BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Recommend tire pressure for rear tires?
      11-10-2018, 08:07 PM   #1
boonkgang13k
Drives: 530e
My 530e's rear tires are currently at 38-39 psi, but the recommended psi shown on the screen is 45 psi. They were set to 38 by the tire shop technician. So should I go with the BMW recommendation or the technician's?
      11-10-2018, 08:29 PM   #2
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
I would go by the pressure printed on the sticker inside the driver's door.
      11-11-2018, 12:31 AM   #3
omera60
omera60's Avatar
Turkey
195
Drives: 218i Coupe
Always go by the manufacturers recommendation that is on the sticker, remember they are the ones who built your car so they know it the best. In the olden days tire pressure were more or less the same (especially where I live) and you didn’t have a lot to go with so old mechanics even today still go with the “standard pressure” they have. Just a reminder, adjust them when the car is cold (shouldn’t have covered more than 2km from the start, if they are hot wait 2 hours for them to cool down).
      11-11-2018, 12:35 AM   #4
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Try 100
      11-11-2018, 02:19 PM   #5
jadatis
Drives: No BMW
Advice on plate on car is for fully loaded, and nowadays for rear an overloading is taken into account. So this is verry high,and comfort and gripp is totally gone when you drive allone ,wich is 99% of use.
So even 38 psi can be on the high side.
I am able to calculate a safe lowest pressure for the weights on tires and maximum speed used( and wont go over for even a minute).
Pressure advice is to give the tire a deflection that wont overheat any part of tire when driving the maximum speed used constantly.
Once a part of tire has been overheated long enaugh, the damage is ireversible, and every next deflection crackes the beginning cracks fuether, untill mayby only after 3 years the damage is that much build up that the tire blows, and accident and injuries. Then the moment of damagestart is already forgotten.
      11-16-2018, 02:44 PM   #6
Jelston
Drives: 2018 Bmw M550xi
Also to add for every 10degrees is one psi. so to the point of adjusting them cold. i am not sure about your car but mine will display the temp at the wheel. so as an example say in the morning temp is low. as the day progresses and temp increases say by 40. and you have been also driving the car and with alot of breaking this will increase temp. and then the warning lamp will come on
      12-02-2018, 04:50 AM   #7
BudgieUK
United Kingdom
38
Drives: BMW 520d M-Sport Touring
To add more confusion ....
My car has different tyres at the front and rear. (F = 245/40 R19, R = 275/35 R19).
In iDrive, there is only an option to select a single tyre size type (19 inch).
If I select Winter/all season, then the pressures shown in iDrive are different to the pressures shown on the sticker. If I select summer tyres, then the numbers agree.
So do I go for the sticker pressures or the iDrive pressures ... if I go with the sticker pressures, iDrive keeps telling me I need to check the tyre pressures!
      11-05-2021, 04:51 PM   #8
choppedliver
Drives: 2020 M550ix Pure
Reviving this thread. Just checked the tyre pressures on my 20” tyres on an M550i. 39psi front and back for normal load. Loaded up it recommends 45psi front and 51psi rear. Wow that seems very high to me.
Has anyone run the car fully loaded and those pressures?
      11-10-2021, 05:04 AM   #9
Joe-BMW33
Joe-BMW33's Avatar
7041
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
I run my M550 non-rft summer tire set up at 38/42 per the manual for normal load.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
      11-10-2021, 08:01 AM   #10
fly@night
fly@night's Avatar
Drives: 2019 M550i
Same here, and I have RFT Pirellis for summer, Michelin Alpins non-RFT for winter.
      11-10-2021, 08:05 AM   #11
Joe-BMW33
Joe-BMW33's Avatar
7041
2021 BMW X5  [0.00]
You are really missing out in summer! Pirellis suck in general, so Pirelli runflats must REALLY suck.
When they wear out, get yourself some summer softy Michelin PSS or PS4S's. You will love them coming from Pirelli runflats.
5post
