Who has a welded aftermarket exhaust?
07-21-2008, 10:09 PM | #1 |
Rep 1,193
Jus askin if anyone welded their aftermarket exhaust instead of using shitty slip joints. I may wanna do this but Im afraid to screw up my 1700 dollar exhaust.
07-21-2008, 10:17 PM | #3 | |
Rep 1,381
Just take it to someone who knows how to weld exhaust and nothing will be screwed up. Slip joints just make installation and removal easy. If you are doing it yourself, just use the slip joints, then after 1000 miles or so look underneath again. If there are no leaks, then don't worry about it. If it looks like you have problems with leaks, get someone to weld it. Typically with slip joints I see slight leaking, but usually not enough to be worried about. It's really just up to you.
2008 BMW 335i: Jet Black, Jade Gray, Gray Poplar, 6MT - Stock... for now.
07-21-2008, 10:20 PM | #4 |
Rep 3,469
None of my exhausts sealed without welding.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
07-21-2008, 10:24 PM | #6 |
Rep 1,193
07-21-2008, 10:27 PM | #7 |
Rep 7,719
Pretty normal to get an OEM muffler cut and have an aftermarket one welded onto the pipe. This action probably accounts for more than 50% of the stuff done at muffler shops.
07-21-2008, 10:30 PM | #8 |
Rep 1,193
07-21-2008, 10:37 PM | #9 |
Rep 1,381
Well, what they will do is put it together with the slip joints, then just weld around them. It's a piece of cake to do, and will seal VERY well and be VERY strong. That's far superior than either two pipes butted up and welded, or just a plain slip joint.
07-21-2008, 10:51 PM | #11 |
Rep 4,726
Really? I wish you luck getting an aftermarket exhaust to fit after welding it. Actually thats a lie, I hope you fail miserably just to prove my point. Most barely fit properly with the slip joints.
You said it, custom exhausts, that's how. Not difficult when your sitting there fitting it on your car then welding it.
07-21-2008, 11:08 PM | #13 | |
Rep 1,381
If whoever you use to install your exhaust can't lay a bead around a slip joint, then you might want to look for someone who actually knows how to weld.
07-21-2008, 11:24 PM | #14 |
Modder Raider
753
Rep 8,633
Drives: M3
I have had all of my fittings welded, but I prefer the flanged joints for ease of installation.
Flanged is the way to go! I believe that AE is the only aftermarket comapny to have all sections of their DP back exhaust flanged. Props to them!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-21-2008, 11:29 PM | #15 |
Rep 1,193
What exhaust do you have MR.5?
07-21-2008, 11:31 PM | #16 |
Rep 4,726
Sorry, misunderstanding, your definition of welding an exhaust is clearly different then mine. Go ahead and weld the slips together all ya want.
07-21-2008, 11:35 PM | #17 | |
Rep 1,193
What did you mean the O-cha? Any advice woould be greatly appreciated. My idea is to ditch the slip joints and weld it instead. I already cut the stock exhaust already. I dont see how that would be a problem unless the guys who are doin it are a bunch of tards. They seem pretty confident in doin it. They say its a 2.5 to 3 hour job though. |
07-21-2008, 11:42 PM | #18 | |
Rep 4,726
Anyone who has installed more than a few exhausts will tell you that. Some companies make exhausts that fit like OEM, unfortunately 90% do not. You said your "muffler" guy will buy you a new exhaust? Then let him do it, but to get it to fit well hes going to have to do some fabrication guaranteed.
07-22-2008, 12:06 AM | #19 |
Rep 1,381
Okay, I think I know what you're saying now. Yes, you obviously can't just toss the slips completely and butt up the pipes. If the pipes are even an inch shorter that would have been taken up in the slip joint (which they probably are), then butting up the pipes would lose that inch and you can have any problem from just your tips being too short, to the pipes not fitting around the suspension, etc.
However, my point remains, to the OP. Removing the slip joints completely is silly. That's like taking a kit and throwing away an important piece and trying to make it work without it. There's absolutely no reason why you shouldn't line it up with the slip joints, then weld the slip joints together with the rest of the pipe. Then you don't have to worry about getting clamps tight enough, and you have a strong and tight seal. Otherwise, as O-Cha was saying (and I missed it, sorry), whoever is doing the job is probably going to have to cut another piece of pipe to fill up any gap. +1 on a flanged setup though, Mr. 5. I installed a Mac midpipe and catback on my old Mustang and it was flanged all the way back, and I've seen no evidence of much leaking. It's a much better solution to a simple slip joint for bolt together.
07-22-2008, 12:37 AM | #20 |
Rep 1,193
Who knows. He wil probably do some fabrication to make it fit properly. But to lose the slip joints would look super clean. Lets see what he does tomorrow. Ill post pics tomorrow.
07-22-2008, 06:58 PM | #21 | |
Rep 471
Oh Boy....Here comes O-cha |
07-22-2008, 09:03 PM | #22 |
Rep 429
By slip joints are you saying these aftermarket exhausts actually have pipe unions (ie double female short piece of pipe) to join two other pipes? That seems odd.
You don't have to weld anything unless you plan on leaving on there for 10 years and never touching it. If you want a leak-free exhaust you can just put some copper permatex RTV as it seals exhaust just fine and won't melt etc. I've seen it used on headers with good results. http://www.permatex.com/products/Aut...sket_Maker.htm For the cleanest look (for those that like to get under your car and check out your exhaust) I guess welding is an option but there are some different exhaust clamps that are a lot nicer than the old fashioned "U" clamps and might help.
2014 Audi S5 DSG
2011 335xi Sedan (retired) 2008 335xi Sedan (retired) |
