      02-28-2019, 02:34 PM   #1
gofast182
Drives: 2020 M340i xDrive
Cleaning the 740M Wheel
So we are now in possession of our G05. The ride back from Spartanburg was rainy almost the entire way and the 740M wheels got terribly dirty. When I cleaned them my suspicion was realized: while they look good on the car, they are a bitch to clean.
1. How does everyone else clean the scallop/channel that runs behind the spokes? This feature caught a crap ton of grit and is the worst part of these wheels IMHO.
2. Does anyone have a wheel brush that will clean behind the M Sport caliper? Clearance is super tight and my wheel brush won't even fit. I could just move the car up a foot but I'd like to clean in place if possible.
3. On the RF wheel there's now a streak of rust going around the barrel (in line with the rotor) that didn't come off with my scrubbing. To be fair, I didn't try my Sonax wheel cleaner on it yet but has anyone else seen this and removed it?
4. Does anyone recommend a wheel specific coating? I'd like to apply something semi-permanent to ease this process going forward. (I'm also looking into a pressure washer)
      02-28-2019, 02:43 PM   #2
MystroX5
MystroX5's Avatar
3608
Drives: 2020 X7 M50i 2019 M2 Comp
Easy to clean. Get yourself a good wheel brush and wash mit. You can also get your hands in there to wipe down the M brake caliper. I use my foam gun and lather it up first. I do wax my wheels with quality wax. Treat it like you do your painted surfaces.
I use this one.
https://www.autogeek.net/daytona-spe...r-brushes.html
      02-28-2019, 02:55 PM   #3
gofast182
I use this one.
That is the wheel brush I have and it won't fit between the caliper and the wheel.
Wax isn't what I'm looking for, I want to coat them. (I, too, have waxed or sealed my wheels in the past)
      02-28-2019, 03:05 PM   #4
MystroX5
MystroX5's Avatar
3608
That section between the caliper and wheel I need to pull foward about 12”. Not much will fit with the big calipers.
      02-28-2019, 06:03 PM   #5
puraj83
Drives: 2021 x5 m50i
That section between the caliper and wheel I need to pull foward about 12". Not much will fit with the big calipers.
I use a wheel woolie fit in between no need to move the car. As for the groove on the backside, I use a dedicated wheel mit
JLR052382.50
      02-28-2019, 06:33 PM   #6
JLR0523
Drives: 2019 X5 50i
Ditto.
2019 G05 X5 50i MSport Phytonic Blue
2013 E93 335i Conv Mineral White Metallic
      02-28-2019, 10:26 PM   #7
MystroX5
MystroX5's Avatar
3608
What size wheel woolie? I chucked my last one as it was ratty. I need more.
      02-28-2019, 11:22 PM   #8
AndroidRobot
AndroidRobot's Avatar
Drives: 2019 X5 50i Carbon/Tartufo
I use a small one and it fits between the caliper and wheel well enough for a good clean.
2019 BMW X5 50i Carbon Black/Tartufo
G05 X5 50i Review
G01 X3 M40i/MKII Audi SQ5 Comparison
      03-01-2019, 02:09 AM   #9
puraj83
Small and medium fit great
      03-01-2019, 10:03 AM   #10
Gerry70
Drives: 2015 BMW X5 xDrive35i
Try wrapping a wet, old MF towel around a small paint stirring stick to get between the calipers and the barrel. I had my wheels removed and coated with OptiCoat-Pro Plus when I had the entire car coated. My wheel cleaning bucket includes a chenille glove purchased at Advance Auto for $5 that I use to clean the backside of the spokes.
      03-01-2019, 10:55 AM   #11
SCA
SCA's Avatar
Drives: Multiple BMWs
Everyone do yourself a favor and purchase the large Gyeon wheel brush. You will thank me later.
GYEON quartz Cloth Wheel Brush (Large) https://www.amazon.com/dp/B01N0WJ4D5..._8vvECb18Y099D
      03-01-2019, 11:25 AM   #12
gofast182
Yeah I guess my OP wasn't clear, I have a wheel brush, a dedicated wheel mitt, and have treated my wheels with a LSP before. I was just looking for tips and tricks for the tight areas/features which are plentiful on this wheel. I'll pick up a wheel woolie to get behind the caliper.
      03-13-2019, 04:49 PM   #13
mbarrett635
Drives: 2019 X5 40i
What makes this better/different than other wheel brushes?
Copyright ©2000 - 2021, vBulletin Solutions Inc.
