02-12-2019, 11:27 AM | #1 |
BimmerPost Supporting Vendor
9587
Rep 10,878
Eventuri F87 M2 (S55) Competition Carbon Intake System
Featured on BIMMERPOST.com The F87 M2 Competition intake system is designed to to allow the turbos to work more efficiently. By replacing the stock airbox system with our Patented Venturi filter housings and smoothly curved tubes, the airflow to the turbos is more laminar thus they can spool with less drag. Since the M2 Competition does not have air openings behind the grills, we also added sealed ducts to ensure that the intake temperatures stay as low as possible. The combination of our Venturi housings, organically shaped tubes and sealed ducts result in an optimized intake which sets a benchmark for this platform. Performance Gain: 12-20hp, 12-16ft-lb The Eventuri M2 Competition intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. Here are the details for each component and the design ethos behind them: Each intake system consists of:
The filter housings comprise of the high flow filters, aluminium cowls, V-Band clamp, laser cut brackets and the Patented carbon pods themselves. The carbon pods shroud the reverse mounted filter and smoothly shape the airflow down to the intake tubes. This geometry invokes the Venturi effect where the airflow accelerates whilst maintaining laminar conditions. It can be thought of as a large velocity stack - below is a diagram to show the comparison between our patented design and a regular intake system. Our bespoke filters aid the airflow moving through the housings and allow for an even velocity profile as the airflow exits the housings. Further details can be read in the Technology and Filters pages. CARBON SEALING DUCTS The filter housings are positioned with the openings sealed against the carbon ducts. These ducts have been designed to fit over the stock cold air ducting channels and direct ambient air into the filters. These ducts seal the openings of the filter housings and prevent heated air from entering the filters. CARBON INTAKE TUBES Eventuri intake tubes are again crafted from 100% prepreg carbon fibre. Each tube has an integrated MAF sensor mount which is CNC machined from aluminium. The shorter left side tube smoothly transitions from the carbon housing down to the turbo inlet tube. The longer right side intake tube has to clear the fan shroud and strut brace. To do so we employed the same principle as the stock tube in changing the cross section from a circle at the turbo inlet tube to an oval for clearance over the shroud, then back to a circle at the filter housing end. We ensured these transitions were gradual so as not to disrupt airflow, furthermore we maintained the same cross sectional area in order to keep the velocity through the tube constant. All the components come together in the engine bay to produce a genuine improvement in the driving experience as well as providing an incredible visual display of form and function in complete harmony. Below is a dyno graph showing the comparison between the Eventuri and the stock airbox on a M2 Competition. The car had no other modifications. As you can see, power and torque are increased through a large portion of the rpm range. This translates on the road to increased part throttle and full throttle response with the car pulling much more eagerly to the redline. The testing was done on the same day back-to-back and temperatures were monitored to ensure consistency. The hood was closed for all runs.
02-12-2019, 11:55 AM | #2 |
346
Rep 378
Awesome stuff... can't wait to get their system installed on my 340
/// F80 M3 CS ///
IND-Distribution9586.50 |
02-12-2019, 12:13 PM | #5 |
///M
6654
Rep 3,683
Looks sick, I believe Eventury builds the best intakes. Besides the look the design is awesome!!
Life is too short...enjoy your life
///M |
02-12-2019, 12:45 PM | #6 |
Rep 5,728
Drives: 2019 M2 Competition
02-12-2019, 01:16 PM | #7 |
Rep 80
Thanks! $2k for those intake filters. Looks really sexy.
M2C - HS Manual
infinitekidM2C4206.50 |
02-12-2019, 02:33 PM | #9 |
Rep 539
$2k+ usd for a 12hp gain!?! Yeah I don't think so...
CP-E DP's / Remus Race / ETS 7" FMIC / AFE DCI / Cobb V3 / ETS CP / HKS BOV
02-12-2019, 02:40 PM | #10 |
1603
Rep 1,765
Cool but how often do you open your hood to look at it for 2k? How about a non CF version for 500?
02-12-2019, 03:34 PM | #13 |
Rep 5,728
02-12-2019, 05:13 PM | #14 |
Food Critic
1086
Rep 1,015
But think of the weight savings!!
02-12-2019, 08:17 PM | #15 |
M Comp
134
Rep 228
Drives: 2019 BMW M2 Competition
Looks gorgeous, but that price for the gains is rough. If you're a show car, then this is great.
'19 M2 Competition | '07 Heads/Cam/Stall C6 Corvette | '17 Ford Escape Titanium
Past: '14 M235i, '07 335i xDrive, '06 GTO, '02 Trans Am Firehawk, '99 Grand Prix GTP Last edited by epic; 02-12-2019 at 08:27 PM.. |
02-13-2019, 07:30 PM | #16 |
24197
Rep 190,805
Nice
02-14-2019, 12:38 PM | #17 |
Rep 3,256
infinitekidM2C4206.50 AndrewC198910931.00 |
02-14-2019, 08:08 PM | #20 |
24197
Rep 190,805
