25 offset and a bit narrower than the stock wheel is almost 1" farther from the suspension strut.
I'm doing this for: a) looks (not wild about the stock M sport style 664 wheels), b) wanted the wheels a bit more flush with the fenders without the use of spacers, c) maybe a tad more "cushion" staying with a 40 aspect tire (instead of 35 or 30 profile), d) and a bit more neutral handling afforded with square set up.
OPINION: Aside from skinnier appearing tires when viewed from the rear of the car, Im I doing something crazy or missing something here? Thanks!
Test
      11-10-2018, 02:05 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
That will be a very nice setup!
No issues.
      04-04-2019, 09:09 PM   #3
wyang828
Drives: 2018 BMW G31 530i
No issues.
No issues.
I like to get ET25 20x10 on my rear but not sure if that will rub or stick out too much.
      04-07-2019, 03:42 AM   #4
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
That is too aggressive!
      04-07-2019, 12:08 PM   #5
wyang828
Thanks for the feedback
5post
