BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Smoked Turn Signals
      07-09-2008, 04:23 PM   #1
cyphr
cyphr's Avatar
69
Drives: 08 335xi coupe
After custom fitting a sheet of tinted lamin-x to the front and rear signals for a few months, the thickness of the film (17 mil) started to get the better of me. Since the film was so thick, there was a very noticeable outline of where the lamin-x was placed and frankly, looked really cheap... so I decided to spray tint them
Now the directions for most spray tints i.e. VHT Night Shades instruct you to clean the surface of the lens then spray it directly on. This is all wrong and the final product will suffer greatly not only in terms of shine and finish, but also with durability. My car is a daily driver and here up in the Northeast, winter salt takes a toll on any unprotected finish. This DIY is how to spray tint that not only looks good, but will also stand up to the elements.
Time for DIY : ~2hrs
Parts needed
- 800, 1500, 2000 grit wet/dry sandpaper
- Blue painters tape
- Newspaper
- Soapy water (in both spray bottle and bowl)
- 2 cans Tint spray (I used a spray tint made by Tamiya found at most hobby stores. Two cans were plenty for the signal lights but if you're doing the entire lamp, buy more.)
- 1 can Clear coat (I used Tamiya clear. Again, buy more if you're planning on doing the entire lamp)
- Buffer (PC 7424)
- Medium and Fine Polishing compound (Menzerna IP & FPII)
Step 1: Mask
Mask the area you want to tint with blue painters tape.
Step 2: Surface prep
Dunk the 800 grit sandpaper into the bowl of soapy water, spray the area to be sanded a few times and begin sanding. Continue wetsanding while keeping both the area and the sandpaper well lubricated. Stop when you have sanded away the gloss. Note: That's soapy water in the Zaino bottle.
Step 3: Mask again (if necessary)
My sanding job ate away at the painters tape so I re-taped and masked a larger area with newspaper in preparation for paint.
Step 4: Painting
Not necessary, but a trick people like to use when painting with rattle cans is to lightly heat the can before spraying. This atomizes the paint better which allows for a more even coat. Do this by running the can under warm water for 5 seconds and then shaking the can. Repeat until the can is slightly warm after shaking. Caution: Do at your own risk. Heating a sealed canister with a propellant may cause the canister to explode. Warm water only. Don't think you can save some time by breaking out your heat gun . Paint using long even strokes. Start spraying before the area and end after. Remember to use lighter coats instead of thicker coats to prevent running. Allow 5-10 minutes in between coats. Stop when you have achieved the proper darkness. Apply the clear the same as you did the tint. Three coats of clear is sufficient.
After first coat
Since I wanted a darker tint, I sprayed an additional 6 thin coats. Here is a picture after the clear.
Step 5: Removing orange peel
The purpose of this step is to remove the orange peel that has occurred during the painting process. Gently wetsand beginning with the 1500 grit then work up to the 2000. It is especially important to keep the surface and sand paper wet during this step as the finer grit sandpapers tend to gunk up quickly. Your goal here is to remove the orange peel while minimizing the amount of clear removed. It may help to wipe down the area occasionally to make sure you aren't sanding through the surface layer.
If you don't know what orange peel looks like...
After sanding, your lights should look like this:
Step 6: Polishing
At this point, you're probably wondering why you just ruined your perfectly glossy finish. Before you send me an angry pm about how you just wasted an hour prepping and painting just to end up with a horrible product, break out your buffer. For this process I used combination of an orange pad with IP followed with a white pad with FPII, with an isopropyl wipedown in between products. Follow up with your favorite sealant and voila, you're done!
      07-09-2008, 04:52 PM   #2
i8_it
Feeling Blue.
i8_it's Avatar
Drives: I12 i8,f10 M5,e89 IS,F1 6S35i
2008 E93 M3  [5.36]
nice write up i just decided to remove my tail light tints yesterday, because of the lack of gloss.. i wish i read this earlier
      07-21-2008, 08:19 AM   #3
dreamk
Dominican Republic
122
Drives: 335i
2007 e90 335i  [0.00]
A+. wait if i don't own a pc? wat can i use?
      07-22-2008, 03:50 PM   #4
cyphr
cyphr's Avatar
69
You can apply most polishes by hand as well.
