02-05-2019, 07:48 AM | #2 |
Rep 6,121
check your door plate
09-29-2020, 06:12 PM | #3 |
Rep 92
Would like to know too... my experience of using the door plate (in my past BMWs) pressures is premature tyre wear.
Adding some PSI seems to help. I'm running an M50d on 315/30/22 rear & 275/35/22 front. Both are non-RFT. Based in Ireland so average annual ambient temp is probably around 10C. Usually drive alone with little or no luggage. Any recommendations for similar conditions & weight?
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas! Previously 2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D |
09-29-2020, 07:29 PM | #5 |
33
Rep 47
09-30-2020, 04:49 AM | #7 |
33
Rep 47
I'll be throwing on 20" wheels and blizzaks for winter driving (first winter with this setup) any ideas on tire pressure? Will iDrive throw an error as I'm guessing the tire pressure on the 20" wheels will be different than the 22s?
09-30-2020, 02:12 PM | #8 | |
210
Rep 336
10-17-2020, 03:08 PM | #10 |
Rep 236
I started of a year ago running the door plate psi and started getting premature sidewall wear on the contis. I upped it about 6 months ago by 5 psi from the low load figure and the wear is so much more even now. Got about 15000 miles on them now and measured them last week at 5 mm tread so still going strong. Pleased overall with them.
10-20-2020, 08:48 AM | #11 |
Rep 195
seems to be some difference between peoples readings:
fronts (275/35 R22) currently range between 33-34psi rears (315/30 R22) currently range between 34-36psi which seems to match the label on the car (attached below).
G05 X5 M50D - Carbon Black - Tech Pack - Comfort Pack - Sky Lounge - Individual Merino Leather
10-20-2020, 01:47 PM | #12 | |
210
Rep 336
Edit... I said it backwards but I think you know what I mean. |
10-22-2020, 04:26 AM | #13 |
Rep 195
It's for the M50D which has 22s front and back, not the mix like the X5M.
