BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Engine coolant low
      12-03-2018, 12:02 PM   #1
tcw495
tcw495's Avatar
272
Drives: F90 M5
Engine coolant low
Anyone had this warning? I live less than 2 miles from the dealership, so got it topped off first thing this morning when I saw the warning. But I'm still a little nervous after seeing what happened to Quickburn7's engine.
      12-03-2018, 01:02 PM   #2
Quickburn7
Drives: 2018 Bmw M5
I had that message. About 30 seconds before my engine went Boom!
      12-03-2018, 02:12 PM   #3
tcw495
tcw495's Avatar
272
Drives: F90 M5
Shit, that's what I was afraid of. Will check later, but hopefully I didn't puncture.
      12-03-2018, 03:49 PM   #4
tcw495
tcw495's Avatar
272
Drives: F90 M5
Did you have leaking under your vehicle once you realized there was a puncture?
Wondering if I can just check for a leak in my parking spot today as a tell-tale sign, without having to even start up the car if there is any issue.
      12-03-2018, 04:20 PM   #5
TheRealBob
Drives: '18 Bluestone M5
I thought Quickburn lost oil pressure. Why would he have a low coolant message? Maybe I'm confused as usual.
      12-03-2018, 04:20 PM   #6
Quickburn7
Drives: 2018 Bmw M5
Yeah just look for fluids right under the engine cooler. Should be easy to spit if there is a leak or a puncture
      12-03-2018, 04:28 PM   #7
GUNGASLOW
192
Drives: 2019 M5
Wasn’t it oil pressure?
      12-03-2018, 05:28 PM   #8
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
G30 guys had a few occurrence of Low Coolant message.
I did too, but after topping off, after almost a year, nothing yet. ::knock on woods::
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      12-03-2018, 05:44 PM   #9
trackday96
trackday96's Avatar
155
Drives: BMW M5 CS, Porsche 911 GT3 RS
2022 BMW M5 CS  [0.00]
2016 BMW M4  [0.00]
I had the message as well; they topped off but also replaced two coolant hoses under warranty (car has ~9200 miles). I did not have any noticeable leaking, but went from 4 weeks prior having the fluids topped off to almost none.
Good luck!
instagram: trackday.fanatic
      12-03-2018, 06:03 PM   #10
Vic55
Vic55's Avatar
19359
Drives: 2023 BMW M8 Competition Coupe
Coolant is different than oil pressure (Quickburns issue) as others have pointed out. You can not drive the car with loss of oil pressure. Coolant low has nothing to do with pressure but instead the level. And its easily remedied as you did.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
vtknight966.50
      12-03-2018, 06:13 PM   #11
tcw495
tcw495's Avatar
272
Drives: F90 M5
Thanks!
      12-03-2018, 09:01 PM   #12
kdeleon
Drives: M5
I posted a similar question a month or so ago as I also got the message. Most said it was related to the lowering temperature. Not sure if it is any colder in CA recently.
r33_RGSport12967.50
      12-03-2018, 10:35 PM   #13
r33_RGSport
Yea, we just hit "our" 32°F and rain recently.
      12-11-2018, 10:23 PM   #14
droitman
Drives: BMW M5 2018
Had this week for the first time when temp dropped to about 20F. I've ignored as it goes away if it's a bit warmer (over 30F). I guess I'll top off this wkd and see what happens.
      12-09-2019, 04:59 PM   #15
Clarkey
Clarkey's Avatar
United Kingdom
38
Drives: 340i M Sport Touring
Which coolant is used in the F90 as mine needs topping up and the manual doesn’t state the type anywhere.
Does it have to be BMW or is another brand ok?
      12-16-2019, 08:10 AM   #16
jensputzier
Germany
99
Drives: 2018 F90 M5
I had the coolant level low message in my first F90 after appr. 11.000 km. We topped it up, but never got to follow it as the car was totalled shortly after that. No with the new F90 I just had the same warning at 13.000 km. Will ask the dealer now what to do.
HAZET Stahlwille Knipex German tools shipped worldwide.
http://www.jensputzier.com
      01-15-2020, 03:39 PM   #17
ACF90M5
ACF90M5's Avatar
21
Drives: 2018 F90 M5
I've had it multiple times. I had an unknown leak back in August that looked like oil. Been running through coolant like crazy and just got told a rock punctured one of my auxiliary radiators after they pressure tested it. When you bring it in for a top off and they don't put in a crazy amount to either reservoir you should be fine. Otherwise it is something you should look into asap
2018 BMW M5 Black Sapphire Metallic
GONE - 2013 Audi S6 Phantom Black Pearl
      02-03-2020, 06:14 PM   #18
soopa
Drives: 2018 F90 M5
My car showed it for about 1 week. The day I took it in for service to top the coolant off the warning message went away. The mechanic told me that I had a full tank of coolant.
      12-09-2020, 01:00 AM   #19
jensputzier
Germany
99
Drives: 2018 F90 M5
I just had the message again at 30.000 km. Can't remember what they did last time.
m5post