      07-23-2008, 02:20 AM   #5
simp0man
Not looking 2 SPEED, just looking GOOD
simp0man's Avatar
Cambodia
45
Drives: 07 328i
2007 328i  [0.00]
That is good to know, didn't think of that.
      07-25-2008, 03:34 AM   #6
Sam12345
Sam12345's Avatar
106
Drives: jet black 335i coupe
2008 335i Coupe  [0.00]
is this removable?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      07-25-2008, 11:25 AM   #7
cyphr
cyphr's Avatar
69
Originally Posted by Sam12345 View Post
is this removable?
Yes, the spray tint I used is lacquer based so any lacquer remover should remove it completely.
      03-20-2009, 05:07 PM   #8
karlytobmw
BMW 328
karlytobmw's Avatar
Lithuania
Drives: BMW 08' E90 328 Alpine White
Thanks, great DIY!
      03-24-2009, 01:31 AM   #9
Tommy350
Tommy350's Avatar
Drives: 08' Mercedes CLS63
the side markers look great!... is the light output the same? after tinting/ smoking them?
~*RELUX Brands/ Company's in the making*~
06' Smokey Granit Lexus IS350....SHADOW....~*SOLD*~
08' Titanium Silver e92(335i)....SILVER SURFER....
09' Black w219 cls63amg... The Rocketeer....
http://tommybooyyyy.wordpress.com/
      03-24-2009, 09:10 PM   #10
cyphr
cyphr's Avatar
69
Yep, the light output is essentially the same.
      04-18-2009, 02:05 PM   #11
rubber_ducky
rubber_ducky's Avatar
383
Drives: roach coach
Great DIY.
Just picked up some VHT nite shades and intend to do this. One question... how long did you let the clear cure before wetsanding/polishing?
TIA
      05-01-2009, 05:38 PM   #12
cyphr
cyphr's Avatar
69
It depends on the clear you use. It can be anywhere from a couple to 4-6hrs depending on the product/weather conditions.
      05-01-2009, 05:42 PM   #13
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
nice info to know
      05-06-2009, 09:23 PM   #14
951's 330i
951's 330i's Avatar
Mexico
92
Drives: E90 330i, 95 RB-S14
Going to do this either tomorrow or the next day. So if we dont have a buffer we can still do it by hand right?
2006 E90-Running like brand new again. Take that insurance company
95 S14-Sold
95 S14 Rb25det-Vrom Shhh
      06-13-2009, 05:11 PM   #15
Aramel
Aramel's Avatar
Drives: 2008 323i
Could you be a bit more detailed about this. I'm unsure about what type of polishing compound you're talking about as well as sealant. Thanks,
      06-13-2009, 05:35 PM   #16
cyphr
cyphr's Avatar
69
Originally Posted by Aramel View Post
Could be be a bit more detailed about this. I'm unsure about what type of polishing compound you're talking about as well as sealant. Thanks,
Menzerna Intensive Polish (IP) is basically a medium strength polish. Menzerna Final Polish II (FPII) is a light strength polish. You don't have to use only Menzerna polishes though; any brand medium polish followed by a light polish will work just the same. For sealant, top it with the wax/sealant you would normally use on the rest of your car. Hope this helps!
      05-02-2014, 06:19 PM   #17
WapArtist
WapArtist's Avatar
Drives: 2008 328i Sedan Sports
I am not finished with this. Tomorrow I will smooth this down and possibly clear coat if you think that makes sense. I had rain approaching within a few hours and had to get the assemblies back in plus I wanted it to cure back at my garage. Was my first time and I went one coat too dark but it still works
2008 E90 328i Sport Sedan
335 189 wheels/Eibach Pro-Kit/H&R 10&12mm/K&N/Charcoal delete/LED
Past:2012 R56 MINI S/1992 E34 525i/1989 E30 325ic
      05-03-2014, 10:44 AM   #18
GR33NMACH1N3
Drives: 2007 335i coupe
Didn't know you could get it to shine like that! Thanks!
      05-03-2014, 04:09 PM   #19
WapArtist
WapArtist's Avatar
I actually did the 2000 grit today and hit with final Polish by hand. Then 4 clear coats lacquer only. When that cures I will repo list with machine.
Here is an experiment I did today from SlickMod. It is 20 or 35% tint that is precut. And can put on using the wet method. Very cheap way to change it a little and totally removable. If doing again I would use a hair dyer and maybe wrap the curves but overall I like it.
