11-19-2018, 01:42 PM | #1 |
621
Rep 390
Rust under center wheel cap
Someone stole one of my center wheel cap (the bmw logo in the center of the alloy wheel)...
That revealed a fair amount of rust where the center axle meets the center of the wheel alloy... I'm just wondering if that is something to worry about or just ignore... While the center caps are tightly in place i don't think it's meant to be... water tight or anything... ? Should I worry about it ? |
11-19-2018, 02:05 PM | #2 |
Rep 2,956
Just ignore as the hub spigot is steel and steel rusts. It's going rust to depend on your part of the world, winter, humidity, ect. Maybe in the desert or Calfornia you can go a long time without getting rust there but most other places it's hard to avoid.
AndrewC198910931.00 thaalrasha621.00 |
11-19-2018, 02:30 PM | #4 |
844
Rep 1,962
Separately. Those things only come out without damage if hit from behind by a blunt object.
Have you considered going for a drive with your jacket turned inside out? I'm not sure what you did, but it might help... |
thaalrasha621.00 |
11-19-2018, 02:59 PM | #5 |
621
Rep 390
Thanks for your insight guys. I'm in a country where it rains 340 days a year so i suppose it's prone to more rust than California ^^ I'll need to change the rear tires soon anyway since those tend to wear down fast for some unknown reasons
11-19-2018, 03:25 PM | #6 |
Rep 442
thaalrasha621.00 |
11-20-2018, 04:43 PM | #7 |
Rep 4,551
Drives: 2015 328d xDrive
Doubt anyone stole it, they are ridiculously difficult to remove without taking the wheel off. It probably just fell out.
Like others have said the rust is unavoidable so no sense in fighting it. Just replace the cap and you won't see it. |
thaalrasha621.00 NYC Bimmer259.50 |
12-10-2018, 01:11 PM | #8 |
Rep 3,402
Since you live in a climate with lots of moisture it would be good to at least once a year take the wheels off and as stated hit those hubs with a wire brush. The rust can really build up and make the wheels really hard to remove. I have had to pound the rear wheels off my 3 series because of the rust and I live in one of the driest climates in the USA .
thaalrasha621.00 |
04-01-2019, 11:11 AM | #10 |
1287
Rep 1,675
04-04-2019, 06:49 AM | #11 |
323
Rep 392
04-13-2019, 07:40 PM | #13 |
Rep 817
04-20-2019, 09:01 PM | #14 |
Rep 3,951
BMW doesn't believe in coating the hubs just like when they stopped coating the brake parts years ago. My hubs were bleeding rust with only a couple hundred miles so like all my other BMWs I took care of it. I also do the vents.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
