      11-10-2018, 08:25 PM   #1
baseballD
Drives: 2018 530i, 2019 X5
Do old model wheel locks work for 2019 X5?
Mine is 21'' , and the BMW part store sold me a set of old model wheel lock that he said works for the 2019 X5 as well. I put them on, but still not comfortable.
      11-10-2018, 08:27 PM   #2
jra0113
jra0113's Avatar
Drives: 2019 X5 xDrive 50i
2019 BMW X5 xDrive50i
2017 F150 King Ranch
1967 Camaro Pro Touring
      11-12-2018, 04:20 AM   #3
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
Is that a yes??
      11-12-2018, 01:55 PM   #4
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
so the bolt pattern changed but BMW is still using m14 x 1.25 bolts.
I know my E90 has M12 bolts so I guess the real question is how old are your wheel locks or which model did you use previously.
      11-28-2018, 10:04 PM   #5
F1 Pilot
13
Drives: '19 X5 M Sport '21 335x M sp
I spoke to my knowledgeable BWW parts manager who told me he looked up the part number and that my 2016 X5 bolts would fit my 2019 w 20's M sport brakes.
I picked up the car today and I put the McGards from my 2016 X5 on the 2019 and they fit perfectly.
      02-19-2019, 08:58 PM   #6
kanvit198613
Drives: 2013 X5, 2019 X5
Hey everyone,
Just got my new X5. Tried to install wheel locks but did not find a took kit. Everyone has theirs? Nothing in the manual about it....
Thanks!
      02-19-2019, 10:49 PM   #7
BMW168
BMW168's Avatar
76
Drives: 2004 X5, 2019 X5
Originally Posted by kanvit198613 View Post
Hey everyone,
Thanks!
No, my X5 did not come with tool kit or first aid kit in the US. I think Europe market will have them.
You will get a tire wrench and jack if you ordered the Spare Tire option.
you will need a 17mm socket, extension and a torque wrench that can handle 105 ft-lb.
      02-19-2019, 10:53 PM   #8
Hchhuor
Drives: 2016 LX570
I received first aid kit with my x5.
      02-20-2019, 07:28 AM   #9
kanvit198613
Thanks very much for the info. Can you also tell me if those will fit:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I heard that 2013 X5 locks will fit 2019 model so I got those.
Thanks!
      02-20-2019, 09:20 AM   #10
rmorin1249
rmorin1249's Avatar
817
Drives: 2019 X5 MSport 40i
I tried putting the locks from my F10 on the X5 but the original bolts have a spacer on them. The locking bolts do not. What are the specs for the proper locks?
Added: McGard website lists the size as M14 x 1.25 for both the 2016 5 series and the 2018 X5. No listing for the 2019 models. I was hesitant to use the ones from my 5 series and not sure what to do about the spacer that is on the OEM lug bolts.
COL(Ret), US Army Hagerstown MD
2019 X5 40i MSport Alpine White/Coffee (my 13th BMW)
2015 Mercedes SL400; 2009 Lexus RX350
      02-20-2019, 09:25 AM   #11
rmorin1249
rmorin1249's Avatar
817
Added: McGard website lists the size as M14 x 1.25 for both the 2016 5 series and the 2018 X5. No listing for the 2019 models. I was hesitant to use the ones from my 5 series and not sure what to do about the spacer that is on the OEM lug bolts. I need to see if the length of the OEM bolts is the same as the locks.
      02-20-2019, 10:21 AM   #12
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
My old F15 locks don't fit my G05 correctly. They'll tighten up, but there's a huge gap around them showing the bare aluminum.
It's good to be bad
      02-20-2019, 10:36 AM   #13
Hchhuor
Drives: 2016 LX570
I bought this wheels lock part number
36 13 2 453 961
      02-20-2019, 12:01 PM   #14
rmorin1249
rmorin1249's Avatar
817
These look right. They have the spacer like THE OEM bolts.
      02-20-2019, 12:26 PM   #15
baseballD
Mine is 36 13 2 453 961 , good fit
      02-20-2019, 01:20 PM   #16
BMW168
BMW168's Avatar
76
Thanks!
They are the correct thread size but I can not tell how well they fit on the wheel without the spacer.
seems like the correct P/N is 36 13 2 453 961 per the latest posts.
      02-20-2019, 02:35 PM   #17
BMW168
BMW168's Avatar
76
The wheel lock bolt kit I bought has the same P/N 36 13 2 453 961 as Hchcuor's set, manufactured in Sept 2018.
But does not have the spacer as Hchour's set !?
      02-20-2019, 02:37 PM   #18
BMW168
BMW168's Avatar
76
The wheel lock bolt without spacer will fit tight in the cone shaped wheel well because you can thread it in further then the standard bolt.
However, I notice that after hand tight, I have to turn the standard bolt with spacer more to achieved the required torque.
So fiction between the cone shaped wheel well and wheel lock bolt without spacer may affects the torque requirement ?
I put the standard bolts with spacer back on for now.
      02-20-2019, 02:38 PM   #19
rs4eva
Drives: bmw
I just found wheel locks in my trunk. Not sure if my CA put them there or they came with the car. He's hooked me up with a bunch of ///M goodies so far.
      02-20-2019, 02:43 PM   #20
BMW168
BMW168's Avatar
76
36 13 2 453 961
Just realize that your picture only shows the standard OEM bolts. Did your wheel lock bolt set has spacer ? ?
      02-20-2019, 02:45 PM   #21
BMW168
BMW168's Avatar
76
Do they have spacer like the standard OEM bolt ?
Can you post a picture of the wheel locks that your CA gave you ?
      02-20-2019, 03:10 PM   #22
Hchhuor
Drives: 2016 LX570
It’s same one you have.
