12-11-2018, 08:23 PM | #1 |
El Conquistador
12
Rep 44
Drives: 2015 535i xDrive
Tire concerns
My new to me 2015 CPO 535i XDrive Luxury Line came equipped with Goodyear Eagle® LS-2 ROF tires. (245/40R19) As I head into my first Michigan winter with them I am reading reviews and beginning to worry. Worry about their winter performance and their overall performance.
I'm reading about a lot of early failures and the warranty seems to be crap. Only seems to cover issues, like noise and roughness, found in the very first bit of use. No real coverage for failures as far as I can tell. But I can only read so much fine print, I will admit. And their winter performance seems to be sub par. Anyone have experience with them? What's the go to tire(s) I should be looking for? I dread the cost of both new all seasons to avoid failure and new winter to survive in Michigan. This is my daily driver. Thx |
12-11-2018, 09:57 PM | #2 | |
Rep 5,366
12-12-2018, 11:12 AM | #3 |
Rep 697
Drives: 2013 535xi
The Goodyear LS2 tires are not good for many reasons:
- rough ride: I have had softer runflats that handle better - easily damaged by potholes: I killed two of them in one go, as they blister quite easily - like most all-season tires, they cannot compare to a dedicated winter tire - like most all-season tires, they do not handle as well as a high-performance summer tire If you are looking for a reason to replace your tires, you will find many if not most on this forum will tell you to ditch the Goodyear LS2s for all of the above and more. Having said that, you should be OK for an Ann Arbor winter except for perhaps going to the ski hill or braving a winter storm.
2013 535xi, Carbon Black, beige interior, M Sport package, HUD, DDC & ARS, ACS springs, Kelleners wheels
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
12-12-2018, 03:42 PM | #4 |
El Conquistador
12
Rep 44
Thanks for the confirmation. Much of my reading on this forum has confirmed that these tires are crap. I'm glad they haven't caused me trouble yet. Odd that BMW would use them at all.
Recommendations? For winter wheel and tire combo? 17s or 18s? I'm coming from a long line of subaru's and used to just plowing through whatever winter throws at me. I'd like something that won't break the bank, but also won't look too horrible. Will stick with RunFlats too, for now, to avoid the spare tire work. For better all season for the rest of the year? I'll probably stick with the LS2s until one fails, but want to know what to have lined up for when that happens. I see quite a few recommendations on the forum over time. Hard to know if they all stand the test of time. Is there a collective current thinking about this? Really appreciate the help. |
12-12-2018, 05:29 PM | #5 |
Rep 659
I'm not sure the 17's fit the 5 series any longer.
Of course dedicated winters are the best option but I get by on Conti DWS just fine. I have friends in Grand Blanc that drive 5 and 3 series XDrive that are happy with Michelin Primacy which are all season also. I have made trips there for visits during prime time (December/January) with no issues. Now what you will run into is the want of run flats, this will greatly lower your choices. |
12-12-2018, 05:44 PM | #6 |
Rep 697
Drives: 2013 535xi
For winter driving in the Canadian snow-belt, I had Nokian Hakkapeliitta runflats on 18 x 8" aftermarket wheels on my F10 that performed exceptionally well. They were oversized at 245/50/18, but worked without any rubbing issues and configured like this my xDrive was unstoppable. When I lowered my car, I had to switch tires and ended up switching wheels too, so now I now have a set of Nokian WR A4 runflats on a different set of 18 x 8.5" wheels. These newer tires are 245/45/18 which is a correct size for the F10. I have not yet tried them in much snow, but expect to soon when I go skiing in the near future. They should be nearly as good as the Hakkapeliittas but are more performance oriented.
12-12-2018, 06:51 PM | #7 |
El Conquistador
12
Rep 44
For winter wheels, I'm looking for 18x8, right? What offset am I looking for? I'm trying to figure it out from what I can find on this forum, but I'm unclear how to take into account the wheel size change from 19x8.5 to 18x8 and I'm not sure how to find out what my existing offsets are. I think they are 35.
I'm thinking that 18x8 with a 40 offset is about equivalent. Did I get that right? Here are two options I'm considering. Thoughts? Alternatives? Alternative sources? Last edited by SonOfAnakin; 12-12-2018 at 09:43 PM.. Reason: wrong attachment. |
12-12-2018, 09:52 PM | #8 | |
El Conquistador
12
Rep 44
Would this option look like what you had? Last edited by SonOfAnakin; 12-12-2018 at 10:43 PM.. |
12-12-2018, 11:54 PM | #9 |
9159
Rep 14,521
you can get some ideas in the MarketPlace as you'll find people selling they're winter setups.
12-13-2018, 11:29 AM | #11 | |
Rep 697
Drives: 2013 535xi
Regarding your tire/wheel choice, tires are oversized in that they are taller than stock. I did use that size for my aforementioned review, and they can work for you as long as your wheel offset is OK and you are not lowered. The wheels will not fit as the bolt pattern is 5 x 114.3 vice the 5 x 120 that you need for the F10. Also, if the offset is truly 40 (I'm guessing at the number down in the description), then this is too high, and you will be facing rubbing issues against the suspension. Cheers.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) Last edited by cdmulders; 12-14-2018 at 11:42 AM.. |
12-13-2018, 08:31 PM | #12 | |
El Conquistador
12
Rep 44
Did I miss anything else? |
12-13-2018, 10:59 PM | #13 | |
Rep 697
Drives: 2013 535xi
- 245/45/18 is the proper size for the F10. As I said, 245/50/18 you propose will work, and will fill the wheel arches a little more since the overall diameter of the tire is about one inch more than a 245/45/18. I have a picture somewhere of what these wheels / tires looked like on my F10, and will post if I can find it. - A 245 size tire (this is the width of the tread, just in case you did not know) is a little wide for a 8" wide wheel, but can work. The tires will bulge a bit. If you wanted a more streamlined fit, then you should go with 8.5" wide wheel, still keeping the 32mm offset. Cheers. Edit: I found a couple of pics to show you the size of the 245/50/18 tires.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) Last edited by cdmulders; 12-13-2018 at 11:45 PM.. |
SonOfAnakin11.50 |
12-18-2018, 06:28 PM | #15 |
111
Rep 377
Drives: 16 X3 28d/18 540d xdrive
Save your money and go with 17" wheels and 225/55-17 winter tires. For example, BMW wheel style 327 was standard on base model 528xi and are available for about $100 each on the internet (ebay or craigslist). Modern winter tires are formulated with similar compounds and perform much the same, so not much is gained from spending top dollar for Nokian or Michelin. In fact, Consumer Reports ranks Cooper and Hankook ahead of more expensive brands. Finally, while 245 tires will look cooler on your car, narrower 225's are more effective in deep snow and on slippery roads.
I am confident about the fit as I have those wheels and tires on my '16 535d xdrive and live in a snow belt off of Lake Erie. Last year we had 200 inches of snow, so I can vouch for the value of narrower 17" wheels and winter tires. Good luck on your purchase. |
