BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis Aggressive wheel fitment for M550
      02-25-2019, 09:15 PM   #1
12bmw535xi
Drives: 2019 M550
What would be the best width/offset for a set of 20" wheels maximizing available space without rubbing/fender modifications? I'm thinking about going 20x9 +25 and 20x10.5 +35. Any advice?
      03-09-2019, 09:31 PM   #2
aadum
aadum's Avatar
Croatia
80
Drives: 330xd e92 ,520d f10, 540i G30
I am trying to figure this one out myself but no one seems to know ....
i was looking at z performance wheels with similar setup..
20x9 et35 and rear 20x10,5 ET33.... I am not sure about those rear wheels...specially as I will lower my car too
It would be nice to have some thread just for 20'' if people would care to share their experience
      03-10-2019, 04:43 PM   #3
12bmw535xi
Drives: 2019 M550
What I'm getting from wheels company's is 20x9 +25 and 10.5 +38. About 1" of concave in the front and 2.8" in the rear. I hope this helps.
      03-11-2019, 12:59 AM   #4
emre
emre's Avatar
Turkey
85
Drives: G30 540i xDrive
I think those rears are too aggressive for G30.
20mm spacers with the OEM wheels is the most popular setup many owners are running.
20x10,5 ET33 would stick out 10mm further than this and I don't think there is room for that. Especially if you will lower your car.
G30 540i xDrive M Sport MPPSK / BM3
      03-11-2019, 06:56 AM   #5
aadum
aadum's Avatar
Croatia
80
i' ve seen a guy fitting m5 wheels on his car somewhere on the forum (similar setup), but on the pictures it looked like the the wheels are sticking out.
I want to fit concave wheels but if i go with 9 instead of 10.5 i will loose the 'depth' ....unfortunately that company doesn't make anything in between....
i guess i will have to start search for something else or go for a original wheels
      03-11-2019, 07:00 AM   #6
aadum
aadum's Avatar
Croatia
80
have you seen this ?
https://g30.bimmerpost.com/forums/sh....php?t=1533602
      03-11-2019, 07:55 AM   #7
12bmw535xi
Drives: 2019 M550
Yup, I did. After the research I have done, 20x9 +25 and 10.5 +38 are the sizes that I'm going with. I will have the wheels in about 30 days and will let you know how it played out.
      03-13-2019, 08:29 AM   #8
aadum
aadum's Avatar
Croatia
80
Thanks.... when you do..please make few pictures from side and rear
      05-02-2019, 07:49 PM   #9
aadum
aadum's Avatar
Croatia
80
any updates
      05-03-2019, 04:53 AM   #10
aadum
aadum's Avatar
Croatia
80
any ideas if 20x10J ET25 will fit in rear?
      05-05-2019, 10:33 PM   #11
12bmw535xi
Drives: 2019 M550
That's too agressive. You should stick with +30.
      05-12-2019, 09:43 PM   #12
aadum
aadum's Avatar
Croatia
80
what about 11j? what would be ideal et for that ?
      05-14-2019, 10:20 AM   #13
12bmw535xi
Drives: 2019 M550
According to my calculations, you should be flushed with et45.
      05-14-2019, 07:43 PM   #14
aadum
aadum's Avatar
Croatia
80
i was doing the same math...however i am worried about almost 2cm going closer to the struts...not sure if there is enough space there
      05-15-2019, 09:25 PM   #15
12bmw535xi
Drives: 2019 M550
Stick with 10.5
aadum79.50
      05-16-2019, 12:53 AM   #16
aadum
aadum's Avatar
Croatia
80
did you mount those wheels?
      05-16-2019, 05:22 AM   #17
Dobie Dog
Dobie Dog's Avatar
Drives: 2021 F97 X3M Comp
Here is a 20x10.5 ET35 on the rear of mine for comparison.
Life is short...Drive fast
Appreciate 3
aadum79.50
      05-16-2019, 09:49 AM   #18
stk24178
45
Drives: 2021 X5MC DG
Looking good! Has this been lowered?
Dobie Dog738.50
aadum79.50
      05-16-2019, 09:52 AM   #19
Dobie Dog
Dobie Dog's Avatar
It's not lowered. I will have that completed next week.
      05-16-2019, 10:38 PM   #20
12bmw535xi
Drives: 2019 M550
Looks good! It will look great when lowered! My offset is et38 as I was making room for 295 tire.
Appreciate 6
clee1982797.50
Dobie Dog738.50
aadum79.50
540iSUP704.00
saga boy299.50
      06-15-2019, 12:48 PM   #21
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
If the g30 has as much room in the rear wheel wells as the f10, you will have no problem with 11" wide rears.
I got 20x11 ET46 on my f10, and there's still about 2cm of clearance to the strut.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
aadum79.50
540iSUP704.00
      07-16-2019, 08:49 AM   #22
x427x
Drives: M3
I'm planning to order a set of wheels with parameters 9J +25 10.5 + 38 and put tires 255/30 and 305/25 - could anybody advise will this work?
255/30 and 295/25 will work for sure, but what about rears with 305/25 as for me it will be better for 10.5 and fronts with 255/30
5post
