iPhone 3G compatible with BMW iPod kit
07-22-2008, 07:28 AM | #1 |
Certified Purveyor of the High Life
63
Rep 260
Just tried it out and it works.
One caveat: When I hooked my iPhone up to my corporate email system (via MS Active Synch) it forced me to enter a complex password on the device (no big deal). When I plugged the iPhone into the BMW adapter with the device locked it DID NOT recognize it as an iPod. Once I unlocked it, and plugged it back in, no worries - controls work through the BMW radio (I don't have idrive). The iPhone itself displays an error message and says that the "accessory" isn't compatible - but obvioulsy that is BS - works great. Also I paired the bluetooth in about 1/2 minute - but have yet to make calls with it so far - should be no issue.... Cheers, -j |
07-22-2008, 08:15 AM | #2 |
Rep 425
yeah - you want to unlock the iPhone if you have a password on it. . . although I have found that sometimes it will still go even with it locked.
BMW 335i - e92 Ordered: 4.23.08 Picked Up: 6.19.08 Blk Saph, Black Lthr, Alum, 230s, Man, Prem Pkg, Sprt Pkg, Navi, Prk Dst, CA, iPod, Cstm Pedals, Pntd Reflctrs, GP Thundrs, 30% Huper Optik Tints / 60% Wndshld, Euro Fogs |
07-22-2008, 11:07 AM | #3 | |
Rep 713
Drives: '06 E90 - '04 E85 - '16 F15d
07-22-2008, 11:14 AM | #4 |
51
Rep 1,928
yeah it pisses me off i cannot charge it. that is extremely important for me and the idiots changed it so it could charge faster? i hope we get a fix soon. if bmw was the first before i hope they are again with this one... it should be easy to do!!! sadly that doesn't mean it will happen fast but i hope so
07-24-2008, 07:33 AM | #6 |
63
Rep 260
So I did notice the same behvior as well... the control works, however it doesn't charge (I hadn't even looked at this the first time, since I assume the charge was working).
I tried to plug the cord that came with the iPhone into the car's USB port . . and that did in fact charge the device. I plugged the headphone jack into the car's audio "in" jack using a male-male mini phono cord. So now I have sound and charging. HOWEVER. for some reason the car doesn't recognize the device as an iPod . .so I've lost the car control - basically, this is pretty worthless solution. For some reason, BMW gave me two iPod adapters when I got the car (part number 0 440 796). I think I'm going to crack one open and re-solder the pin configuration to the power to be correct. If this is possible, I'll post it up here. In the meantime, I think I'll just use it as is and not worry about the charging aspect so much. |
07-28-2008, 10:17 AM | #7 |
Rep 33
Drives: '22 X6M Comp
Mine seems to be working very sporadically. It does not charge, I have a pre 3/07 (by 2 weeks) and it appears that the dealer installed unit doesnt charge the iphone 3G. The music playback is very buggy, ie, yesterday it was playing and all the sudden it stopped so i got the iphone out of the glove box, and it had the message up asking if i wanted to switch to airplane mode (I had already hit no when I plugged it in). Once I hit no again the iphone went back to the ipod screen, but no music, and I couldnt change the track with the radio. If i hit play or changed the track on the iphone music plays and track changes. This is shitty, anyone else had this problem.
07-29-2008, 09:51 AM | #8 |
Rep 113
I have the orig iPhone and 6FL and I seem to be having issues with the lock/unlock thing. Even with the phone unlocked I have been having problems getting it to work. Hopefully this is something that Apple will fix in the next software release because everything worked perfectly before the 2.0 update. I havent tried yet to see if my contacts are working via bluetooth but I have read that people are also having issues with that. Hopefully Apple and BMW will get this worked out since both are touting their integration with the iPhone.
07-30-2008, 06:37 AM | #9 |
Rep 177
I just got my 3g also. I think it works GREAT! Try downloading the pandora radio application. You can play sattelite radio through the iPhone. It's a great FREE program.
07-31-2008, 04:36 PM | #10 |
Rep 152
So, just to clarify:
are you guys able to play the ipod music feature from the iphone through the USB jack -OR- do you need to plug the headphone jack into the auxilary port for audio, and solely use the USB jack for charging?? -I have a 2007 non-idrive E90 with the iPod option ($400!) and a brand new iPhone 3G. The phone charges when attached to the USB jack, but the audio display on the car says "unsupported device", so no music. What gives? My iPod Nano works well. Thanks |
08-05-2008, 12:33 AM | #11 |
Rep 240
Mine works weird as well... I tested it on my X5, and there it charges while listening to music as well. But on my 335, I can only hear music.... does not charge. Well, it did once and hasn't since.
08-05-2008, 10:08 AM | #12 |
Rep 127
08-09-2008, 12:47 PM | #13 |
Rep 132
anyone have news on this...
supposedly BMW produced a new cable in 8/07 that is compatible with the 3g (ie, charges through USB pins) the only other options I have seen are to either get the Kensington 4-1 charger and use the pass through ipod connector to charge the iphone http://www.amazon.com/gp/product/B00...reative=380601 or this adaptor coming in Sept. http://www.ilounge.com/index.php/new...rge-converter/
07 e90 335i Black Sapphire on Black Leather
ZSP/ZPP/CWP/Navi/Sirius/iPod/CA 20% tint/Blacklines/OEM spoiler/OEM style splitters |
08-11-2008, 04:46 PM | #14 |
Rep 198
My iPhone only actually charges if I say to enable airplane mode when I plug it in.
I plug the phone in where my iPod is normally plugged in to charge. I get an error on the iphone and says blah blah only if you enable airplane mode but i wont be able to receive calls. If I say yes to enable airplane mode it charges. If I say no I continue to get calls, I can play MP3s off the iphone(although they have interference and sound bad some of the time), and blue tooth syncs, HOWEVER even though the phone says it's charging the battery never increases, unless its the slowest charge ever. In airplane mode the phone charges as normal(which means pretty fast) but I obviously can't receive calls. God did that make any sense? |
08-18-2008, 10:50 AM | #15 |
Rep 1
I have a 2008 135i and the ipod cable that shipped with the car appears to charge the iphone 3g as well as allow audio play through the car's stereo system...
However, when I plug the adapter into the iphone it says "not an iphone supported device. do you want to enable airplane mode?" I say no and everything seems to work OK. Is this a problem? Also, does anyone notice some slight audio interferance when listening to music??? Would this be a Logic7 issue? ]d |
09-23-2008, 02:26 AM | #16 |
The Man
17
Rep 348
Ok. If i buy the BMW OEM kit and have it installed in my 01/2007 2007 non idrive 328i, will that charge my IPHONE 3g? That is the 100,000 dollar question. Anyone have an answer?
10-06-2008, 06:26 PM | #17 | |
Rep 132
10-06-2008, 08:24 PM | #18 |
83
Rep 1,861
Drives: 2008 E92 335i
Sweet, I've been patiently waiting for this damn device to come out. Will this thing work with the Most adapter?
10-06-2008, 09:47 PM | #19 |
The Man
17
Rep 348
Well, I just picked one up and i tried it on a device I know wont charge my iphone 3g and it worked. Gonna have the ipod retrofit installed next week sometime w/ it. So, I hope it works :P
2007 328i (01/07 Production)
Monaco Blue / 2014 MSport 328i - Glacier Silver Modifications: Blacked out Kidney Grill || Bluetooth Retrofit || Ipod Retrofit || Rear Power Outlets || Euro Switch || Blacklines |
