11-26-2018, 10:21 PM | #1 |
31
Rep 42
Steering intervention nearly killed me!
Tonight I was driving in the left lane (relevant) on a four-lane divided rd. The divider is the typical LV desert landscaped type. Basically rock and a few shrubs. Anyways... I was driving perfectly straight approaching the end of one divider to allow traffic to cross to the other side. As I approached the beginning of the next divider at approximately 45mph the steering intervened for no apparent reason and I found myself pointed squarely at the curb and a light pole. I didn't have an extra tight grip on the wheel, just enough to safely cruise on down the road. I immediately corrected back to the right into my previously occupied lane. Scared the hell out of me and my unsuspecting wife. Not to mention the other drivers surrounding me. Had I not reacted fast enough with a considerable amount of force we would have jumped the curb into the pole. Has anyone else experienced anything like this? Yes, I went back and checked for any erroneous lane markings or other striping that I sometimes see painted around here indicating construction pending or past. Thanks!
11-26-2018, 10:29 PM | #2 | |
Rep 294
'13 Raptor (sold); '14 Raptor (sold); '15 A6 Quattro (sold); '19 X5 xDrive 40i (sold); '20 4Runner TRD Pro (sold), '22 MDX A-Spec (sold); '22 MDX A-Spec (sold); '24 X5 M60i
11-26-2018, 10:31 PM | #3 |
Rep 668
Yes, I had a similar experience driving the car 3 hrs home after buying it. I drove on a long stretch of divided highway that is massively under construction. In several sections, traffic is diverted off of existing concrete pavement onto temporary pavement and back again. At these break points, the joints in the concrete aren't in line with the lanes, and the X5 would read those joints as lane markings and try to aggressively pull you out of your lane in the midst of these diversions. I held the wheel with a death grip the whole time.
Afterward I found the setting in iDrive to turn down the sensitivity. It seems to be better but still will act overly aggressively at times. |
11-26-2018, 10:36 PM | #4 |
Rep 74
This is one thing that scares me about increased vehicle autonomy. If lanes are marked well it can cause some vehicles to act strangely. In my XC90 the lane keep won't activated if it can't clearly identify markings, this isn't the case in some other cars I've driven. However, there was one time when I was making a u-turn and the car thought I was gonna turn left into opposing traffic which cause the emergency brake to activate which caused me to almost get rear ended. The driver behind me also thought I intentionally brake checked them. The whole situation was bad.
11-26-2018, 10:56 PM | #5 | |
Rep 3,406
I'm confused by your post busting this guy's chops for starting a new thread instead of searching for an existing thred on this topic. I've been scouring this G05 forum for weeks as I get ready to make a purhcase. I've seen zero threads specifically on dangerous lane departure. I did as you asked the OP to do and searched the G05 section for such a thread and found none. Would you please enlighten us and share a link to the dedicated G05 thread on this topic. Thanks. |
11-26-2018, 11:01 PM | #6 | |
Rep 3,406
Dcinlv31.00 |
11-26-2018, 11:10 PM | #7 |
Rep 668
I forgot to add earlier that I previously drove a GMC Yukon. It also had a version of lane keep assist, and I would say its execution in that vehicle is perfect. Its intervention was very subtle, with very gentle corrections once you've basically grazed the lane markings. It would nudge the steering wheel so that you would basically ride the line instead of cross it, and it would never come close to overpowering the driver.
The X5 by comparison, even on the lowest setting, is much more aggressive. I've noticed its corrections can be so aggressive that it will make you actually sway in your seat as if you had jerked the steering wheel. |
Dcinlv31.00 |
11-26-2018, 11:49 PM | #8 |
31
Rep 42
11-26-2018, 11:59 PM | #9 | |
31
Rep 42
11-27-2018, 12:13 AM | #10 |
162
Rep 360
I would expect this would be corrected with future updates. Our audi q7 is a little jerky also but in my brothers tesla its straight down the center of the lane only moving over if a car is next to us. It did take us a while to get accustomed to the q7. Is it possible that some folks are just not used to the car applying inputs. I know i wasnt when we got the q7. Having a car steer and brake by itself is a bit to get used to. It did save my but over the weekend when i backed out of a parking stall and i didnt see a car crossing and the q7 locked the brakes. Also if we make a u turn we need to have the left turn signal on letting the car know to ignore what were doing. Keep in mind my experience is with the audi.I have a build week 49 so i will be able to compare in a few months.
