M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2C st2 dyno
      11-22-2018, 03:08 PM   #1
CrazyK
Drives: M2C
M2C st2 dyno
SUB-ZERO293.50
b18flip130.50
      11-22-2018, 03:09 PM   #2
CrazyK
Drives: M2C
587hp 498whp 730nm
Appreciate 5
M-Pilot4859.00
Robin_NL8717.00
Bee Pee1779.00
BlkSVT388.50
      11-22-2018, 03:14 PM   #3
CrazyK
Drives: M2C
Bm3 ots st2 93 pump + vfrs downpipes
      11-23-2018, 03:58 AM   #4
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Wow.
Does your car have the OPF? Probably not.
Welcome here btw.
Cheers
Robin
      11-23-2018, 04:05 AM   #5
Lukeni
Drives: BMW M2
Originally Posted by Robin_NL View Post
Wow.
Welcome here btw.
Cheers
Robin
Surprisingly Stg2 with opf puts down similar numbers. We dynoed one with 800nm and 560hp at the crank - without any hardware mods
Robin_NL8717.00
      11-23-2018, 04:08 AM   #6
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
OP,
Impressive numbers from DP and BM3 OTS remap - well done.
That much power/torque in SWB RWD must be quite a handful to drive at above 5 or 6/10ths.....
BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      11-23-2018, 04:24 AM   #7
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
I want the BM3 stuff badly, but I'm a bit of a IT/computern00b, so I'm a bit scared of doing that myself with laptops and stuff...
Cheers
Robin
      11-23-2018, 05:07 AM   #8
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2020 BMW M2 Comp  [0.00]
2020 BMW X3M Comp  [0.00]
2011 BMW 1M  [0.00]
Going by the pictures of the Primary cats he has removed it doesn't.
EU spec'd cars with OPF's fitted have additional pipes attached to EACH primary cat that connect to two sensors. These sensors monitor any blockage to the OPF's/increase in back pressure to the end of the primary cats
Pictures below are his primary cats, non EU spec and an image showing the additional pipe on the primary cat. That cat is a M140i cat but Im using it to show thats the same kind of pipe fitted to each primary cat on our OPF M2C's)
      11-23-2018, 05:21 AM   #9
CrazyK
Drives: M2C
Wow.
Welcome here btw.
Cheers
Robin
Well honestly, I do not know what is OPF is) But I can second cats before the mufflers. I will attach photo from the phone.
And thank you)
Originally Posted by Bee Pee View Post
OP,
BP
It is a big joy to drive after the remap, feels like the cars was missing those 200hp))
Cheers
Robin
Nothing difficult at all! Take around 10 mins to set up. Can help you out with team-viewer)
      11-23-2018, 05:26 AM   #10
CrazyK
Drives: M2C
Highlighted black what is still on the car, waiting for Akra «
M2C_PLUS1774.00
      11-23-2018, 05:36 AM   #11
n55co
Germany
41
Drives: G80X BSM
The torque dip at 2500 rpm looks strange to me.
The car is without OPF (US-Version) as the OPF is looking different
M2C_PLUS1774.00
      11-23-2018, 05:46 AM   #12
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
Yep, see my post a few up.
On EU spec cars each primary cat gets a pipe that goes to sensors monitoring the OPF's to make sure they do not get blocked. If they do, then the car goes in to limp mode.
      11-23-2018, 05:47 AM   #13
M2C_PLUS
M2C_PLUS's Avatar
1774
Drives: BMW 1M
2011 BMW 1M  [0.00]
Originally Posted by CrazyK View Post
Highlighted black what is still on the car, waiting for Akra "
Thanks, your car is WITHOUT OPF's and has the standard S55 secondary cats you circled.
      11-23-2018, 06:06 AM   #14
CrazyK
Drives: M2C
Just got it, after looking at your picture!! Thanks!
M2C_PLUS1774.00
m2
