M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Dyno Results 2019 BMW M2 Competition 6MT
      02-17-2019, 10:52 AM   #1
Kelvin1000
Drives: 2019 BMW M2 Competition MT Hoc
02-16-2019: Baseline Dyno Results
100% stock with no mods
Stock Map
93 Octane
Single large fan
Closed and open hood
85 degrees with Florida humidity
Appreciate 19
808elise378.00
akkando5864.50
COChris888.50
Karmic Man1996.00
nomoracin761.00
Altra265.50
Madmat50.00
BlkSVT388.50
pnosker66.50
Robin_NL8717.00
SeanWRT3179.00
CSBM52721.00
ChrisK4449.00
DaFish157.50
      02-17-2019, 10:56 AM   #2
Kelvin1000
02-18-2019: Bootmod3 CS Dyno Results:
100% stock hardware with no physical mods
Bootmod3 CS Map (Free)
93 Octane
Single large fan
95 degrees with Florida humidity
(Sorry for the horrible testing conditions)
Appreciate 13
808elise378.00
akkando5864.50
nomoracin761.00
M-Pilot4859.00
Altra265.50
Madmat50.00
pnosker66.50
Robin_NL8717.00
CSBM52721.00
nis270r33.00
filet.M2c784.00
      02-17-2019, 10:57 AM   #3
Kelvin1000
02-23-2019: Stage 0+ CS and Stage 1 Dyno Results:
93 Octane
Three medium fans with one directly in front of the intercooler
Closed hood
I tested the car in a different shop that has a better Dyno facility. Still suboptimal testing conditions of 88+ degrees and high humidity but better cooling fans this time.
CS Map (full adaptation):
428.54 WHP
436.05 WTQ
Stage 1 Map (only two pulls of adaptation):
464.63 WHP
498.59 WTQ
Hope this helps some of you!
Appreciate 13
808elise378.00
akkando5864.50
epic133.50
nomoracin761.00
pnosker66.50
Robin_NL8717.00
CSBM52721.00
BAN_M2C4180.00
filet.M2c784.00
whoop_ass355.00
esoj37156.00
      02-17-2019, 04:05 PM   #4
N3M3S1S
Drives: 2019 Porsche Turbo S
That seems pretty strong. I was expecting closer to 350 HP/TQ.
When are you doing the BM3 flash?
      02-17-2019, 06:02 PM   #5
paradocs98
paradocs98's Avatar
Drives: M2C
Great info. Will be watching.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
      02-17-2019, 06:41 PM   #6
nomoracin
Drives: Porsche GTS 4.0
Following!
      02-17-2019, 09:42 PM   #7
Kelvin1000
Actually, I already did the CS flash earlier today.
It was an incredibly simple and intuitive process and only took me about 15 minutes from start to finish to register the license and get the software system up and running on the laptop.
Flashing it for the first time took about 5 minutes because it has to open up the ECU. After that, it flashes the maps in less than 1 minute.
Now the car pulls much harder all the way to redline with the CS map and actually feels a lot like a naturally aspirated high revving engine. It truly transforms the car.
Other benefits are that gear shifts are smoother (particularly first to second gear) and I find that the exhaust is also a bit more aggressive.
Overall, I couldn't be happier so far with the Boostmod3 setup and easy of use. Light years ahead of other bench flashes and piggybacks in my opinion.
I will go back to the dyno in the next couple of days to try out the CS map and probably the Stage 1 map.
Appreciate 10
adisz165.50
M-Pilot4859.00
akkando5864.50
VIERsr2623.00
AlpsRider2865.00
CSBM52721.00
BAN_M2C4180.00
Alfy79.00
      02-18-2019, 12:25 AM   #8
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
Great to hear! I'm planning to get BM3 pretty soon too. Just curious, have you done the crank hub fix or are you planning to?
BAN_M2C4180.00
      02-18-2019, 02:03 AM   #9
aerokubectl
Drives: M2C
Subbed !!
      02-18-2019, 05:06 AM   #10
Kelvin1000
Not planning on it.
      02-18-2019, 05:29 AM   #11
chris719
Drives: '08 M Roadster
Does it fix the after shift lag / torque management thing some people complain about?
      02-18-2019, 10:13 AM   #12
Kelvin1000
It does shift significantly better than stock.
      02-18-2019, 02:42 PM   #13
Kelvin1000
Bootmod3 CS Dyno results added in the second post.
Appreciate 3
hellrotm4142.50
nomoracin761.00
BAN_M2C4180.00
      02-18-2019, 03:06 PM   #14
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Nice one.
I bought BM3 10 days ago, still not had time to use it... too much work and too many chores and stuff to do!
This weekend hopefully try the CS map.
      02-18-2019, 03:13 PM   #15
Kelvin1000
Bootmod3 Stage 1 Dyno results added in the third post.
hellrotm4142.50
nomoracin761.00
      02-18-2019, 03:32 PM   #16
hellrotm
4143
Drives: F80
Impressive gains for the free CS map.
      02-18-2019, 04:00 PM   #17
Kelvin1000
Agreed!
That's because these cars (although still underrated by BMW official numbers) come slightly detuned from the factory so they don't outperform the M3s and M4s that have the same S55 engine.
      02-18-2019, 04:24 PM   #18
akkando
akkando's Avatar
5865
Drives: 17 M2 DCT LBB,11 e90 M3 ZCP IB
Agreed!
Thanks for doing these tests. Going to try the the CS+ map as well?
Looks like stock gets its max power later in the rev range than the other two maps.
(edited because auto correct...)
      02-18-2019, 04:39 PM   #19
Kelvin1000
Agreed!
Looks like stock gets its max power later I'm the reason range than the other two maps.
I really like how linear the CS Map feels even though it has less power than the Stage 1.
What are the characteristics of the CS+ versus the standard CS?
CSBM52721.00
      02-18-2019, 05:15 PM   #20
akkando
akkando's Avatar
5865
Agreed!
Looks like a bit more hp and a little bit less torque, but I don't have an S55, yet.
https://f80.bimmerpost.com/forums/sh....php?t=1542700
also check page 5 for explanation. Also in the example like like real CS is the OEM CS tune, and CS is now named CS+.
      02-18-2019, 05:17 PM   #21
jdub486
Drives: 19' M2C dct/ e90 335d dd
Excellent results on the cs map! I bet the car feels much faster. Although interesting that the stock m2c map peaks higher. Does the CS map feels as linear as the m2c map?
I’d love to see results with 1.5-2 gallons of e85 in the tank to make sure full timing is being hit and to offset the Florida heat.
      02-18-2019, 05:21 PM   #22
evolved///M
Drives: 2019 F87 M2C, had 2012 E92 M3
CS+ has more top end: https://f87.bimmerpost.com/forums/sh...8&postcount=40
m2