11-27-2018, 02:48 AM | #11 |
Rep 8
Had a similar issue - intervention almost pushed me out of the highway when two lanes were merging. Closed all steering interventions immediately after that. I only use the vibration warning and that is more than enough.
I bet BMW will get sued over an accident this will cause pretty soon. |
bigdaveindubai208.00 Dcinlv31.00 |
11-27-2018, 06:25 AM | #13 |
Rep 66
Thank you for posting regarding a significant safety issue that everyone thinking about ordering the driver assistance should be aware of.
Personally, I find these posts disappointing and worrying. It seems BMW is way behind in its autonomous driving tech. I have used a similar system in a rental XC-90 and it worked well. |
11-27-2018, 06:32 AM | #15 |
Rep 5,448
This is very disappointing especially at the price they charge - Toyota gives it to you for free and sounds like it works better at that price also.
I wonder what happens when it does this and crashes, BMW should be responsible for that liability - guessing they have a lot of lawyer speak around that in the manual, but if it is a flawed technology and a few cars crash because of it, there will be a class action lawsuit for sure. Bet it works much better in Germany where the roads are better marked and maintained - not sure how anything self driving will ever work in the US with the disaster we call a transportation infrastructure.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
11-27-2018, 06:42 AM | #16 |
208
Rep 328
We talked about it here. It almost killed us too.
https://g05.bimmerpost.com/forums/sh....php?t=1556127
2018 540i
2019 X5 xDrive40i 2012 Boss 302 #2147 2017 Shelby GT350 2017 F250 KR |
Dcinlv31.00 |
11-27-2018, 11:27 AM | #17 | |
Rep 3,406
lumpydog690.50 bigdaveindubai208.00 |
11-27-2018, 11:43 AM | #18 | |
Rep 978
Here is another thread that touches on this subject but was not specific to it: https://g05.bimmerpost.com/forums/sh...0#post24034550 |
11-27-2018, 02:44 PM | #19 |
Rep 2,703
this reviewer shuts it off
Not sure where in the review, but I think as soon as he starts driving it he said he shuts it off (lane assist), he is fine with all other automated driver stuff.... Am sure BMW will have to change it. |
bigdaveindubai208.00 lumpydog690.50 |
11-27-2018, 03:29 PM | #20 |
Ring Leader of G8X Haters
25083
Rep 8,762
Another reason while I think some safety tech is good, like blind spot, auto braking, the whole lane keeping thing is a little overkill, I mean part of driving the car is well... driving, and paying attention to the lane your in. God sometimes I wish we were back in the golden era of the 2000's when the biggest and most advanced safety features were parking sensors and DSC in BMWs!
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
bigdaveindubai208.00 Wild Blue3683.50 |
11-27-2018, 09:35 PM | #21 |
Rep 421
Glad I read this post before I took delivery of mine tonight. It is a pretty aggressive steering wheel correction. Def. would have been caught off guard if I wasn't looking for it.
2019 BMW X5 xDrive50i
2017 F150 King Ranch 1967 Camaro Pro Touring |
11-27-2018, 10:03 PM | #22 |
Rep 831
OP glad you are OK. This autonomous driving nonsense needs to stop. Let owners decide if they want it and allow them to turn it off. When I first heard that BMW turned on aggressive lane correction by default, I couldn’t believe it.
All car companies are trying one up each other with these “safety” features. The realty is they are full of false positives and hiccups that will get people hurt (ask Tesla). And I thought the collision control in my F15 was brutal. It gave me a nice whiplash on a false positive. |
Tags |
steering and lane control assistant |
