      11-29-2018, 05:06 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
Drives: F90 M5
IND | G05 X5 Painted Front Reflector | Installation Procedure
GENERAL NOTE: This method was created for a true garage DIY with minimal intrusion to OE equipment. The proper method would require a much more comprehensive set of instructions and additional tools (rivet gun, etc).
Step 1: Start the vehicle and turn the wheel to the opposite side of which you intend to work. This will grant you easier access to the fender liner.
Step 2: Remove the two 8mm fender liner bolts aft of the reflector and pull the liner loose.
Step 3: Carefully pop the painted fender arch from its housing. There is no need to remove this piece completely; where the front bumper meets the fender is good enough.
Step 4. Use a heat gun to apply uniform heat the OE reflector. This will soften the adhesive that holds the reflector in place. Please take note to keep the heat gun moving during this process to ensure no paint damage (burning) occurs.
Step 5: With the reflector area properly "warmed up", use your thumbs to depress the OE unit while using your other fingers to simultaneously pull on the surrounding bumper from the inside of the fender liner. We've found it easiest to work from the bottom first.
Step 6: Once the bottom of the reflector is freed from the bumper, you may slide a bondo spreader between the fender liner or "outside in" and pull it upwards to help release the adhesive.
Step 7: With the reflector now completely free, you will need to slide it out from the bumper. Pull the bottom of the reflector down and towards you. This will pivot the top of reflector toward the front of the car. From here, you are able to work the reflector out through the fender liner.
NOTE: If you attempt to pull straight down instead of pivoting, it's likely that the + shaped retaining tab on the back of the reflector will get stuck on the plastic ducting element.
Step 8: Occasionally, all of the OE adhesive doesn't come out with the reflector. If some adhesive still remains, take some time to remove it completely from the inside of the bumper. This will ensure a uniformly flat contact area for the IND reflector replacement.
Step 9: Expose the adhesive on the IND painted reflector replacement.
Step 10: Going from the "outside in", insert the IND reflector and position it properly. With uniform pressure behind the fender liner, adhere the IND reflector with the bumper. Similar to Step 5, you may also use your other hand to press the bumper edge forward creating a "sandwich effect" to ensure full adhesion.
Step 11 (optional): Use a hand-held polisher to finish the front reflector.
Step 12: Re-insert the OE fender arch trim, ensuring proper tab alignment prior to pushing it into place.
Step 13: Re-fasten the fender liner and install the 8mm bolts removed from Step 2.
Step 14: Repeat this procedure for the other side.
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
Appreciate 6
      11-29-2018, 06:06 PM   #2
r33_RGSport
r33_RGSport's Avatar
Drives: 997.1 C4S / F39 X2 / F97 X3MC
Great work!!!
Much easier than F15/F16 F85/F86.
      11-29-2018, 07:08 PM   #3
M3 Chris
M3 Chris's Avatar
33
Drives: 991.2 GT3 RS, X5 40i
Perfect. Once you guys get the blacked out kidneys ready for sale I'll purchase everything all at once.
      11-29-2018, 07:39 PM   #4
avengerboater
Drives: 2019 X5 xDrive40i
Awesome! Thanks for the installation guide and pics! I'm receiving mine in the mail tomorrow, about 3 weeks before the actual car arrives.
      11-29-2018, 10:57 PM   #5
bizfiend
bizfiend's Avatar
133
Drives: Renting Corolla lol
      11-30-2018, 01:03 AM   #6
Jrunr
Germany
161
Drives: 2019 BMW X5 M40i - G05
Awesome. I already have mine sitting here and I don't eve have the X5 yet! LOL
When will you have the blacked out grille ready for sale? Please let me know ASAP!!!
Thank you!
      11-30-2018, 04:14 AM   #7
denniss
denniss's Avatar
Drives: 2019 X5 40i M Sport
What about rear reflectors ?
2019 X5 40i M-Sport
2018 RANGE ROVER VELAR R-DYNAMIC HSE P380
2016 X5 35i M-Sport (sold)
      12-04-2018, 02:52 AM   #8
bizfiend
bizfiend's Avatar
133
They're available now.
https://g05.bimmerpost.com/forums/sh....php?t=1560249
      12-27-2019, 11:32 AM   #9
vicfalc09
vicfalc09's Avatar
183
Drives: M340i xDrive
Just completed my install and it is much harder then it looks in this write up. The + tab on the reflector makes it very difficult to maneuver into position. I do not see how they could have gotten the reflector in place going outside in. There is just not enough room to wedge the reflector through the outside.
      12-27-2019, 07:40 PM   #10
martinf79
martinf79's Avatar
139
Drives: 2020 G05 X5 M50i
Yeah ... I did the install 2 months ago... thought it would take me 30min... took hours. The first one took about 2 hours to install. Like you said, getting the new painted reflector installed from the outside-in was near impossible. I finally figured it out, but most frustrating install I've ever had to do. You would think they would show a more detailed instruction/visual on this step given how difficult it is. Once I figured out how to get it in, the other side only took me 20min or so.
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
vicfalc09182.50
      12-27-2019, 10:08 PM   #11
vicfalc09
vicfalc09's Avatar
183
I actually never figured it out and cut the + tag off. How did you get it in?
      12-28-2019, 10:11 AM   #12
martinf79
martinf79's Avatar
139
The reflector has to be positioned downward first and inserted and then you have to pull the shit out of the top of the wheel well (the part that's been separated from the car) to create enough clearance behind it to insert the top part of the reflector and the tab to pivot. You have to pull on the wheel well piece almost like you're trying to rip it off of the car.
      12-28-2019, 10:52 AM   #13
KDDI
Drives: 2019 G05 50i M-Sport
2019 X5 50i  [0.00]
Just wonder is this legal in the USA to remove yellow reflectors?
      12-28-2019, 11:20 AM   #14
polychromatic
polychromatic's Avatar
Drives: E30, E44, E61, E07
Dunno, I changed out the orange to clear/white on my Carrera and M3, and no one noticed after multiple state inspections. Note these were relatively small reflectors compared to the X5’s and I think the orange stands out more on white body color.
      02-17-2020, 07:30 PM   #15
seanyo
seanyo's Avatar
14
Drives: 2016 X5
I took a stab at this install today. I must say that I thought it was easier to do on my F15 given that there was more room to work with behind the fender. It took me over an hour for the first side and less than 30 minutes for the second. 2 time saving tips that I learned while working on the first side is to buy 2 rivets and remove the ones that hold an internal plastic liner tight against the fender. I have marked up the IND pic to show the rivet location. The second is when removing the fender flare, the bottom vertical tab actually points straight down on the inside so its best to bend it up from inside the fender liner and push it out from there. The other fender tabs after that are accessible by hand and are easy to get out once the bottom tab of free.
I have include pics of the before and after too (sorry they are sideways...). Overall I love the look these reflectors, much more than the small cuts on my hands so I'd say the time and effort was worth it.
      04-06-2020, 01:57 PM   #16
Milangel
Drives: 2020 BMW X5 M50i
Tried to do this on my own yesterday but got blocked at the very beginning. When removing the fender flare, the tabs that lock the flare to the liner are so stubborn to disengaged. Couldn't get any one of them out of position.
So when you are talking about the "bottom vertical tab", which one do you refer to in the following pic (marked up from the IND pic)? A or B? As I did not see A in your pic.
Also how did you get that done (bending tab A up from inside the fender liner and push it out from there)? Did you use any tools or fingers only?
For tab B it seems that I have to either push it from the front bumper ventilation hole (2nd pic), or pull it from the gap behind the flare (3rd pic)?
      04-06-2020, 02:35 PM   #17
seanyo
seanyo's Avatar
14
Drives: 2016 X5
I was referring to the tab you marked as A. It is pointing down, if you bend it up (make it more horizontal) you can push it out of the slot. From there the tabs you have marked B can be be pushed out from behind. You should be able to see them . I trim tool would help but not required.
      04-06-2020, 03:45 PM   #18
Milangel
Appreciate the info!
I notice that tab A has a hole. Does that mean it is secured with a screw or something similar? Or it is flexible to bend with fingers?
Right, I can see tab B from either front bumper or from behind. Did not notice tab A yesterday and had a hard time fighting to push tab B out from the very beginning
      04-06-2020, 05:56 PM   #19
seanyo
seanyo's Avatar
14
Drives: 2016 X5
I don't remember there being anything securing the A tab. Once that is free the other tabs should be easier to get out. Good luck!
      04-10-2020, 07:09 PM   #20
mspete75
22
Drives: 2020 X6M50 2019 X5M
Love em!
      06-26-2020, 01:27 PM   #21
Ftpohyeah
Ftpohyeah's Avatar
Drives: BMW
2008 135i  [0.00]
2020 X5 Sdrive  [0.00]
How do i remove the rivets? Do i need to push it in first or just yank n break it?
      10-23-2020, 11:35 AM   #22
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
5303
Drives: Audi BMW Ferrari LR MB
The most difficult portion of this install is the removal of any adhesive left behind from the previous set of reflectors. Outside of that it is fairly straightforward and much easier if you remove the plastic rivet.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
